Powerlab 37r install begins tonight..
Old Aug 22, 2008 | 08:57 AM
  #61
tig488's Avatar
tig488
just get a 4 to 3 reducer coupler, come straight out thru the hole in the support, use a bent pipe with a filter on it, easy.
Old Aug 22, 2008 | 08:58 AM
  #62
SlideFox's Avatar
SlideFox
Steel Mesh?
Old Aug 22, 2008 | 09:03 AM
  #63
tig488's Avatar
tig488
no, that doesnt stop dust and small debris from getting in there, just rocks and birds.
Old Aug 22, 2008 | 09:09 AM
  #64
SnyperZ's Avatar
SnyperZ
I ran my t67 wide open for 2years with no issue...even without a screen. Im mostlikely going to make some room to fit a 4" pipe. Im not going to reduce it down to 3"..that would defeat the purpose of doing the 37 with the 4" inlet.
Old Aug 22, 2008 | 09:14 AM
  #65
SlideFox's Avatar
SlideFox
Get one of those 8" flat strainers from Wal-Mart, and bend it over the edge of the 4" inlet and use a hose clamp!!
Old Aug 22, 2008 | 09:17 AM
  #66
rcdash's Avatar
rcdash
Hey that's an easy fix and better than nothing for sure! Powerlab should at least provide this to prevent large insects and debris from getting in. A couple layers of steel mesh will provide most of the protection you need.
Old Aug 22, 2008 | 09:21 AM
  #67
thawk408's Avatar
thawk408
No it won't defeat the purpose. The main purpose of the 4inch is to have the anti-surge. A 4 to 3 reducer with a filter will provide that turbo with plenty of air.
Old Aug 22, 2008 | 10:26 AM
  #68
350 Rookie's Avatar
350 Rookie
I
Also, no matter what I tried to do..I could not get the AC line to snap in under the windshield.
dude, tell me about it. i tried to take that line out too from there and it was amost impossible for that one line.
Old Aug 22, 2008 | 10:42 AM
  #69
Peteski's Avatar
Peteski
I dont know why I come to threads like this one, just makes me want to spend more money than I have. Very Nice!!
Old Aug 22, 2008 | 10:43 AM
  #70
SnyperZ's Avatar
SnyperZ
I got it out, cant get the new one in...it wont "snap" into place.
Old Aug 22, 2008 | 10:45 AM
  #71
SnyperZ's Avatar
SnyperZ
mine didnt come with an anti surge housing..according to Han..my turbo is a t3 gt35r modified to make it a 37r..larger wheels I think?But the part number on the center section is that of a 35r.
Old Aug 22, 2008 | 10:47 AM
  #72
SnyperZ's Avatar
SnyperZ
Originally Posted by str8dum1
Can you take close up pics of how the bumper brace sits over the IC. Or how much you have to notch it to fit.
Thanks!
Im going to cut that tonight..along with trimming the bumper itself a little on the bottom edges. One thing though..I did have to cut/bend alot of headlight brackets inorder for the intercooler pipes to fit..I gouged the hell out of it.
Old Aug 22, 2008 | 11:04 AM
  #73
SlideFox's Avatar
SlideFox
Headlight brackets? I've never seen any have to do that before....
Old Aug 22, 2008 | 11:07 AM
  #74
SnyperZ's Avatar
SnyperZ
yeah the pipe would not fit between the the frame and that blackmetal brace. I gouged the pipe pretty bad..good thing you cant see it haha. I had to do it on both sides actually.
Old Aug 22, 2008 | 11:08 AM
  #75
denverinfiniti's Avatar
denverinfiniti
As far as your AC line goes. Make sure the spring is inside the fitting. Its what locks the new line in. If thats gone it'll never click. I had a brand new FX here at work that came in with the line apart and the spring was missing.
Old Aug 22, 2008 | 11:09 AM
  #76
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by rcdash
There's no air filter on this kit? At all? I would check out siliconeintakes.com and see if you can squeeze something on... Even if you use a reducer to squeeze through, I doubt for a short length it will have any impact on performance.
That looks like waaaay to much work. Kudos man. And good luck with the rest.
PS. My guess for the heater hose is for driver's side CCV hook up to air inlet? (that's a wild guess)
Hey raj
the kit does come witha nice green filter.... but this is a gt37r version... so it doesnt fit, unless you start "bastardizing" the radiator support. I doubt he will have any trouble but he can alwasy add a screen on the turbo too.
OH well, just get some damm videos already Mark.!
Old Aug 22, 2008 | 11:14 AM
  #77
SnyperZ's Avatar
SnyperZ
Yeah the spring is in there..its strange.
Old Aug 22, 2008 | 01:21 PM
  #78
thawk408's Avatar
thawk408
Either way, a 4 to 3 will be fine for that turbo.
Old Aug 23, 2008 | 07:13 AM
  #79
SnyperZ's Avatar
SnyperZ
Here ya go..REALLY quick video of the start up.
Old Aug 23, 2008 | 10:11 AM
  #80
UMW350Z's Avatar
UMW350Z
lordy that is a big turbo
