Procharger dyno #'s 7.8psi
Old Apr 22, 2008 | 05:55 PM
frankie945's Avatar
frankie945
Default Procharger dyno #'s 7.8psi
Running a 7 psi set-up got 7.8 out of it. The Meth really helped by safely gaining 21 whp and 11 ft-lbs torque. Which is a conservative tune is what I asked for but after driving it I loved the power and want more, so don't we all. So i'm going to go with the 10psi setup in a few weeks which I should have done to begin with. will post more results then.
[IMG][/IMG]
[IMG][/IMG]
Old Apr 22, 2008 | 06:08 PM
Weqster's Avatar
Weqster
what meth kit?
Old Apr 22, 2008 | 06:10 PM
frankie945's Avatar
frankie945
Originally Posted by Weqster
what meth kit?
Snow performance Stage II
Old Apr 22, 2008 | 06:13 PM
one1pitchblackz's Avatar
one1pitchblackz
Good numbers
Old Apr 22, 2008 | 06:17 PM
frankie945's Avatar
frankie945
Originally Posted by one1pitchblackz
Good numbers
Thanks. It's a start, not as much as expected but very pleased.
Old Jul 30, 2008 | 08:24 AM
jpc350z's Avatar
jpc350z
Any tuning between the runs , like removing timing? Looks like a before and after meth install...Any reason why the peak Tq comes about 750 RPM higher than the base peak Tq RPM? Also the A/F ratio drops around 5200 RPM bringing the Tq curve with it..Probably get a little more Tq if the ratio was a little more horizontial.Thanks
Old Jul 30, 2008 | 09:30 AM
frankie945's Avatar
frankie945
First run was with no meth added.#2 run was with the meth and the timming up high was advanced. Unless you are running high boost on a SC the tq curve goes down abit and you have to wait on. your power.Unlike the turbo. But with meth its mainly in the tune. I think when I was procharged I started sparing at 2psi. Know i'm turbo wanted more TQ getting 358whp # 388tqw off 7.2psi give or take.
Old Jul 30, 2008 | 09:42 AM
350Z400rwhp's Avatar
350Z400rwhp
Damn I didn't gain any power with my meth What solution are you using? Boost Juice?
Old Jul 30, 2008 | 10:00 AM
frankie945's Avatar
frankie945
It's all in the tune...
Old Jul 30, 2008 | 10:04 AM
GTM's Avatar
GTM
Vendor - Former Vendor
Meth alone won't add power, but it allows you to run more timing and a leaner afr, resulting in more power.
Congrats on the numbers, 10 PSI should be good, but when you want more boost is when you run into issues eating up belts, good luck!
-George
Old Jul 30, 2008 | 10:09 AM
350Z400rwhp
-George
Well when Sharif tuned my car we talked about advancing timing but decided against it for safety reasons. I still expected the reduction in intake temps to yield some power gains though.
frankie945's Avatar
frankie945
George I have already gone turbo gota love all that TQ, but miss the sound of the blower.
Old Jul 31, 2008 | 07:52 PM
tylerxfire's Avatar
tylerxfire
do you have any mods done to support the power or no.
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
