Greddy Oil Seals Leaking????
Old Jun 15, 2008 | 08:24 PM
JETPILOT's Avatar
JETPILOT
Default Greddy Oil Seals Leaking????
Comming off WOT I'm getting some smoke out my exhaust. I only have about 3000mi on the Greddy kit. The smoke doesn't happen every time. Maybe 1 out of 10 times. Any ideas?
Old Jun 15, 2008 | 08:30 PM
Nexx's Avatar
Nexx
smoke color? if its just coming out when you get off the gas from WOT, its normal.
Old Jun 15, 2008 | 08:36 PM
JETPILOT's Avatar
JETPILOT
My windows are tinted and it's hard to tell, but just from the comming off WOT symptom I'm assuming it's the turbo seal. But after only 3000 mi? Is everyone getting this once in a while?
Old Jun 15, 2008 | 08:39 PM
westpak's Avatar
westpak
SFZCC
I do and at more times as well, I am wondering if the synthetic oil is too thin for the turbo seals, they are not the most sophisticated seals and can see how thin oil would get past them
Old Jun 15, 2008 | 08:42 PM
Barzten1's Avatar
Barzten1
mine does it too every so often and usually when I come to a stop.
Old Jun 15, 2008 | 08:43 PM
JETPILOT's Avatar
JETPILOT
It's strange it only happens sometimes. I am using MOTUL 300V 5W30. I think I will try their 15W50.
Old Jun 15, 2008 | 09:45 PM
wannabuy350z's Avatar
wannabuy350z
^ I use 15/50 mobil1 and i dont have that problem. your oil is too thin, and at wot oil will pass through seals. shouldnt much smoke.
Old Jun 16, 2008 | 08:59 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Give the slightly thicker weight oils a try. Motul 300c 10/40 or 15/50
I havent seen a bad OEM greddy turbo yet.
Old Jun 16, 2008 | 09:42 AM
D350Z10's Avatar
D350Z10
ITS NOT THE SEALS, I had a long talk with a tech from Forced Performance and he stated that the seals on a turbo work alot different (real hard to explain call yourself and listen). If your turbo has play and the wheel it self is hitting the housing... get your turbo out of there and rebuild it.
There is to much bull chit on this forum that clouds peoples minds.
Old Jun 16, 2008 | 10:37 AM
rcdash's Avatar
rcdash
I've been doing a lot of reading on turbo seals recently. I had my PCV valve get blocked and my car turned into the space shuttle. I feared the worst but things are looking better after a few trial runs... (many thanks to Sharif for diagnosing the problem remotely and holding my hand as I worked through this issue).
It is now my understanding that as Dil states, turbo seals are designed differently than you might think. And in fact, they generally work in tandem with compressor and turbine pressures to keep oil contained.
Refer to this troubleshooting chart:
http://www.jhdiesel.com/failurechart1.htm
Anything that disturbs the balance of air flow or oil flow may cause turbos to "spill" oil. The good news is that if you can correct the underlying problem, in many circumstances, the oil leaks will stop.
That said, you may need to do some cleaning of the IC, piping etc. if you've been running "out of balance" for some time - otherwise you'll continue to have spurts where pooled oil in the piping is ingested into the engine every so often.
One other issue to think about is where crankcase vapors are going under boost and at idle... If you truly want to keep oil out of the intake system, it takes some careful planning, or there may be short periods where the car is indeed run "out of balance", resulting in transient oil leaks.
EDIT: And oh yes, I was running 10W-40 and am now switching to Motul 15/50 for the summer...
EDIT#2: Here's a cutaway pic of a turbo...
Old Jul 24, 2008 | 01:04 PM
turbotoy's Avatar
turbotoy
I had a similar problem on my Toyota and it ended up being a broke ring.
Old Aug 4, 2008 | 10:26 PM
jmcmorante's Avatar
jmcmorante
I'm having the same problem. When I come out of WOT or anything close to WOT I get smoke just like you. Occasionally when I start the car for the first time in the mornings, when its warming up, I notice it smoke at idle also for the first couple of minutes while the car is at idle warming up.
I had this problem very slightly but it has increased within the last 3-4 months I think. After my last oil change a couple of weeks ago it got a little worse (the smoke that is).
Do you get any strong exhaust (fume like) odor as well? I do.
Let us know what you do to resolve this. Good Luck JETPILOT! Hopefully you resolve the situation.
Old Aug 4, 2008 | 10:45 PM
overZealous1's Avatar
overZealous1
had about 15k on my turbos before rebuild, they never smoked. new seals now, and still no smoke. there have been a few times though that i got my oil so hot (water temps were at 280!) and i was getting some smoke, but that was the only time and condition.
i would just try thicker oil to start with.
Old Aug 5, 2008 | 05:52 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
run some thicker oil...
Old Aug 5, 2008 | 06:04 AM
rcdash's Avatar
rcdash
And clean out your IC piping (check the manifold to see if oil is collected there). You may continue to smoke if you have oil pooled...
Old Aug 5, 2008 | 08:40 PM
boostedmaxima's Avatar
boostedmaxima
Depending on the turbo, a restrictor might be needed. I had a brand new turbo on my car and the car was smoking when in boost, there was also after about 3 weeks 2-3 teaspoons of oil that collected in the coupler elbow before the ic piping. Got an oil restrictor for the feed, and no more leaks. If the turbo is a bb, it more than likely could use a restrictor.
http://forums.maxima.org/supercharge...estrictor.html
Old Sep 7, 2008 | 05:58 AM
jtgli's Avatar
jtgli
Im running royal purple 15-40. I used to run mobile 1 10-30 but after I switched to the royal purple I found last weekend my car smoked for a bout 30 seconds then went away. Now last night after getting on it a few times it smoked for a few minutes only out of the drivers bank. I then turn it off and turn it back on, nothing. Could this be that royal purple is too thin? Or is it something that I should check compression for a piston ring, or is it maybe a turbo seal?
Old Sep 7, 2008 | 06:05 AM
doug's Avatar
doug
it might be your oil... mine started doing this after i switched to Rotella T Sync 5w40 .. i'm thinking about switching.. but i just changed my oil last sunday.. not even 100 miles on it
Old Sep 7, 2008 | 06:12 AM
jtgli's Avatar
jtgli
My royal purple has been in for about 3 weeks now. Its just weird how it started for only 30 seconds then nothing for a week, then last night it does it fora minute then nothing.
Old Sep 7, 2008 | 07:17 AM
jtgli's Avatar
jtgli
anyone?
