Crankcase Ventilation Mod w/Pics
Old May 13, 2010 | 11:57 AM
  #141
wtk's Avatar
wtk
I have an APS TT set up on a built motor, and after a couple years, Ive been getting a little more blow by at WOT, so I decided it was time to take this on... I pretty much used rcdash's set up (thanks so much for the help!), except I routed all my hoses around the drivers side the same way the already were to keep the plumbing a little shorter... this worked out better for me with the placement of my catch can. I was able to retain vacuum very near stock at idle, so I am really happy with that outcome thus far...
And here's a little diagram I drew up to try to clear things up a little...
^^my arrow is technically backwards, but whatever, you get the idea : )
Old May 13, 2010 | 01:35 PM
  #142
wtk's Avatar
wtk
Oh, and if any one is still confused at all, I wrote up a step by step with pictures that you can find here: http://www.*********.com/forums/119-...i-members.html
Old May 15, 2010 | 06:49 AM
  #143
wtk's Avatar
wtk
So after running this for a couple days, I notice the engine is getting some un-metered air from the plenum. This is making me idle a bit leaner. Has anyone had to make fuel adjustments, or is it not significant enough for that?
edit: I played around with some different size hoses, I added a 1/4 hose into the one that runs to the plenum. This sort of simulated the restriction of the stock PCV, brought my A/F back down, increased plenum vacuum pressure, and it seems to be idling perfect again...
Old May 24, 2010 | 09:24 PM
  #144
Mr_pharmD's Avatar
Mr_pharmD
can someone draw a better diagram with the correct version?
Old May 24, 2010 | 11:55 PM
  #145
Synjn's Avatar
Synjn
Seriously.
Can't you just run two of those breathers? One on each valve cover, plug up the two holes and be done with it? That's what i'm planning on doing.
I'm getting blow by from the crankcase vent into my supercharger inlet. going to put a breather on and plug the SC crankcase hole.
Hoping I can do the same thing to the other side and get rid of my catch can all together.
Old May 25, 2010 | 04:57 AM
  #146
rcdash's Avatar
rcdash
You can just run two breathers. You don't get any ventilation of combustion vapors (oil, fuel, water) out of the crankcase, the only downside of which is the oil getting dirty more quickly. Not a big deal if you change it out frequently anyway.
Old May 25, 2010 | 09:01 AM
  #147
05Z33's Avatar
05Z33
So to remedy this, all you really need is 2 oil catch cans with breather filters on top. Place one on each side and run a hose from the plenum vacum port with a T fitting to both cans. It seems to me like the best catch can option out there is the ARC V2 when it comes to our cars.
Old May 25, 2010 | 09:29 AM
  #148
rcdash's Avatar
rcdash
Any *significant* amount of hose between the valve cover and filter can cause restrictive pressure build up in the crankcase. Use short 1/2" hose and that should work fine but is still not true ventilation. BB turbos are more sensitive to crankcase pressure than journal so YMMV.
Most folks I think now use 1 filter right on a valve cover with the catch can only on the other side. That gives true ventilation (fresh air in one side, picks up fumes, goes out the other to the catch can, suctioned by whatever vacuum source/s you choose to use).
Old May 25, 2010 | 09:33 AM
  #149
05Z33's Avatar
05Z33
Does it matter which valve cover gets the filter? I have one on the driver side, so a regular catch can on the passenger side should do the trick?
Old May 25, 2010 | 09:44 AM
  #150
streetzlegend's Avatar
streetzlegend
Not really, both heads are connected to the crankcase. you can actually blow into one cover and feel it on the other side.
Old May 25, 2010 | 11:07 AM
  #151
rcdash's Avatar
rcdash
^+1 exactly. Does not matter - the plumbing is shorter putting the filter on the driver's side but that's about it.
Old May 31, 2010 | 05:27 PM
  #152
cersoft's Avatar
cersoft
I just want to give a big hats off to this thread, I had pretty bad smoke under -ve load and a nasty whiff coming any stop. I drilled out my pcv valve and am now running the mirror of rcdash's setup (breather on drivers side, suction from plenum and intake with check valves). And no smell, no smoke, absolutely none ...
Awesomeness !!!!
Old Jun 15, 2010 | 01:54 PM
  #153
Synjn's Avatar
Synjn
Awesomeness !!!!
