Oil cooler/warmer removal.............
Old Jun 12, 2011 | 11:13 AM
  #261
bikinilust's Avatar
bikinilust
couldnt you guys do this for a cleaner look?
and weld on a fitting on the bottom of the center exit coolant pipe to take advantage of the "pathfinder coolant mod"?
Old Jun 22, 2011 | 03:31 PM
  #262
lemmiwinkz's Avatar
lemmiwinkz
ok, after reading more i found some more info on this and saw that the DE's do flow coolant at the back of the block up to the rear of the heads right before the coolant exits. however on the HR's they flow up through the exhaust side of the block to the exhaust side of the heads, correct? so after looking at it for a while wouldnt the pathfinder mod still be better? my reasoning is that the coolant on the HR is being heated in the block first then being sent to the heads, and from what i understand is that the only coolant the heads are getting is already heated coolant from the block. where as the pathfinder coolant path allows for the coolant to exit the back of the block and not contaminate the heads with hot coolant. any thoughts?
Old Jun 25, 2011 | 03:09 PM
  #263
Bigalow's Avatar
Bigalow
I'm not sure about HRs since I have a DE. I did the PF vs the HR mod because I have IC piping going all over my bay and I couldn't use the HR coolant pipe. I also needed to the opportunity to install an oil cooler which I couldn't do with all the stock components in place.
I went ahead a removed the A/C Condensor and compressor and installed a Mishi rad. My oil cooler still isn't installed but I can tell you 100% that my car is running cooler. My temp gauge would usually stay around 50-53% and now it's runs around 47-50% (I'm not exactly sure what numbers that translates to). Of course, my temp gauge gets to about 5x% while on the track.
IMO, the PF mod in itself isn't worth it without other supporting mods (new rad, a/c removal, hood vents, etc).
Old Jul 12, 2011 | 08:35 AM
  #264
snobes's Avatar
snobes
Default cooling system
Yes its an old thread but its still useful so i thought i add some more easy to see photos for people while at the same time ask some of my own questions
Ok Before we get to the photos ill explain a few things
i have already removed the heater and aircon ( its going to be a track only car)
Its a Australian RHD
Im going to remove the oil cooler/warmer setup completely (Red Lines)
Becasue ive removed the heater and im going to remove the throttle body section as well can i just remove this whole peice and block that port off?
that will remove the air bleeder, any recomendations if i should put it back in somewhere else? ( if find its a ***** to bleed these cars)
Im also going to remove the front bypass hose so i will block both ports on that plate.
Whats this rear by pass line for?
one final question
if ive removed the heater lines
the throttle body lines
the oil cooler lines
and the front bypass line
will that casue the thermostat to not work properly as there wont be any flow there when its closed now?
Old Jul 12, 2011 | 11:07 AM
  #265
DaveJackson's Avatar
DaveJackson
Master
Although I haven't performed this task, I think it's safe to say that the bleeder needs to stay in the system at a high point or bleeding all of the air out will become an even more miserable job.
Maybe, and this might be a big maybe, you could plug the firewall end of that hose and the bleeder would still function but I'm pretty sure that there has to be a bleed somewhere in the system at, or very near a high point.
Hope this helps!
Old Aug 19, 2011 | 12:12 PM
  #266
rh_334's Avatar
rh_334
I forgot to update, and i hope to make a build thread soon but here are the pics of my HR style cooling system.
Size:  128.7 KBName:  IMAG0699.jpg
Size:  89.6 KBName:  IMAG0596.jpg
Old Aug 19, 2011 | 12:15 PM
  #267
phunk's Avatar
phunk
CJ Motorsports
cool configuration you got there. i love when other people arent afraid to reorganize their engine bay.
Old Aug 19, 2011 | 12:19 PM
  #268
rh_334's Avatar
rh_334
Thanks man, yea between the cooling system, idler and tensioner delete, wire tuck and custom piping for larger housings it was a very long drawn out process, especially only working on sat nights, but its finally complete and im happy with it.
