Turbonetics g35 making insane power
Old Apr 13, 2008 | 11:13 AM
  #81
diwun67's Avatar
diwun67
Originally Posted by 98intrigue
Go to the track and trap 120mph...Then we will believe these Mustang dyno numbers are realistic. I bet you won't make 400whp on Jeremy's dyno when you come down.
fixed.
I thought Mustang dyno's were supposed to read higher?
Old Apr 13, 2008 | 11:26 AM
  #82
diwun67's Avatar
diwun67
Originally Posted by SlideFox
Deatschwerks doesn't make 650cc Injectors....
Yes they do...or did at least. That's what I'm running in my car.
Old Apr 13, 2008 | 11:31 AM
  #83
SlideFox's Avatar
SlideFox
I'm more then happy to admit i was wrong, if the info I had was incorrect.
Old Apr 13, 2008 | 11:36 AM
  #84
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by George@GTM
That was painful to read...lol
cellphone pwns me
Old Apr 13, 2008 | 11:37 AM
  #85
taurran's Avatar
taurran
I don't think it's improbable at all that he made the power he did. What's improbable is guessing he's making 430whp on a dynojet without actually running it on one.
Old Apr 13, 2008 | 11:43 AM
  #86
supra crazy's Avatar
supra crazy
Originally Posted by zcon
not insane?:-)
No that's not insane it's preety weak if you ask me I put down 420+whp on the same dyno running 8 psi turboneticsSingle turbo must Suck
Man the **** up and get a twin or bigger single
Old Apr 13, 2008 | 11:47 AM
  #87
GTM's Avatar
GTM
Vendor - Former Vendor
  #88
taurran's Avatar
taurran
Originally Posted by supra crazy
No that's not insane it's preety weak if you ask me I put down 420+whp on the same dyno running 8 psi Single turbo must Suck
wat?
The deal with mustang dynos is that one day they can be reading wildly low, and the next wildly high. It totally depends on the atmoshperic and load settings that the operator applies.
Old Apr 13, 2008 | 12:00 PM
  #89
captj3's Avatar
captj3
Says who? 400 on a stock is do able, has been done OVER AND OVER AND OVER
Here is a dyno chart form a G35 with STOCK BLOCK making 405 @ 6 psi
See what I did.... I made a claim, and post a dyno to back it up.... you should try it
Some of the people that post in the FI section are as knowledgable as anyone in the industry.
so STFU until you know what your talking about
Ok genius so I forgot to put a question mark at the end sue me. I've posted my dyno sheets long time ago. He wouldn't be the first to not have his dyno sheet from the run. I know what I'm talking about as*hat. My whole point was 408 wasn't impossible and that the dyno he used was accurate. They are not known to give inflated numbers if anything there numbers are lower. Maybe if you should have read my other posts before opening your mouth.
Old Apr 13, 2008 | 12:05 PM
  #90
SlideFox's Avatar
SlideFox
cellphone pwns me
Old Apr 13, 2008 | 12:19 PM
  #91
supra crazy
a greddy tt kit with meth injection made 430 on 10.6 lbs on the same dyno.
Who, might I ask?
wat?
That is true, but it is the same person who dynoed both our cars I'm preety sure they have presets for the load settings.
Old Apr 13, 2008 | 12:21 PM
  #92
captj3's Avatar
captj3
401 hp?
Its not that you cant make 400whp, you have to consider the size of the turbo, engine, and psi ....some kits make 400whp at 6-8 psi but look at the size of the turbo they use...now look at the flow charts of the hifi turbo u have.
Also in your post you mention why he is incorrect: he claimed with a exhaust leak too That the gains 40whp on a tune(which if true, it makes you wonder on the previous tune) and then add another 10-20whp on top of that on a "rice" correction to approximate dynojet numbers? he already admitted its not his fault his shop told him so, so maybe incorrect advice...maybe he received an inflated number for "business purposes' who knows really as Tim said....the should have done a baseline
ID be nice to see the boost curve of the run too.
The shop only will give the dyno jet # if asked and everyone is told that it's an approximation. The original install and tune was done at a different shop. I happened to speak with the tuner as I was getting some work done there. If you read my posts they were mostly about the accuracy and the integrity of the shop not neccesarily the thread starter. (sorry zcon) I probably have the most runs on that dyno and it's always been very accurate with my car + or - depending on the weather. I can't talk about his gains as I didn't see the car run, but I have had 40rwhp/20tq gain just by removing hi flo cats and installing test pipes. Sometimes people read to much into a post and it keeps getting worse on this forum. This has stopped a lot of old members from posting when they have had good and bad experiences.
Old Apr 13, 2008 | 12:52 PM
  #93
taurran's Avatar
taurran
It all boils down to : If you want to claim what your car makes on a dynojet, RUN IT ON A DYNOJET.
That's it. All this other arguing is just masturbation.
Old Apr 13, 2008 | 01:18 PM
  #94
GTM's Avatar
GTM
So I'm thinking, we should make a forum rule that only Dynojet dynographs are valid and all others don't count?
What do you guys think, eh?
Old Apr 13, 2008 | 01:50 PM
  #95
IIQuickSilverII
worst case..at least do a baseline run on what ever dyno to check on the gains.... and dont assume dynojet till you see a dynojet
Old Apr 13, 2008 | 02:40 PM
  #96
zcon's Avatar
zcon
this thread is so stupid it makes my head hurt. i left performance factory with a dyno of 380. this was running 11 degrees of timing. im now running somewere around 19. when we put the dyno on for the preliminary run it was 360 . given my "assumtion" that everyone seems to be so hung up on.
cliff notes: 380 on dyno jet
360 on mustang dyno
408 with meth and same psi on mustang dyno
take a look at the 20 whp diffrence from the time it was at pf to the time it sat on the mustang dyno.
so all you guys can go on "assuming" what your saying isnt ignorant.
Old Apr 13, 2008 | 02:45 PM
  #97
taurran's Avatar
taurran
360 on mustang dyno
I'm not trying to talk trash, but the only one I see here assuming anything would be you. (that your car would make 430whp on DJ)
If you don't want people debating the validity of the assumption you should go run it on the Dynojet. I'm interested in seeing what it would make.
Old Apr 13, 2008 | 04:59 PM
  #98
EnjukuBG's Avatar
EnjukuBG
Enjuku Racing
Yea Craig, man up and get a bigger single.
Old Apr 13, 2008 | 05:47 PM
  #99
diwun67's Avatar
diwun67
If you don't want people debating the validity of the assumption you should go run it on the Dynojet. I'm interesting in seeing what it would make.
+1
Old Apr 14, 2008 | 05:01 AM
  #100
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by superchargedg
Man in the fi forum you better have a titanium shield around you as this is a harsh place to be.If you say you have this amount of power you best be able to prove it.Robertk has been thru the ringer for posting some totally bs rwhp #,s and now you are next.Oh well just another day in the fi forum.
Uncorrected number don't lie. And 6.5psi is manifold pressure (what the UTEC reads) not going off your bragging right a-pillar pod gauge pressure. [/end]
