Powerlab 37r install begins tonight..
Old Aug 27, 2008 | 11:00 AM
  #161
SnyperZ's Avatar
SnyperZ
My car does seem to have an idle issue..it idles pretty low. Its stalled out twice while drive around town coming to a quick stop.
Old Aug 27, 2008 | 11:11 AM
  #162
4SHIZZIL's Avatar
4SHIZZIL
Originally Posted by SnyperZ
no its surge. I can feel it come out of the compressor with my hand..also it keeps blowing the nylon screen off the front of the opening. That thing should never come off unless air was coming out the other way. Also, the tial 50mm on my trans am would open up wide as soon as you started the car...this car doesnt pull enough vacuum to open the 12 and 11psi springs..tial actually rates different springs for different hgs..my car pulls 17.9 at idle which is set for the 9lbs spring.....the BOV is on its own vacuum line.
isnt there a hole in the throttle body on most V8 fuel injected performance engines...? that small hole does wonders for boosted VQ idles... I seen it done.... but you cant do it on an NA car... dash will become a christmas tree!
Old Aug 27, 2008 | 11:13 AM
  #163
4SHIZZIL's Avatar
4SHIZZIL
sorry the pic is so big.... lol!
Old Aug 27, 2008 | 11:37 AM
  #164
SnyperZ's Avatar
SnyperZ
Yeah like with LS1s. Some aftermarket tbs for those cars dont have the hole and idle like sh*t. After you drill one it solves the problem. Why do you say it wouldnt throw a light with FI?
Old Aug 27, 2008 | 11:39 AM
  #165
Driver06's Avatar
Driver06
Probably going to have to get someone to bump the idle a bit. you usually have to do that. dealer can do that. or anyone with the software
Old Aug 27, 2008 | 04:42 PM
  #166
jeffie7's Avatar
jeffie7
Dave bumped my idle up, sounded like a very common thing to do.
Tell me more about the blow off valve issue, who provided you with a new spring?
Old Aug 27, 2008 | 08:41 PM
  #167
SnyperZ's Avatar
SnyperZ
A friend of mine. And I dont care what anyone says about it being ok..thats not how it was designed to work. Its not supposed to flutter at all..either be open or closed with one solid release sound. Also at idle the valve should be fully open..not half way nor should it need an abrubt decel to "flutter" (the flutters your hearing is the excess boost trying to get out..its supposed to come easy) and when it flutters some air goes back out the turbo.
Im going to try the 9psi spring..and if it doesnt work fully(which it should drastically cut down at least..) then im going to step down to the 7psi spring which I know will work.
Old Aug 27, 2008 | 10:33 PM
  #168
wannabuy350z's Avatar
wannabuy350z
Idle should be at 850, mine sits at 680. dealer for $75
Old Aug 28, 2008 | 06:34 AM
  #169
IIQuickSilverII's Avatar
IIQuickSilverII
mark do as you please either way you will be fine
Are you gonig to bump your idle btw?
Old Aug 28, 2008 | 08:03 AM
  #170
UMW350Z's Avatar
UMW350Z
When the car is off, the BOV is closed, right? So when iding it is open and you should feel air coming out of the valve ?????
I think i almost understand this...the spring is set to push the bov open at the pressure the spring is loaded for...(ex:a 7 psi spring open the bov at 7 psi or greater)...so at idle the bov is closed? so if the spring is too light, it will bleed off charge air under hard loads since the spring is optimized for a certain pressure range? the 7 or 9 lb spring is good for low boost apps, but the 11 is good for high boost apps....am i correct here?
so if you run 9 psi of boost, that BOV with a 7 psi spring will open up some?
Just trying to grasp the concept fully here...
Old Aug 28, 2008 | 08:12 AM
  #171
SnyperZ's Avatar
SnyperZ
Yes when the car is off theres no vacuum to compress the spring and open the valve. And no like I said in the other post..if your running 20psi..you have 20 psi pushing up on the valve(trying to open it)...however your vacuum line that holds the valve open turns into a boost line when you go into boost. So if your pushing 20psi..you have 20psi of pressure(not vacuum) going through that line now pushing down on the valve...if there were no spring..the valve would leak because there would be 20psi trying to push it open and 20 trying to close it..but you have that extra 7lbs of pressure from the spring ALSO pushing down on the valve and THATS what keeps it closed.
Old Aug 28, 2008 | 08:18 AM
  #172
SnyperZ's Avatar
SnyperZ
Oh, dont take it the wrong way please..im not saying your wrong..im just saying the TIAL was desiged to open smoothly...not flutter at all. IMHO Tial 50mm is the best bov on the market and when its setup the RIGHT WAY is unbeatable. Its funny how sync. will say theres is faster..thats because they rigged the test. A tial with the wrong spring sucks and will be sluggish and not work...but thats why they make different springs..if you watch youtube..you can find how one works with the RIGHT spring.
Old Aug 28, 2008 | 09:26 AM
  #173
IIQuickSilverII
its all good...
lets get this thread to go to page 10 so i dont have to see that big *** picture posted by 4SHIZZIL lol
Old Aug 28, 2008 | 09:28 AM
  #174
SlideFox's Avatar
SlideFox
HAHAHA
  #175
SnyperZ's Avatar
SnyperZ
Its only on page 4 for me. =P
Old Aug 28, 2008 | 09:33 AM
  #176
Jay'Z's Avatar
Jay'Z
Me too..
Old Aug 28, 2008 | 09:34 AM
  #177
SlideFox's Avatar
SlideFox
I'm with Jorge.. THis is Pageg #9 for me... I guess it depends on the layout you have in your User CP
Old Aug 28, 2008 | 09:37 AM
  #178
rrmedicx's Avatar
rrmedicx
Bump for new page. Thanks 4Shizzel...LOL
Old Aug 28, 2008 | 09:40 AM
  #179
SnyperZ's Avatar
SnyperZ
Yeah I set it to 50 posts per page I think.Makes it easier to find things.
Old Aug 28, 2008 | 09:44 AM
  #180
UMW350Z's Avatar
UMW350Z
bummpp
