NE1 removed PCV on passenger side valve cover?
Old Dec 5, 2009 | 09:02 AM
  #201
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
All nipples are molded into the valve covers.
Old Dec 5, 2009 | 09:09 AM
  #202
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yep I just looked at mine
ok so I need some guidance from the guys who have done this - keeping in mind my car is NA
I really want to use AN's and not standard vacuum hose. Can anyone think of a clean way to do this, preferably without removing the valvecovers (since I literally just did new gaskets a couple thousand miles ago and I'd hate to have to get new ones again)? Passenger side is easy since pcv unscrews and I can get a fitting to thread in it's place
I'll just leave the crossover between the 2 valvecovers with the stock hose, can't see it anyway
Old Dec 5, 2009 | 04:30 PM
  #203
Chris@FsP's Avatar
Chris@FsP
There is no good way to add an AN fitting to the drivers side without pulling the cover and cutting off the nipple, and drilling/tapping a larger hole.
BTW, I have reused my old valve cover gaskets for years with no problems, at least on my personal car. For customers I always use new.
Old Dec 5, 2009 | 09:10 PM
  #204
Z1 Performance
Former Sponsor
gotcha, thanks Chris
I had a valvecover leak on my passenger side that just got fixed, so I don't really feel like risking it again I'll figure something out and post here
Old Dec 14, 2009 | 11:51 AM
  #205
str8dum1's Avatar
str8dum1
here's what i did.
i'm goin to just run a breather on the other side of the catch can instead of a hose and mount the catch can down low by the frame rail. Allow plenty of fresh air to keep away the fumes.
Old Dec 15, 2009 | 10:15 AM
  #206
350z 6spd's Avatar
350z 6spd
Anybody know where to get check valves with 5/8" barbs?
Old Dec 15, 2009 | 11:33 AM
  #207
rcdash's Avatar
rcdash
You can get all sorts of couplers at fastfittings.com. I use only 3/8" hose barb check valves.
Old Jul 7, 2010 | 12:09 PM
  #208
midz350's Avatar
midz350
Originally Posted by Chris@FsP
Here's what I did:
1. Removed pass side PCV, installed 5/8 barb
2. Ran a separate hose from each valve cover to Greddy catch can
3. Vent catch can to atmosphere through small filter
No smoking under boost, no smoking at idle, no oil in intake. Does its job perfectly.
Chris, can you please draw a diagram for your setup? its the HR shop car right?
I have a HR and the DE's drawing here is messing with my head .
Old Jul 7, 2010 | 01:52 PM
  #209
Chris@FsP's Avatar
Chris@FsP
I suck at Paint, so here is the best I came up with. Both the PCV valve and the drivers side breather have been drilled out.
Attached Thumbnails NE1 removed PCV on passenger side valve cover?-hr-catch-can-diagram.jpg
Old Jul 7, 2010 | 02:28 PM
  #210
midz350's Avatar
midz350
Thanks.
Old Jul 9, 2010 | 10:40 AM
  #211
specialist's Avatar
specialist
insn't that k&n Filter legal? or you will get a big ticket?
Old Jul 9, 2010 | 12:29 PM
  #212
4SHIZZIL's Avatar
4SHIZZIL
Originally Posted by thawk408
Another option is to seal up the hole on the driver side cover and make your own with whatever size fitting you want.
i grabed a longblock that had been sitting or about 6 months. after the vortec hit it, it shot the effing dipstick out and almost took out a few patrons watching the run.
removed the california emission bs PCV system all together, install catch can...cranked up boost and timing, she ran great after that.
After 6psi the PCV system starts negatively working as in the air going back the wrong way. Installing a check valve only makes the boost go to the other side of the system, either way if it can bleed off because boost is on the other side of the check valve, then excessive crank case pressure is going to be evident.
FYI
***edit*** lol some catch cans have a small vent hole to avoide excessive pressure in themselves which also aid the entire crank system too.
Rev_Night
Nov 7, 2020 06:00 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
samansharif
Sep 25, 2015 12:31 PM
