Eagletanggreen---> ForgedPerformance long term motor update<------
Old Apr 20, 2008 | 02:57 PM
  #121
rcdash's Avatar
rcdash
Originally Posted by D350Z10
A full tank of methanol will last me pry about 2-3 full tanks of gas. I monitor it manually, If you run out you are screwed... and your car can possibly detonate. Each kit comes with a control unit, mine for example acts together with haltech and comes on by it self. All I have to do is turn on the switch, and whe the meth spray's my green indicator light goes off.
Bottom line is always make sure you have enough methanol when running the car hard on your methanol map or else your screwed.
If your W/M kit has an output that triggers if there is a malfunction (or low tank condition), you could use it to kill your boost controller via a relay (for added safety). The Haltech's 32 input/output module will hoepfully be available soon so everything can be managed via software.
Old Apr 20, 2008 | 03:16 PM
  #122
GTM's Avatar
GTM
Vendor - Former Vendor
This is what I will be doing with my HFS-5, the HFS-5 has built in clog detection, so if something were to go wrong, it would switch back to the base map.
-George
GTM
P.S. Sorry for the severe O.T. louie
Old Apr 20, 2008 | 03:27 PM
  #123
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
-George
GTM
npr
Old Apr 20, 2008 | 04:19 PM
  #124
MardiGrasMax's Avatar
MardiGrasMax
You can run 50/50 water and denatured alky in your windshield washer resivior. Just plumb your systems pump pick up to that tank. If it runs low it will set off the low fluid dummy lamp on your dash. Its fine to use on the windshield too.
_bit
Oct 2, 2015 07:49 AM
