Anyone have a Camp2 up and running?
Old Aug 18, 2008 | 09:14 PM
  #41
terrycs's Avatar
terrycs
Originally Posted by fstrnldr
actually you are wrong, the Camp system will display all OBDII sensors w/ or w/ out the FCON. It will also display any sensors connected through the IF port, which for those that have never used this is most of your aftermarket sensors, EGT, Map, Oil Temp/Pressure, Fuel Pressure, I know there is a couple more, but i don't remember them off the top of my head. Biggest advantage to having it coupled w/ the FCON products besides the map switching is that you can save some money on sensors, for instance if you have a Map sensor plugged into the FCON, you can read that through the Camp rather than needing one for the IF unit as well.
You're absolutely right ... CAMP2 goes direct to OBD II port for the data. Thanks for correcting me.
Without F-Con iS OBD II plug connected to OBD II port, the manual says you can't get A/F, A/F correction, A/F learn, and knock ... now I'm confused. Maybe time to take my car apart and see how they did it.
Old Aug 19, 2008 | 06:41 AM
  #42
fstrnldr's Avatar
fstrnldr
that is correct, the camp2 has no input for the a/f gauge. Especially if you are running something like the Innovate LC1, then you will have to have the FCON to translate the signal into something that can be displayed. I could see that being possible in the future, but for now i'm sure they are still trying to sell their a/f knock amp, and this would compete w/ it.
Old Aug 25, 2008 | 11:56 AM
  #43
Crom's Avatar
Crom
As soon as somebody gets the map switching working...keep us posted.
Old Aug 25, 2008 | 12:12 PM
  #44
XKR's Avatar
XKR
FO Sur
Old Aug 26, 2008 | 03:20 PM
  #45
ADMAN's Avatar
ADMAN
Group Buy???
Old Aug 28, 2008 | 09:10 AM
  #46
chopperman's Avatar
chopperman
Originally Posted by ADMAN
Group Buy???
I would like
Old Nov 6, 2009 | 10:45 AM
  #47
IslandZavage's Avatar
IslandZavage
Did anyone ever figure out if its possible to change maps through the Camp2 screen?
Old Nov 6, 2009 | 11:31 AM
  #48
Kwame's Avatar
Kwame
^It does not allow for that.
Old Nov 6, 2009 | 11:36 AM
  #49
ttg35fort's Avatar
ttg35fort
Professional
If someone has the latest rev of the F-CON, it does not work with the Navigator Pro.
How are they supposed to change maps?
Old Nov 6, 2009 | 11:51 AM
  #50
Kwame's Avatar
Kwame
^ Go back to your tuner I assume.
Old Nov 7, 2009 | 11:41 AM
  #51
Crom's Avatar
Crom
The camp2 map changing functionality only works w/ the iS flavor of the F-con.
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
