APS TT Air Filters - Pre Filters?
Old Jun 2, 2008 | 11:29 AM
Abishop's Avatar
Abishop
Default APS TT Air Filters - Pre Filters?
Since my car has a new body kit, my drivers side filter is open to the air. Which is good and bad. At the last local meet, one of the members suggested i get a pre filter that also repels water ( on certain times i have to drive home on a damp night, I would never drive in the rain.)
http://www.injen.com/docs/products/listing.asp?pcc=rp
I have a couple questions
1. What size are the APS TT air filters?
2. Has any one used a pre filter before?
3. From the Injen Link provided above, what size would i need?
4. Is there any other suggestions?
A picture for reference is added.
Attached Thumbnails APS TT Air Filters - Pre Filters?-0520081257-01.jpg   APS TT Air Filters - Pre Filters?-dsc08017.jpg   APS TT Air Filters - Pre Filters?-dsc00014re.jpg
Old Jun 2, 2008 | 05:10 PM
Zivman's Avatar
Zivman
the prefilter is just some sort of nylon sock that covers the intake. IMHO you are no safer with or without.
If you have concerns, get some mesh to fill the hole so the bigger debris doesn't hit the filter
Old Jun 2, 2008 | 09:15 PM
Abishop's Avatar
Abishop
^ even if it repels water?
Old Jun 2, 2008 | 09:21 PM
Crom's Avatar
Crom
There was a thread on here a while back w/ the KN equiv...I think the choices were 34XX or 28XX somethin...I chose the wrong one and they did not fit.
Old Jun 3, 2008 | 05:05 AM
Zivman's Avatar
Zivman
What do you care if it 'repels' water? You are only in danger if the filter is submerged and allowed to suck water into the motor. Sock or no sock, it won't matter at that point.
Old Jun 3, 2008 | 05:07 AM
rcdash's Avatar
rcdash
+1. Zivman on the ball, as usual. This is a marketing gimmick.
Old Jun 3, 2008 | 01:15 PM
Abishop's Avatar
Abishop
ok, so even in a heavy rainstorm i shouldn't expect this to hurt my motor?
Old Jun 3, 2008 | 01:22 PM
Zivman's Avatar
Zivman
no more than with a stock bumper. you really only have to be concerned about having the filter be submerged
Old Jun 3, 2008 | 04:30 PM
Abishop's Avatar
Abishop
^ wow, i would have figured it would be bad to get any water at all on the filter. Thanks for the info.
Old Jun 3, 2008 | 05:48 PM
rcdash's Avatar
rcdash
water injection pumps a fine mist directly into the intake charge. trust me, it's not going to be anywhere close to that quantity in a rainstorm. as long as you don't hydrolock (submerge the filter in water), you'll be fine.
Old Jun 3, 2008 | 06:02 PM
Blackbird CPV35's Avatar
Blackbird CPV35
back when i had my turbo ka 240, if i drove in a heavy enough rainstorm then water would hit the mafs causing it to max out. However that was not a blow through setup, with our setups the water would have to go through the turbo and intercooler, at which point it would probably be vaporized
Old Jun 3, 2008 | 06:05 PM
35Z's Avatar
35Z
Thumbs up K & N Airforce Pre-Cleaner
This K&N pre-cleaner is specifally designed foam filter wrap made for dusty conditions (i.e off-road). Its not designed for water dispersement... AEM makes a water by-pass for this purpose. Alternatively, fab up a water diverter on the intake opening.
Old Jun 3, 2008 | 08:11 PM
Abishop's Avatar
Abishop
^ i was thinking about taking a roll of bule tape with me and when it looks like rain, covering the hole up to get it home.
Old Jun 3, 2008 | 08:45 PM
Zivman's Avatar
Zivman
just let it go... is blue tape going to make the compartment water tight.? If you run through a 'puddle' deep enough to submerge the filter I don't think a hydrolocked motor is your first concern
Old Jun 4, 2008 | 11:14 AM
Abishop's Avatar
Abishop
^ true, but would it hurt to cover it?
Old Jun 4, 2008 | 11:20 AM
Zivman's Avatar
Zivman
asethically, yes it would....
would it be fine if you just did nothing and didn't waste time, money, or blue tape? Yes
Old Jun 4, 2008 | 05:09 PM
Abishop's Avatar
Abishop
ok. thanks for the advice ziv.
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
