Td05-18g oil return gasket????
Old Dec 22, 2008 | 11:33 AM
Blwn_By_Twins's Avatar
Blwn_By_Twins
Default Td05-18g oil return gasket????
Do I have to get one from Greddy or is there something else I can use? I got the car out back together, but have s slight drip from the O/R on bottom of the turbo. Bolts are tight so I assume I just need a new gasket.
Oh, 1 more thing. Can the factory fuel line be bent to move it a little? There is a bend in it that makes it run right up against the pass side turbo. It's heat wrapped, but I'd still like to get it further away. Just didn't want to grab and bent without knowing for sure. Thanks!
Old Dec 22, 2008 | 12:09 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Check with ATP turbo or Forced Performance for the gasket.
Regarding the fuel line, you can make slight bends to it with a tubing bender. Be careful to not go too far and crimp it, because once damage is done there is no reversing it.
Old Dec 22, 2008 | 12:30 PM
Blwn_By_Twins
Thanks Hal!!!
Old Dec 22, 2008 | 07:19 PM
JETPILOT's Avatar
JETPILOT
Oil Return Gasket
Old Dec 22, 2008 | 09:37 PM
theking's Avatar
theking
Just be sure to use alot of silicone with it. My turbo drain line(on my DSM) had to be redone three times before I got it right.
Old Dec 23, 2008 | 01:51 AM
350zzzgunnar's Avatar
350zzzgunnar
During rebuild I re routed my fuel feed line (as far from hot exhaust parts as possible), but skipped the EVAP hose cuz I was lazy.
On a hard track day the turbo hit the engine bay wall, came loose and hot gases burned the EVAP hose as you can see in pic. I'm glad that i moved the fuel line or the car would have set on fire.
As you can see the EVAP line burned despite I heat wraped it . It burned and the metal melted inside the wrapping!
Now I have solid motor mounts from Hal@IP and rerouted the EVAP house
Old Dec 24, 2008 | 06:02 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Originally Posted by JETPILOT
Good find Jet as i need 2 new ones also.
Old Dec 24, 2008 | 07:40 AM
QuadCam's Avatar
QuadCam
anyone have a line on the greddy 3-bolt turbine gaskets. those suckers are hard to find. they aren't a standard 2" 3-bolt gasket (even those are hard to find.)
Old Dec 24, 2008 | 08:26 AM
Blwn_By_Twins
Replacment parts for the Greddy kit found HERE.
Old Dec 24, 2008 | 08:57 AM
QuadCam's Avatar
QuadCam
I am not finding anything for the greddy/mitsu turbos. why did greddy have to put there own inlet/outlet flanges on these castings. it is so annoying!!!!!
Old Dec 24, 2008 | 09:11 AM
sandy@forged's Avatar
sandy@forged
Forged Performance
I do have these Td05 gasket $30. Call the shop I can ship it out today
Old Dec 24, 2008 | 09:49 AM
gdragon's Avatar
gdragon
Thumbs up
Same here... I have tried every muffler and automotive shops in my area.... Only turn up empty handed.
Thanks Sandy...
Old Dec 24, 2008 | 10:11 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Thanks Sandy...
They are prettymuch impossible to find anywhere else. We have to get them from Greddy. We always keep spare in stock.
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
