Eagletanggreen---> ForgedPerformance long term motor update<------
Old Apr 19, 2008 | 12:52 PM
  #101
DanielW's Avatar
DanielW
Originally Posted by eagletanggreen
I love it and have ran about 10 gallons thru the motor, Sharif was able to tune it for crazy torque. If you have a tuner that's not afraid to tune meth for power I would say go for it. With that said, we as a community are still growing with this meth... i.e I blew a plenum with it.
does the tq come on differently with the meth?
Old Apr 19, 2008 | 12:53 PM
  #102
GTM's Avatar
GTM
Vendor - Former Vendor
Well there is nothing wrong with more octane, the high the octane rating, the more timing you can run, hence more power you can make.
I would go with what your tuner/builder recommends.
-George
GTM
Old Apr 19, 2008 | 12:59 PM
  #103
rcdash's Avatar
rcdash
Originally Posted by D350Z10
I am already tuned on 110 octane + straight methanol.... I just think its to aggressive and should have had a water/methanol mix. But Sharif insisted and wanted to run straigh methanol.
From a combustion standpoint it's just as safe. Methanol lowers the combustion temperature (not as much as water per unit mass, but still quite good) and it also acts as a fuel. So you can get away with injecting less fuel. Methanol cools better than fuel, so the tradeoff is a good one. Water also cools, but it does not burn like methanol or gasoline - all it does is absorb heat. (Yes, I know some chemistry major will say you can burn hydrogen gas, but I have yet to see any proof it is created in WI).
I forget now - what kind of cams and plenum you have Dil? A pressure relief plate is always a good idea with any kind of methanol/nitrous injection. Talk to Joe K. about why the BOV switch for Luie fixed the backfire issue. I'd love to hear his theory on that (or why he decided to try it).
Old Apr 19, 2008 | 01:06 PM
  #104
D350Z10's Avatar
D350Z10
Originally Posted by rcdash
I forget now - what kind of cams and plenum you have Dil? A pressure relief plate is always a good idea with any kind of methanol injection. Talk to joe about why the BOV switch fixed backfire issue. I'd love to hear his theory on that (or why he decided to try it).
I am running a Cosworth and a Scott performance stage 2 cam, with a greddy type rs bov. I also asked Sharif about the backfire issue, he stated that I had nothing to worry about, and the greddy rs would be more than fine. But I was also curious on this matter as well, after seeing what happend to Luie.
Old Apr 19, 2008 | 01:34 PM
  #105
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Oh Yes alot different!.
As far as a meth mix I am always up for new things.
If blowing a plenum is a problem, then yes I guess you can say I had 1 issue.
Old Apr 19, 2008 | 02:04 PM
  #106
turismo's Avatar
turismo
How much are you guys paying for your methanol setups(no labor included) and what kits are you going with.
Old Apr 19, 2008 | 02:31 PM
  #107
eagletanggreen
Got Track!!!!!
The kit I am running is by Alkycontrol. PM Joe Kenefic put the kit together and with all the parts it around 600 to 700. Joe was the first with this kit, I then had Joe install mine , and I believe Alberto has had Sharif install his. I love it except blowing the plenum but I think that was just a freak ting???? I have gone thru 10 gallons thru my kit.
Luie
Old Apr 19, 2008 | 02:44 PM
  #108
turismo's Avatar
turismo
Luie
Thanx.
Old Apr 19, 2008 | 05:37 PM
  #109
DanielW's Avatar
DanielW
somebody should do a sticky Q & A Thread on meth injection.
Old Apr 19, 2008 | 06:07 PM
  #110
turismo's Avatar
turismo
+1
Old Apr 20, 2008 | 09:06 AM
  #111
dutchboy's Avatar
dutchboy
^ I wanted to run a 70meth/30water combo but sharif insisted that we do straight methanol. Curious to see how this set up will handle it. Has anyone had problems with running straight methanol yet?
I've been running straight meth since last October. I have not had any issues so far.
Old Apr 20, 2008 | 11:18 AM
  #112
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Isn't there a quite lengthy thread of Meth injection Already?
Old Apr 20, 2008 | 11:35 AM
  #113
D350Z10's Avatar
D350Z10
the methanol concept is so simple no need for a extra thread. Plain and simple it acts as a octane booster while also cooling. So you can run a leaner a/f and aggressive timing. Also its cheaper than race gas.
The best bang for the buck great kit is the snow performance kit, if anyone needs one pm me I have a direct supplier on those.
Old Apr 20, 2008 | 11:45 AM
  #114
Nexx's Avatar
Nexx
are there any possible issues you can run into running meth? how do you monitor your meth reservoir, is there a gauge or do you have to visually check it so often? what if you run out of meth while driving? damn im a noob but im curious.. we really do need a meth FAQ sticky.
Old Apr 20, 2008 | 11:47 AM
  #115
turismo's Avatar
turismo
There's no rust or anything on your parts?
Old Apr 20, 2008 | 11:53 AM
  #116
D350Z10's Avatar
D350Z10
A full tank of methanol will last me pry about 2-3 full tanks of gas. I monitor it manually, If you run out you are screwed... and your car can possibly detonate. Each kit comes with a control unit, mine for example acts together with haltech and comes on by it self. All I have to do is turn on the switch, and whe the meth spray's my green indicator light goes off.
Bottom line is always make sure you have enough methanol when running the car hard on your methanol map or else your screwed.
Old Apr 20, 2008 | 12:05 PM
  #117
GTM's Avatar
GTM
http://www.alcoholinjectionsystems.com/
Pretty good info there if you have a lot of (*basic) questions.
*edit
Old Apr 20, 2008 | 12:16 PM
  #118
eagletanggreen
Got Track!!!!!
AlkyControl FTW
http://www.alkycontrol.com/
Go to Facts and read!!!!!
Old Apr 20, 2008 | 02:11 PM
  #119
Shabib67's Avatar
Shabib67
The best Water/Alky setup is the Aqua Mist HFS-5. A lot of the suby and evo guys are using them and have had great success with them. Its probably one of the most advanced setups out there and has many great failsafe features and can run straight meth without corrosion problems.
Here is a FAQ link by Richard Lamb who works for Aquamist
http://forums.nasioc.com/forums/showthread.php?t=752282
Here is a link with the description of the unit.
http://www.iaperformance.com/product...oducts_id=2451
Old Apr 20, 2008 | 02:53 PM
  #120
rcdash's Avatar
rcdash
I believe the reason many run 50/50 is because that mixture isn't considered flammable. Stainless steel lines are not required so costs are lower. If everything is set up properly for 100% meth, it's fine, but I understand your hesitation. I would love to hear Sharif's insight with using 100% meth vs a mix and the potential for backfires. He must have a reason he prefers not to mix - perhaps the uncertainty of the mix with future fill ups? I don't have any experience with methanol, but I'd be worried about the fire hazard also.
