NE1 removed PCV on passenger side valve cover?
Old Dec 2, 2008 | 06:34 PM
  #81
bikinilust's Avatar
bikinilust
Nice find...
So which of these is ideal?
Also, can one buy 90 degree bent hosing in 5/8"?
Old Dec 4, 2008 | 07:25 AM
  #82
doug's Avatar
doug
Originally Posted by doug
what is the hose currently connected to from the valve cover.. the intake pipe? i know it was on my maxima
anyone?
Old Dec 4, 2008 | 07:44 AM
  #83
ToastZ's Avatar
ToastZ
anyone?
On the driverside valve cover the hose is connected to the turbo intake pipe on my car (APS-TT).
  #84
weslutes's Avatar
weslutes
anyone?
^^ I have the APS TT also.
You mean size right?
5/8
Old Dec 4, 2008 | 08:44 AM
  #85
doug's Avatar
doug
ok cool.. so basically its the same place.. thanks
Old Dec 4, 2008 | 03:06 PM
  #86
doug's Avatar
doug
last question.. what do you do with the port from the intake pipe after you add the breather to the valve cover?
Old Dec 4, 2008 | 04:48 PM
  #87
ToastZ's Avatar
ToastZ
Cap it off.
Old Dec 4, 2008 | 06:26 PM
  #88
doug's Avatar
doug
Cap it off.
what do you use to cap it off.. i'm looking to redo my catch can and do the breather filter on saturday.. provided it doesn't start snowing too early
Old Dec 4, 2008 | 07:15 PM
  #89
str8dum1's Avatar
str8dum1
a vacuum cap
Old Dec 4, 2008 | 07:16 PM
  #90
ToastZ's Avatar
ToastZ
Try Autozone or other local parts store. They sell vacuum caps of various sizes.
You will probably need something like a 5/8 id cap.
Old Dec 5, 2008 | 02:28 AM
  #91
doug's Avatar
doug
gracias
Old Dec 5, 2008 | 04:32 AM
  #92
JETPILOT's Avatar
JETPILOT
3/8 inner diameter
Old Dec 5, 2008 | 05:09 AM
  #93
ToastZ's Avatar
ToastZ
Originally Posted by JETPILOT
3/8 inner diameter
Jet, the drivers side hose is larger than 3/8.
Old Dec 5, 2008 | 05:14 AM
  #94
doug's Avatar
doug
two months ago i did a homemade catch can from this thread
https://my350z.com/forum/engine-driv...catch-can.html
i got this hose from home depot.. but its flexing and shrinking too much with heat..
i ordered some SS Lines and Andonized Fittings from corvette accesories per gothchick's suggestion..
i'm going to redo the catch can with the new hose and fittings this weekend.. and also do the breather filter on the drivers side
here is her car with the new lines and fittings
Old Dec 5, 2008 | 07:03 AM
  #95
QuadCam's Avatar
QuadCam
doug,
as you already know....that hose sucks. it collapses with heat and vaccum! if you want a cheaper alternative to the braided lines, go to your local auto parts store and look for "high pressure" hose or "fuel injection" hose. they should have it behind the counter. Just ask them if you can look through the hoses in the back.
Old Dec 5, 2008 | 07:14 AM
  #96
doug's Avatar
doug
Originally Posted by QuadCam
doug,
the package already arrived from corvette accessories.. i figured they look nice.. i would dress her up a little bit what i need to find though is that bracket she has to mount it
Old Dec 5, 2008 | 07:20 AM
  #97
rcdash's Avatar
rcdash
Use it as another vacuum source: during boost! (check valve required) Use SAE J30-R7 or -R9 fuel injection hose (the latter is really expensive per foot). I doubt R7 would collapse at the low vacuum levels it sees even when hot. I used it for a long run across the front of the car (from pass side catch catch to vacuum source on driver's side intake pipe).
Old Dec 5, 2008 | 07:39 AM
  #98
doug's Avatar
doug
thats a great idea.. thanks.. if i don't do it this time.. i will do it another time..
sound like i might need a T Fitting too
Old Dec 5, 2008 | 08:28 AM
  #99
rcdash's Avatar
rcdash
yes T-fitting coming out of the catch can to 2 check valves - 1 going to plenum, other to driver side turbo intake. voila - vacuum source all the time!
Old Dec 5, 2008 | 09:24 AM
  #100
350z006's Avatar
350z006
Nice pics doug...please post pics of your driver side mods too when you get to it...