I'm going to play around with that idea as well.
Old Jun 15, 2010 | 02:01 PM
  #154
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Originally Posted by Synjn
Ok so after reading all this I am not sure what is the best route to take.
my problem:
I'm running a vortech and have discovered oil blowing onto my sway bar out my bypass valve. Safe to assume there is oil in my intercooler. This is due to the driverside valve cover breather tube recirculating to the intake on my SC. Just after the air filter.
Passenger side: Valve cover breather tube runs to my catch can, then to the inlet on my intake plenum.
Question: Can I just plug the hole on my SC and plug the hole on my intake plenum and put a small breather on each valve cover and forget the catch can altogether? Just like the old days?
You can, but here's how I do it:
Passenger side- mini K&N filter
Drivers side- PCV drilled out, -6 line to catch can, from catch can to intake piping. ZERO oil problems Just make sure you put something "mesh-like" in the can to help catch the oil and keep it from getting sucked straight through the catch can and back into the intake.
Old Jun 16, 2010 | 01:39 PM
  #155
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
350z(dash)Tech.com is a blocked name site so you have to get creative with the link....like this www.350z*-tech.com (please remove *)
See if that helps the link above. Thread can be found under Power & Performance, Forced Induction, Engine, Then look for " How To: Vent Your Crank Case. Attn: F/I Members."
Old Jul 23, 2010 | 06:41 PM
  #156
Synjn's Avatar
Synjn
<a href="http://s66.photobucket.com/albums/h244/Synjn/vacume/?action=view&current=Picture006.jpg" target="_blank"><img src="http://i66.photobucket.com/albums/h244/Synjn/vacume/Picture006.jpg" border="0" alt="Photobucket"></a>
I recently realized that the stock hose connecting the L and R valve cover was creating a shortcut and the only thing being recirculated was the vapor under each valve cover.
Think about it: PCV (out) <----- Left cover <---- Connecting hose <----Right cover<------Breather (fresh air in).
Was never pulling from the crankcase. By cutting the connecting line, I can (under vacuum) as I illustrated pull from the left side via the plenum vacuum under low load conditions, thus good piston ring seal. Fresh air in through the right side circulating throught the bottom end.
BTW -The red indicates a 1 way check valve. Who's got good one's that actually seal?
Anyone got numbers on the vacume created at the plenum vs the intake vs the crankcase?
Most importantly having enough breather outlets for proper venting during high load/high boost conditions. The crankcase pressure is always going to overtake the vacume. Right? The pressure's got to go somewhere. So why try to pull out CC pressure when it's already moving out. (Is why I disconnected and plugged the preturbo vacuum).
I figure the moment crankcase is not boosting anymore, my plenum vacuum source will gently pull out the bad vapor.
Any input would be great.
Old Jul 23, 2010 | 08:11 PM
  #157
rcdash's Avatar
rcdash
Never thought about ventilating through the bottom end. So the two central nipples have one way valves that only allow gas escape? The driver's side rear vent is just an open breather? I think that would work fine also. I'm not sure that it would provide any better ventilation if the lighter vapors that you want to remove (fuel, water) are up top, but it might... If blow by is excessive it provides 2 additional outlets. Even with the center hose, I pull 4 mm Hg vacuum at idle in the catch can. You may end up sucking out more oil because of the increased vacuum from the longer circuit and from having the ventilation flow through the bottom end.
Old Jul 23, 2010 | 08:31 PM
  #158
Synjn's Avatar
Synjn
Only where there is the "red" are the check valves. There are 2 of them. The right central nipple is wide open. Releases pressure under boost, sucks in fresh air under vacuum. AND the driverside rear vent also is an open breather to do the same.
Old Jul 26, 2010 | 03:37 AM
  #159
HotRodG35's Avatar
HotRodG35
Heres what I used for my PCV return line. Moroso check valve, extremely durable.
http://www.summitracing.com/parts/MOR-23875/
Old Jul 26, 2010 | 04:09 AM
  #160
rcdash's Avatar
rcdash
Looks like it's designed for fuel/oil - much heavier materials than the plastic counterparts. While they may work fine, the lighter check valves designed for brake booster operation seem to work just fine.
Gotcha - makes sense. It'd be great if you could update this thread when you get an idea of how quickly oil accumulates with that set up.
