Guys i need some help(desperate)
Old Sep 7, 2008 | 02:54 PM
KPierson's Avatar
KPierson
Old Sep 7, 2008 | 02:55 PM
KPierson's Avatar
KPierson
If you don't have a meter just try replacing this fuse with another fuse that isn't required to get the car to start (like a power window fuse or a head light fuse).
Old Sep 7, 2008 | 04:01 PM
GTM's Avatar
GTM
Vendor - Former Vendor
Have you tried removing the HKS DLI II? If it got damaged it could not be letting the coils fire, although unlikely.
Electrical problems suck, I hope you didn't fry the ECU or IPDM, that would suck
As Hal stated it sounds like your ECU either isn't getting power, or is fried.
Good luck
Old Sep 7, 2008 | 05:30 PM
rcdash's Avatar
rcdash
Hey Kevin, I'm pretty sure "superchargedg" has a "G".
Mine is a 2004.5 5AT G and the attachment is from my manual (specifically for the mid year change). You really need to check the PG.PDF document for your model year superchargedg.
Based on what I see I would check the ECM relay and fuse (#77 in the IPDM). If that fuse and relay is working, then the ECM is getting power.
File Type: pdf
Old Sep 7, 2008 | 05:35 PM
Jay'Z's Avatar
Jay'Z
Try undoing the battery a few hours and attach it back.. Hope ur ecu isnt fried..
BTW any codes? Can you turn to the on position? I hope you just need a ecu reset.. You may have thrown a code when you messed with that wire..
Old Sep 7, 2008 | 05:38 PM
Dynosty's Avatar
Dynosty
That is another option to verify if it is a fuse issue... check the power wires going into the ECU. If they are +12v, then you have an ECU problem.
Old Sep 8, 2008 | 02:21 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I found it after using one of my techs multi meters.It was the right upper 10amp fuse in the fuse block behind the battery.After using the multi meter i found the blown fuse and pulled it out but still had a hard time seeing were it blew.It was just a real tiny little mark on it that i just could barely see.
Thanks for the help.
__________________
Old Sep 8, 2008 | 03:08 PM
Jay'Z's Avatar
Jay'Z
Aw fack.. lol Next time literally pull all fuses out and check.. It takes a while and its annoying but it would have solved ur prob faster
Old Sep 8, 2008 | 03:30 PM
doug's Avatar
doug
thats good to hear you back up and running
Old Sep 8, 2008 | 03:44 PM
superchargedg
Damn Noobs
Thanks guys......but im still pissed at myself for not seeing that tiny little burn mark on that fuse.
Old Sep 8, 2008 | 04:41 PM
KPierson's Avatar
KPierson
Does that mean I win?
Good to hear you got it and it wasn't anything major!
Old Sep 8, 2008 | 05:10 PM
doug's Avatar
doug
the end result is more important man.. don't wory about not seeing hte mark
Old Sep 8, 2008 | 10:04 PM
ADMAN's Avatar
ADMAN
Wow...
Old Sep 9, 2008 | 02:38 PM
superchargedg
Damn Noobs
Yes you win.
Old Sep 9, 2008 | 06:52 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Hey guys, I think it's a blown fuse!
Old Sep 9, 2008 | 06:54 PM
zulator03's Avatar
zulator03
he needs a new fuse and why max do u win we all win
Old Sep 10, 2008 | 03:53 PM
superchargedg
Damn Noobs
Closed.
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
