ATI Pro Charger News and Updates (to be ongoing)
Old Jul 24, 2003 | 07:49 AM
  #141
Paolo's Avatar
Paolo
Default 35 shot
I'm still searching for 35 jets myself. I am now running a 75 shot, and with the boost that I will be running, I will definately be downgrading the NOS. If anyone knows where I can get a 35 shot nozzle, let me know.
Old Jul 24, 2003 | 09:05 AM
  #142
Spencer@AAM's Avatar
Spencer@AAM
Originally posted by jesseenglish
Won't he lose some power though by dropping the CR?
On the low end yes. But if you try to throw 18psi at the stock 10.3:1 compression, internals are going to make noise and bend and do unpleasant things.
Not sure if ForcedInduction took the new CO into account with his figuring, but either way, 18psi is going to make a LOT of power.
The lower compression is important for FI applications running high boost. Stock 300zx TT compression is 8.5:1 where as the NA is 10.5:1. A shop in GA experimented with slapping a set of stock turbos on an NA block with no internal changes. The most they could muster with extensive tuning was 11psi with no detonation. I think they got 340rwhp on the 11psi. There are TTs out there running 25+ psi on stock internals (upgraded turbos, obviously).
Old Jul 24, 2003 | 11:15 AM
  #143
insider30's Avatar
insider30
Default MustGoFastR
If you take the supercharger belt off, will there still be extra fuel going to the engine from the other fuel pump that comes with the supercharger? If so, won't that make the engine run too rich?
Old Jul 24, 2003 | 12:53 PM
  #144
D_Nyholm's Avatar
D_Nyholm
THE FMU is controlled by boost pressure. It raises fuel pressure by a set amount by how much boost it "sees'.
Lets say you are running a 4:1 FMU, for every psi of boost, the fuel pressure is raised 4 psi (or is it the other way around?? )
I don't know what the setup is on the ATI Kit, but as far as I know, they are using a FMU type fuel management.
Old Jul 24, 2003 | 01:30 PM
  #145
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
just a little FYI....the VQ30DE (190hp) found in the nissan maxima from 95-01 has a 10:1 compression ratio and there are guys out there running 15psi (S/Cers and turbos) PLUS small shots of nitrous on the competely stock motor with no detonation. A while back a guy with a turbo maxima turned the boost up to 18psi before the motor popped.
The 15psi plus the small shot of juice (35hp I believe) adds up to ~420fwhp
The VQ35DE in the Z should be able to hold 14-15psi (intercooled) safely and probably put out over 500rwhp on the stock motor with no ill effects. This is all assuming that it is tuned correctly.
Old Jul 24, 2003 | 04:27 PM
  #146
12SecZ's Avatar
12SecZ
Thumbs up More progression pics (links to my website to save space)
First of all let me say that the guys at FFP are great. They are working in 100 degree heat and 30 % humidity and doing excellent work.
Second, I could kick myself in the head because I drove out there (45 minutes North) and forgot to take pics of the FMU. It is already done and mounted in the hidden gun compartment in the storage area behind the passenger seat. You did know there was a hidden compartment there right? Just kidding about the gun, I think people keep jewelery there or something anywayZ.
I will get a pic of everything when it's all done. My exhaust (Borla Header and true dual catback) go on tomorow and then they could be done tomorow depending on how much tuning is involved. Their Dyno is a beast it's called a load bearing Dyno and the hardware and software looks nothing like the Dyno Jet it's friggen amazing (and 15 thousand dollars.) On run 2 in 100 degree weather and humidity my car pulled 237 stock on their Dyno, he said you can add up to about 7HP from my baseline from Marco's in cooler weather (which was 242) but more importantly with my headers and exhaust he expects me to be adding more boost (new pulley soon) because of the low end loss. The car will take it no problem, I will probably run 9 PSI when all is said and done we shall see. He anticipates a 60 % gain from this setup above that stock number.
I'm trying something new a temporary profile highlight link to the 3 pics I took today all on one page. Hopefully it will work Comcast has been acting wierd lately.
http://home.comcast.net/~wegetourmai...ome.html-.html
Pretty cool eh? If I get my car back tomorow I will be estatic!
Edit typical and irritating typos.
Old Jul 24, 2003 | 05:17 PM
  #147
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Max: When they talk about changing the pulley to increase boost, which pulley are they referring to? Is it the one you see in your picture of the blower with the belt around it?
