installing walbro pump w/utec ?
Old Feb 10, 2008 | 02:27 PM
stewieisslow's Avatar
stewieisslow
Default installing walbro pump w/utec ?
im currenty installing my walbro pump for my vortech kit....i already have a utec installed so im not using the SS box...you are supposed so run an electrical line from the positive connection on the walbro pump to the ss box..my question is...
where do i run that line into the utec?
Old Feb 10, 2008 | 04:03 PM
stewieisslow
anyone?
Old Feb 10, 2008 | 05:04 PM
str8dum1's Avatar
str8dum1
you dont run any line from the fuel pump to the UTEC.
Old Feb 10, 2008 | 05:12 PM
stewieisslow
???? in the manual you are supposed to run the line from the positive side to the ss box but im not using the ss box...so where do i run the positive side?
Old Feb 10, 2008 | 05:16 PM
Everybodywildou's Avatar
Everybodywildou
You should talk to Sam@GTM. He got this setup working.
Old Feb 10, 2008 | 05:24 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
the walbro is merely plugged in, pretty straight forward, no wire running.
Take the old pump out, clip the plastic on the new pump, put the new pump in and go.
Old Feb 10, 2008 | 05:38 PM
stewieisslow
there is a positive and a negative connection on the pump..i know that for sure...in the manual it tells you to hook up a certain wire from the ss box up to the positive side...im not using the ss box...so where do i hook up that wire????
Old Feb 10, 2008 | 05:41 PM
str8dum1's Avatar
str8dum1
the walbro pump is a direct drop in for the oem pump. it uses the oem power. you dont run any other wires anywhere.
Old Feb 10, 2008 | 05:42 PM
SpoilsofWar's Avatar
SpoilsofWar
Dont worry about any wiring.
All you do is disconnect the harness from the oem pump, pull out the oem pump out, replace it with the Walbro pump, and plug the harness into the Walbro.
Old Feb 10, 2008 | 05:45 PM
stewieisslow
we must be talking about different things...im talking about the pump that hooks up to the vortech FMU during install
Old Feb 10, 2008 | 05:46 PM
SpoilsofWar
The inline/aux pump?
Old Feb 10, 2008 | 05:53 PM
stewieisslow
ya my bad wrong wording
Old Feb 10, 2008 | 06:00 PM
SpoilsofWar
Lol, well that changes everything.
I think this is what Everybodywildou was referring to when he said talk to Sam@GTM. Maybe he got the aux pump wired with the utec.
Old Feb 10, 2008 | 06:06 PM
stewieisslow
alright ya my bad everyone i meant the inline aux. pump with the vortech kit...im under my car trying to figure this out right now so if anyone has any idea id appreciate it
Old Feb 10, 2008 | 06:44 PM
stewieisslow
any idea?
Old Feb 10, 2008 | 08:06 PM
stewieisslow
Old Feb 10, 2008 | 08:52 PM
Everybodywildou
Originally Posted by stewieisslow
TALK TO SAM @ GTM! I already spoke to him about this setup before. He got it working.
