Forced Induction for Noobs....
Old Mar 28, 2009 | 03:24 PM
  #241
toni350z's Avatar
toni350z
great post!! thanks! i read all!!
Old Mar 28, 2009 | 05:47 PM
  #242
SlideFox's Avatar
SlideFox
Originally Posted by gennosuke1
YES
Originally Posted by Frequency 3.5.0
+2
http://auto.howstuffworks.com/supercharger2.htm
http://auto.howstuffworks.com/supercharger3.htm
http://auto.howstuffworks.com/supercharger4.htm
http://auto.howstuffworks.com/supercharger.htm
Old Mar 31, 2009 | 08:56 AM
  #243
sik350's Avatar
sik350
Yes im a newb! i just bought a greddy tt with the 20g turbos looking to push around 550. i have a built long block ,but my question is what clutches do you recommend for my setup? I would want something i could eventually pass 600. Would i really need to upgrade my flywheel or would the stock work just fine? Im going to buy 650 injectors and a utec for starters. Would it be a good idea to go ahead and get a return fuel system or will my stock system with 650 get me at 550hp? also what are some reasonable price on decent axles for 600? What size fuel pump would work on my setup as well? sorry for so many questions but i am a newb! Thanks in advance for the recommendations!!!
Old Mar 31, 2009 | 02:58 PM
  #244
SlideFox's Avatar
SlideFox
For clutches, I would look into RPS or Carbonetic, especially if you are looking to get 600whp out of it. 650cc injectors are good to start out with, but I would ditch the UTEC for a standalone. I would look at Haltech, F-Con V-Pro, or ProEFI. I HIGHLY recommend a full return fuel system, and maybe even a twin pump setup. If you can afford it, it's always better to bigger at the beginning. As for axles, I would look at the DSS Pro Series. I know a few people running these, and have nothing but good things to say. Those people also happen to be pushing 800+whp, and some over 1,000.
Old Mar 31, 2009 | 04:47 PM
  #245
sik350's Avatar
sik350
Thanks slidefox! good info!!! Do you think its ok to run a stock flywheel or get a light weight fw? So a stage 5 Rps should do for now? Whats the difference in sprung and unsprung that RPS sales?
Old Mar 31, 2009 | 06:16 PM
  #246
thom000001's Avatar
thom000001
If you don't plan to pass 650rwhp, DXD Southbend has a cheaper alternative to the multi-disk clutches. They offer some pretty slick hp grabbing clutches.......but if you plan to surpas 650rwhp you are going to have to go to one of the multi-disk setups.
If you go with most of the multi-disk clutches they come with a lwfw. Its better mating material to the material used for the clutches.
If you go with the dxd southbend alternative, stock flywheel is fine.
Just another option.
Tom
Old Mar 31, 2009 | 06:57 PM
  #247
SlideFox's Avatar
SlideFox
^^ I couldn't remember what you were running Tom..
Old Apr 29, 2009 | 09:44 PM
  #248
ssaya401's Avatar
ssaya401
I am a noob but not new to the internet. This is my first post and I spent 3 hours looking for this thread through various sites. Thank you very much, as just lurking my way through random threads gives tons of different, biased opinions, plus some of the posts are 4-5 years old.
Old Apr 30, 2009 | 06:11 AM
  #249
SlideFox's Avatar
SlideFox
^^Your Welcome!
Old May 22, 2009 | 10:09 AM
  #250
toni350z's Avatar
toni350z
i just buy the turbonetics kit, but i have the stock block and i dont have more money for another block... i buy too innovate control AFR and over boost control, the kit said that the max power its 8 PSI, but i see that the people have this kit for 9 PSI o more, what is the maxium PSI that this engine suport and if its necesary to buy another parts for the live of my engine...??? thanks!!
Old May 22, 2009 | 10:28 AM
  #251
INTENSEPOWER's Avatar
INTENSEPOWER
Vendor - Former Vendor
Congrats on your purchase.
I as well as MANY others have run that kit on a stock block at well over 10psi. That being said, the piping and turbo of that kit are pretty inefficient so the best advice is to run it on wastegate spring pressure only. At 8psi, you will make ~380whp, which is basically what the 380cc injectors for the kit will be good for. This is a good kit for stock motor if you respect the idea of just running the kit on spring pressure and don't get boost greedy. Be happy with ~380whp and when you get bored with that, sell the kit, build a motor on the side, and buy a more efficient kit that supports higher horsepower goals (GReddy/PowerLab, etc). Hope this helps.
Darren
Old May 22, 2009 | 11:02 AM
  #252
toni350z's Avatar
toni350z
thanks! but if i choose to put on more PSI, because i want 400hp, i need to change the injectors? i think in install too the APS oil pan and some good liquid for to refresh the engine oil.... Next week i will go my car to the mechanic for install this, im very excited!!
Old May 22, 2009 | 11:27 AM
  #253
SlideFox's Avatar
SlideFox
My recommendation is to let the kit make whatever power it is going to make. If you chase a certain HP number, you can push to hard to achieve that number. That could lead to costly engine repairs.
As Darren stated above, install it and tune it to spring pressure only, and have some fun. Either way you will be happy!!
Old May 22, 2009 | 11:58 AM
  #254
toni350z's Avatar
toni350z
ok, thanks! when i finish this proyect i will up the dyno here for i see yours coments
Old May 25, 2009 | 01:09 PM
  #255
toni350z's Avatar
toni350z
i have another question for some persons that they have to install a turbonetics kit... i bought the turbonetics kit without catalyst, and i dont know if i have to modificate the exhaust stock, i need to remove the y-pipe? i dont know if the turbokit pipes go direct to the intermediate exhaust... i need help!! hope to hear your advice...thank you.
Old May 25, 2009 | 08:26 PM
  #256
INTENSEPOWER
If I understand you correctly, you purchased the kit that doesn't include the high-flow cats, correct? If that's the case, this kit will not retain your Nissan OEM catalytic converters, nor your Nissan OEM y-pipe. Technically, you can use your Nissan OEM rear section of your exhaust (the rear section/muffler section). If you want an aftermarket rear section exhaust rather than the Nissan one, there's plenty that are compatible, including:
Apexi WS2
Fujitsubo
JiC Type 1 Single tip(all materials: stainess, stainless/Ti, Ti)
JiC Type 2 Dual tip (all materials)
AAM single
GReddy TiC
I'm sure I've missed a couple, but this should get you headed in the right direction. By the way, these exhausts work with any of the single turbo kits on the market that replace the piping in the front of the exhaust (PowerLab, etc).
Darren
Old May 26, 2009 | 02:00 AM
  #257
toni350z's Avatar
toni350z
thanks Darren, arready my kit its in his box... i have the rear seccion aftermarket now to 3", then i will search the final exahust for have the 3" in all to the finish,
Old May 31, 2009 | 03:08 PM
  #258
dkuvila's Avatar
dkuvila
thats really helpful but which type of lsd do people usually go with. the 1.5 or the 2.0 and why? tnx
Old Jun 1, 2009 | 08:37 AM
  #259
SlideFox's Avatar
SlideFox
It really all depends on the application...
FYI, that is not a forced induction question.
Old Jun 1, 2009 | 05:56 PM
  #260
xtrmspd's Avatar
xtrmspd
Hence the "they are still noobs" you mentioned in the beginning.
