o..myy..god vortech 300 whp
Originally Posted by jpc350z
There's also a vac line that goes to the FMU..The FMU sends fuel to the Aux fuel pump under boost. W/O the FMU supplying fuel to the Aux fuel pump the only thing the pump is doing is pressuring the fuel!!
its possible, to much head pressure at the injectors rendering them inefficient. injectors cannot open or close properly with to much fuel pressure. you need to get a fuel pressure gage on there and see what the fuel pressure is at the rail, should be around 42 psi base. then 1 psi increase in fuel pressure for every lbs of boost. ie, 9lbs of boost, total fuel pressure increase of 9 psi over 42 psi= 51 psi of fuel pressure at max boost.
Originally Posted by stewieisslow
kind of a sub question to the thread but... to people who started with the 3.33 and moved to the 3.12 did you all have to get it retuned after putting on the 3.12
I know of several people with the stock vortech kit who later went to the 3.12 and just needed a retune. Everything else was fine
I believe the stock fuel pressure is about 52psi give or take a few. When in boost (8psi) with the vortech fuel system my fuel pressure at the rails was around 100psi...That is with the stock injectors..It wasn't very good on the inj's but they were capable of a 11 A/F ratio...To the OP You need to get a better understanding of what exactly your fuel system is and what it's doing...
alright....so just finished tuning the car after wiring the fuel pump to the utec...it still is maxing out my injectors...anyone have ANY other ideas why im not getting enough fuel?
350Z_Al
Oct 29, 2020 07:44 PM