Ive been driving it 2 weeks in 100*+ weather and my defi temp gauge has yet to go above 206 (stock HR Tstat) so the system seems to be doing fine.
Old Aug 19, 2011 | 12:45 PM
  #269
bikinilust's Avatar
bikinilust
Rh_334::::
Please post parts list on ur cooling mod.
def looks sick n well thoughtout.
Old Aug 19, 2011 | 12:47 PM
  #270
bikinilust's Avatar
bikinilust
Also, u mentioned an idler and tensioner delete...
I've done the idler pulley delete, but what is the tensioner delete?
Old Aug 19, 2011 | 01:02 PM
  #271
bikinilust's Avatar
bikinilust
one final question
On ur block off plate that deletes the heater hose/tb warmer line, id suggest:
-Cut a slit on the back of the "blockoff plate" so that air bubbles can flow from the lower outlet to the upper outlet
- thread in a shut off valve into the top portion of the "block off plate" so that u can bleed any trapped air
As for the deleted rear bleeder, id suggest:
-cut off the rear bypass nipple off the rear coolant pipe and thread in a shutoff valve
- this way you'd at least have a bleeder at a high point
Just my $.02
Old Aug 19, 2011 | 05:05 PM
  #272
midz350's Avatar
midz350
I always bleed it from one of the throttle body lines. works like a charm.
Old Aug 24, 2011 | 12:36 PM
  #273
accordfreak's Avatar
accordfreak
looks great rob! glad you were able to put the hr cooling together no problem
Old Sep 6, 2011 | 11:52 AM
  #274
FastGreg's Avatar
FastGreg
Originally Posted by midz350
No.
I almost forget, its not USDM.
My HR, with the modine, too
Attached Thumbnails Oil cooler/warmer removal.............-p1000670.jpg
Old Sep 13, 2011 | 05:26 PM
  #275
rh_334's Avatar
rh_334
Originally Posted by bikinilust
Rh_334::::
Z1 will be working on a kit to replicate my cooling system, alot of small modifications had to be made and as you can tell i had to piece together custom silicone hoses, the kit will include something much cleaner and one piece. Although i do not have an ETA on the kit.
I deleted the tensioner on the main belt by replacing the lower alternator bracket with a tie rod (seen in one of the pics i posted) no real need for doing this and it was pretty expensive just to clean up things, i think in the end it cost me around $80 for the tie rod and belt when i finally found the proper length. If your interested I can PM you the parts needed but honestly if i could do it again i wouldn't have wasted the time/money.
Old Sep 14, 2011 | 05:36 AM
  #276
JasonZ-YA's Avatar
JasonZ-YA
downward facing sensors and no undertray to protect them......
-J
Old Sep 14, 2011 | 05:58 AM
  #277
Kwame's Avatar
Kwame
-J
Lol, how do you expect him to take pictures of his setup with the undertray on?????
Old Sep 14, 2011 | 06:09 AM
  #278
JasonZ-YA's Avatar
JasonZ-YA
troof...lol...
either way, my reference is undertray or not ,they get hit and then oil is jetting out everywhere with downward sensors that can easily get hit..
-J
Old Sep 14, 2011 | 07:18 AM
  #279
bikinilust's Avatar
bikinilust
How did u couple the hoses together?
I can see the clamps, but did u slip a small section of aluminum pipe between them, inside?
that's the only way I can see this working with one clamp to join to hose sections together, with the hoses being butted up together
Old Sep 14, 2011 | 08:46 AM
  #280
Zume's Avatar
Zume
Default may be silly question.....
I have been working on my own custom up the middle V coolant mod for some time now. My question (confusion) is this---
On my 05 nonrev up the rectangular hole/cutout at the front of the engine where the main coolant line passes thru measures only 1 inch by 3 inches. Way to small for the HR pipe.
The above pictures (post #226) shows a black rubber hose passing thru this hole...how is this possible on a DE?
On mine I welded 3 smaller nipples on the modified cast rear return piece that go to 3 smaller hoses that are then able to pass thru the front 1" x 3" hole.