Old Jul 24, 2003 | 05:45 PM
  #148
jesseenglish's Avatar
jesseenglish
I'm getting a 9psi pulley also, but it's because I lose 2psi at my altitude. I'll more than likely also buy an 8psi and a 7psi pulley for when I move down in altitude. BTW, I finally ordered my SC and Borla true dual yesterday!!!!
Dr Bonz, yes, that's the pulley that gets changed out. Smaller for higher psi.
Old Jul 25, 2003 | 12:16 AM
  #149
Jason's Avatar
Jason
Okay, I'm not sure I understand the point of putting headers on a forced induction vehicle?
Headers are (if properly designed) intended to help scavenge exhaust gases. To the best of my understanding, this is not necissary with forced induction.
So, what's the deal?
Old Jul 25, 2003 | 02:34 AM
  #150
Jedi's Avatar
Jedi
I would think that anytime you help the car breathe, whether it be in or out, your decreasing resistance, air turbulence, which usually, not always, increases HP.
Old Jul 25, 2003 | 04:15 AM
  #151
sojourn's Avatar
sojourn
If there is a bit of overlap (intake and exhaust values open at same time), and you're intake it under pressure it probably won't make a lot of difference as the clean air is going to blow right though anyway. If the over lap is minimal or nonexistent, the fact that you're running FI doesn't matter. There won't be anything "pushing" out the exhaust gasses, so a header would help just as much FI or NA.
PS Most NA cars have over lap i believe. I think the low pressure wave of the escaping exhaust gasses help pull in the fresh air.
Old Jul 25, 2003 | 06:25 AM
  #152
Spencer@AAM
Default Finally...Procharger Dyno Sheet!!
OK guys, here it is. I finally got a copy of Mike's initial dyno from the ATI procharger install! Keep in mind this is UNTUNED with no adjustments. You can see between 80-100mph that the A/F richens up quite a bit and you can see the corresponding power dip. Once Mike leans it out some in that range it will gain that power back.
One thing to notice is how smooooth the power curve is. The power comes on early and stays linear all the way to redline!
Hopefully Mike will get to tune it in the next week or so. He wants to take it to the strip before he tunes it to get some initial time slips to show as well.
here it is...
Old Jul 25, 2003 | 06:30 AM
  #153
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Default Re: Finally...Procharger Dyno Sheet!!
[QUOTE]Originally posted by Spencer@AAM
[B]OK guys, here it is. I finally got a copy of Mike's initial dyno from the ATI procharger install! Keep in mind this is UNTUNED with no adjustments.
That is incredible!!! Keep it coming!!!
Old Jul 25, 2003 | 08:30 AM
  #154
DefBringer's Avatar
DefBringer
What are you guys doing for fuel management and boost control?
I don't know what an FPU is.
Does the stock fuel system work ok with the boost?
I've tried reading through 8 pages of this thread and nobody has explained it.
Old Jul 25, 2003 | 09:00 AM
  #155
MilleniumZ03's Avatar
MilleniumZ03
Those results are awesome with no tuning! And this is rwhp right? What kind of 1/4 mile times do you think this wil be capable of once tuned and all?
Old Jul 25, 2003 | 09:24 AM
  #156
elektrik_juggernaut's Avatar
elektrik_juggernaut
Fuel management is being taken care of by the FMU(Fuel Management Unit) which is basically a controller and an additional fuel pump. It senses boost and dumps extra fuel into the injectors. Boost control is done with the pulley. The ATI set-up comes with a 7psi pulley. From what we've seen so far, the stock injectors appear to be okay with the additional fuel.
Thanks for the dyno sheet Spencer. Those are pretty amazing numbers for a set-up just straight out of the box. Do you guys sell tires at Altered Atmosphere? I really think Mike's employee discount is gonna come in handy for him if you do.
Old Jul 25, 2003 | 12:01 PM
  #157
Buub's Avatar
Buub
That looks like crank horsepower to me. I doubt the ProCharger is giving 110 to 120HP (stock rwhp generally seems to run 230~235).
Old Jul 25, 2003 | 12:03 PM
  #158
ravaz's Avatar
ravaz
Nah, that's at the wheels..
Old Jul 25, 2003 | 12:04 PM
  #159
zpeed350's Avatar
zpeed350
Jeez, that thing looks HUGE!! Bwahahaha!!!
Old Jul 25, 2003 | 12:24 PM
  #160
djbit's Avatar
djbit
M killer, finally!
I can't wait to do this next year.
