Stillen Stage 2 Dyno results...*Flame suit on* lol
Old Mar 21, 2008 | 11:27 AM
  #121
halfass872's Avatar
halfass872
Also bare in mind there is a max RPM rating for each model blower too. The specs can be found on Eaton's website as well as a chart to show you rpm vs. psi vs. usable output. I'm not gonna try to do all the math. You may not be getting close to maxing out the RPM on the blower. But just keep that in the back of your head too.
Where's Doug now?? LMAO
Old Mar 21, 2008 | 02:59 PM
  #122
doug's Avatar
doug
hi
Old Mar 21, 2008 | 03:07 PM
  #123
superchargedg's Avatar
superchargedg
Damn Noobs
Originally Posted by doug
hi
Old Mar 22, 2008 | 03:29 AM
  #124
halfass872's Avatar
halfass872
Here's the performance map.
Attached Thumbnails Stillen Stage 2 Dyno results...*Flame suit on* lol-ct_128484.gif
Old Mar 26, 2008 | 02:26 PM
  #125
Sensi09's Avatar
Sensi09
Works Concepts
Originally Posted by c3 rolling
I have a question, my torque graph shows 281 TQ on the blue line run, is that the highest TQ acheived throughout the RPM range?
So you're asking if your peak torque is the most torque you can make.
I think that would be a yes.
Old Mar 26, 2008 | 02:51 PM
  #126
Cannysage's Avatar
Cannysage
man, hate to say it, butt i'll say it anyways.. numbers are low as hell.. but that's expected from stillen. here's my heavily modded NA chart for comarison.
Old Mar 26, 2008 | 03:05 PM
  #127
c3 rolling's Avatar
c3 rolling
what exactly is "heavily modded N/A"? Bolt-ons or motorwork? Nice numbers, The guy at church told me most the bolt on Z's that go there put down about 245-255 whp on their dynapack
Old Mar 26, 2008 | 04:10 PM
  #128
c3 rolling's Avatar
c3 rolling
I just talked to my dyno guy and he said my AFR was 10.8 to 5000 rpms and then 11.2 to redline. Isnt that a little bit too rich?
Old Mar 26, 2008 | 08:57 PM
  #129
medic165's Avatar
medic165
And for those times ya don't wanna race at the stoplight, but some punk is egging you on. Just blip the gas a lil and the SC whine will be quick to put em in their place!!
now, is it true that Stillen SC will kill almost anything at the light to 60mph, including turbo set-ups, and then slowly fall behind? If this is true, then it sounds like fun.
Old Mar 26, 2008 | 10:26 PM
  #130
azkt84's Avatar
azkt84
so what if you send out the blower to get ported to it can flow more air? then wouldnt higher psi improve performance?
Old Mar 26, 2008 | 10:30 PM
  #131
Nexx's Avatar
Nexx
myth, how fast do you think turbo charged cars with lightened flywheels hit 3,500rpm? hello n/a Z's with stock flywheels hit 3500rpm damn quickly.
Old Mar 27, 2008 | 03:46 AM
  #132
zprincess's Avatar
zprincess
Do the turbo cars pulling 400 to 850 whp have traction in 1st, 2nd, 3rd, and 4th gears? Or do they just sit there and bounce around? A friend of ours was complaining that he just bounces at the stop light since he installed his turbo.
Old Mar 27, 2008 | 08:55 AM
  #133
Ed 718's Avatar
Ed 718
BRAVEHEART
^^ Depends on my setup I can spin the tires at 1st and 2nd even on third but then again having a good set of tires comes into play here. I'm somewhere near 370 or 380whp on mine but with a proper launch and tires it hooks up pretty good.
Old Mar 27, 2008 | 03:44 PM
  #134
superchargedg
Damn Noobs
I had a stage 4 and i thought that as well..............untill i got the twins.There is no comparison at all to the stillen........my twins at a low 5.5psi would kill my old stage 4 setup to 60mph and beyond.My best run on the stillen was a 13.41 and my run with the twins(while bouncing off the rev limiter at every shift which killed my times)was a 13.01.Now remember bouncing off the rev limiter is also causing fuel cut and absolutley will kill 1/4 times.I now have a vb and cant wait to hit the track again cause this at trans shifts very fast and hard.
Old Mar 29, 2008 | 02:10 PM
  #135
azkt84's Avatar
azkt84
why are the stillens limited to like 330- 350 whp?
couldnt u port the blower and run more booth?
is it because not enough air and be ran into it or what?
a little shot of nitrous to gain some hp work?
Old Mar 29, 2008 | 02:46 PM
  #136
superchargedg
Damn Noobs
It is because the little m62 blower is just to small for the vq.The same blower is used on the chevy cobalt ss 4 cyl so that should tell you something right there.
Old Mar 29, 2008 | 03:06 PM
  #137
halfass872's Avatar
halfass872
I have noticed that air temp really makes a huge difference with this setup too!!
I've only been to the track twice with my Stage two setup. Best last week (80 degrees outside) Was a 13.8
Today @ 50 degrees i ran a 13.2 !! Made me feel alot better!! Wanted to shoot myself last week when i was barely running faster then stock!! LOL
I wish they had an evening session. I'd liek to see if i could make 13.1 at night in when the temp would be in the 40s!
Old Mar 29, 2008 | 03:14 PM
  #138
Alberto's Avatar
Alberto
Cranky FI Owner
Post a breakdown of the slip.
Old Mar 29, 2008 | 03:29 PM
  #139
halfass872's Avatar
halfass872
No clue why my 1000ft is blank It's not cause i redlighted, cause i had another that i red lighted and the 1000ft was there.
I ran 13.3s consistantly all day.
Attached Thumbnails Stillen Stage 2 Dyno results...*Flame suit on* lol-dsc04633.jpg
Old Mar 29, 2008 | 03:43 PM
  #140
Alberto's Avatar
Alberto
Cranky FI Owner
Wow-109mph, that is the highest Stillen trap by far Ive seen. Nice launch and trap, but your 1-2 and 2-3 shifts need work, with that you are easy 12.8's on that launch...
