NE1 removed PCV on passenger side valve cover?
Old Dec 5, 2008 | 09:50 AM
  #101
doug's Avatar
doug
Originally Posted by 350z006
Nice pics doug...please post pics of your driver side mods too when you get to it...
none of those are my car.. but i can take pics this weekend though while and when i am doing/finished
Old Dec 5, 2008 | 10:11 AM
  #102
350z006's Avatar
350z006
That would be awesome...
My car reeks oil from my Stillen supercharger...
j/k...I have a Vortech...
Old Dec 5, 2008 | 12:19 PM
  #103
Cass007's Avatar
Cass007
[QUOTE=doug;6643280]
QUOTE]
WOW - Gothchick has man hands !!!!
Seriously though, when is someone going to post the definative step by step how to with pics? I thought JET was posting up something? Has it finally been agreed what is the proper/best method to use?
Old Dec 5, 2008 | 12:34 PM
  #104
doug's Avatar
doug
the car with the SS Lines and Andonized Fittings is gothchicks..
For the Pass side.. once you take off the valve cover its pretty straight forward.. you can pretty much see the whole thing in gothchicks pic
Drivers side you have to remove the plenum and its a hose connected to the valve cover going to the intake pipe
Old Dec 5, 2008 | 12:39 PM
  #105
rcdash's Avatar
rcdash
pass side valve cover?
Old Dec 5, 2008 | 12:42 PM
  #106
doug's Avatar
doug
engine cover sorry
Old Dec 5, 2008 | 08:54 PM
  #107
bikinilust's Avatar
bikinilust
where are you guys getting your check valves from?
How much should these run?
part numbers will be greatly appreciated.
Thanks
Old Dec 5, 2008 | 08:59 PM
  #108
bikinilust's Avatar
bikinilust
Also. can someone clear this up for me?
ok. driver's side pcv is for venting, or for sucking in air?
Same with the passanger side. Is it for venting and/or taking in air.
Does the passanger side need to be connected to the plenum? Cant it just be connected to a catch can with a breather on it? Or does it need that vaccuum to release the pressure?
Thanks
Old Dec 5, 2008 | 10:04 PM
  #109
JonnyC's Avatar
JonnyC
Thanks
I used these for check valves, although they don't seem to flow much air...
http://www.usplastic.com/catalog/var...&cookie_test=1
Old Dec 5, 2008 | 11:28 PM
  #110
JonnyC's Avatar
JonnyC
Thanks
Well, are you boosted? If you're not boosted, then just keep everything stock. Here's a diagram of how things work stock...
Attached Thumbnails NE1 removed PCV on passenger side valve cover?-untitled.jpg
Old Dec 5, 2008 | 11:31 PM
  #111
JonnyC's Avatar
JonnyC
anyone?
Sorry, I have to make sure to stick with the threads that I post in
Old Dec 5, 2008 | 11:41 PM
  #112
JETPILOT's Avatar
JETPILOT
Yes.. your right. The drivers side is closer to 5/8.
Old Dec 10, 2008 | 12:06 AM
  #113
Havok_RLS2's Avatar
Havok_RLS2
Any updates?
Old Dec 13, 2008 | 01:32 AM
  #114
Havok_RLS2's Avatar
Havok_RLS2
for those looking for check valves to install between the stock pcv and catch can.
APS part number 000-990-300 VALVE - ONE WAY - PCV
http://www.airpowersystems.com/guide...-tts07/bom.htm
OEM Nissan brake booster check valves off a Z32
$20 from courtesy parts =
http://www.courtesyparts.com/kb_sear...utton=Go&cat=1
1. [47478] VALVE ASSY-CHECK - Product SKU: 47478-Z32001
2. [27461M] VALVE-CHECK - Product SKU: 28628-Z32001
OR:
http://www.partsgeek.com/gbparts/199...ek+Google+Base
Old Dec 13, 2008 | 09:17 AM
  #115
doug's Avatar
doug
OR:
https://my350z.com/forum/6646625-post109.html
Old Dec 18, 2008 | 11:32 AM
  #116
TTRANK's Avatar
TTRANK
OK so I have read this whole thread and am still a little confused on the best solution.
Any updates?
Currently I have a catch can on the oem PCV valve on the pass side and a breather filter on the driver side valve cover with the driver's side turbo inlet port capped.
Old Dec 18, 2008 | 11:36 AM
  #117
JETPILOT's Avatar
JETPILOT
Crankcase Fix
Old Dec 19, 2008 | 08:31 AM
  #118
Snow-G's Avatar
Snow-G
So the end result is drilling out driver pcv and returning the line to the intake right? Why not run this line to the catch can as well? As stated before, I don't like the fact of re-entering spent gases into the intake. I would assume that the intake temp would also be cooler as well. Thoughts?
Old Dec 19, 2008 | 10:14 AM
  #119
JETPILOT's Avatar
JETPILOT
I don't know why I do write ups....
Old Dec 19, 2008 | 10:36 AM
  #120
rcdash's Avatar
rcdash
ummm, no. there are a couple solutions presented in this thread and in jet's link - and that's not one of 'em. try again.
