Scott Bush & Relentless Autosports: Exposing the Hype, Lies, and Failure
Old Apr 5, 2009 | 08:15 PM
  #2201
Nate76s's Avatar
Nate76s
Originally Posted by discom
Hi,
I must say that I am impressed with your dyno results
I am from Singapore and I guess that we are a bit behind the times when it comes to technology. My engine builder has always got me to buy parts that I suspect are more than what I need for my requirements. And after seeing your dyno results, it just confirms that I don't need the 1000cc/min injectors that he got me to buy.
But before I go confront him, can you please let me know what fuel pressure you are running your system at? And what duty cycle are you running the injectors at?
Without taking fuel pressure into consideration, going by the calculations at this website, http://www.witchhunter.com/injectorcalc1.php4,
using crank HP of 585HP (509rwhp x 1.15, think 15% transmission loss is fair),
and BSFC of 0.6, I calculate that you need a fuel injector duty cycle of 123% if you are using 500cc/min injectors.
Is it safe to run injectors at 123% on a constant basis? My engine builder told me that a reasonable number is 85% at WOT or else I will blow my engine. Can you show me some literature so that I can call BS on him!
Or maybe you are running at 85% duty cycle and just increased the fuel pressure. But going by this calculations, http://www.rceng.com/technical.aspx, you need a fuel pressure of 130PSIG!! How did you manage to achieve such a high pressure? I don't think even my dual Sard 280L/min can do that? What fuel pumps are you using? Please don't say that you are using the stock fuel pump because I don't see a fuel pump upgrade on your build sheet. I am going to sue my builder if you are using the stock fuel pump and can get such high pressure
And you stated that you are not running a fuel return system? Again...I am mad. How did your engine builder manage to run such a high pressure fuel system without a fuel return system?
I hope that you will share the knowledge so that I can go confront my engine builder.
DAMN! ...
Originally Posted by USN HM 350Z
Hey if I have them build my car, can I have it fixed if I let another shop look it over?
I was wondering the same thing. I'll send my car too scott for a build and then let XKR pay another shop to fix all the mistakes Scott makes, buy me a new fuel system, ems, and a reliable tune ... winwin
Old Apr 5, 2009 | 08:25 PM
  #2202
XKR's Avatar
XKR
Originally Posted by Nate76s
DAMN! ...
Old Apr 5, 2009 | 08:27 PM
  #2203
XKR's Avatar
XKR
Here is MY dyno run where I made 1150 using 850bb turbo and C36 race fuel.
Yes I had it done at SP....Dont ask me any question...I will not respond...THX..
Originally Posted by XKR
Old Apr 5, 2009 | 08:33 PM
  #2204
Sylvan Lake V35's Avatar
Sylvan Lake V35
Be careful your car might get stolen when its parked in the hood/shop over night.
Old Apr 5, 2009 | 08:59 PM
  #2205
r0mey's Avatar
r0mey
videos of your car on the dyno please
I got em you should too
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/PWquN_SLU-s&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/PWquN_SLU-s&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Apr 5, 2009 | 09:17 PM
  #2206
discom's Avatar
discom
Hi,
I made a mistake when calculating the fuel pressure needed, it should be 90 PSIG and not 130 PSIG. MY bad.
My dual Sards may just reach this high of a pressure. But how did you manage to achieve this pressure without a fuel pump upgrade? Is it true that a thicker wire will do the trick?
Old Apr 5, 2009 | 09:36 PM
  #2207
Nate76s's Avatar
Nate76s
You forgot about his patent pending black hole technology
Old Apr 5, 2009 | 10:38 PM
  #2208
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
I could have my wife bring the car to him....
Can he make my wife's car not be a POS?
Old Apr 6, 2009 | 03:15 AM
  #2209
Mike Wazowski's Avatar
Mike Wazowski
This is relentless we are talking about, he will work his VooDoo on the car and you will be amazed at what he delivers you.....
Old Apr 6, 2009 | 08:08 AM
  #2210
myG35zx's Avatar
myG35zx
Has anyone called JWT and asked about Scott? RA? VRT? I wonder if they refer to them? Scott seems to push the JWT hard (as seen at g 350 z driver yesterday). Just curious.
Old Apr 6, 2009 | 09:02 AM
  #2211
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
Originally Posted by myG35zx
Has anyone called JWT and asked about Scott? RA? VRT? I wonder if they refer to them? Scott seems to push the JWT hard (as seen at *********** yesterday). Just curious.
I already said this.This is how we get to Scott by going through JWT and complaining about him letting guys without shops install their turbo kits. Although we are an authorized JWT dealer,we have not installed one kit, only fixed other shops fuc* ups.
Old Apr 6, 2009 | 09:31 AM
  #2212
Sylvan Lake V35
Sick roadster I am going to have to search I need more pics of that thing
Old Apr 6, 2009 | 09:36 AM
  #2213
Sylvan Lake V35
Just checked out your garage r0mey sickest ZR I have seen
Old Apr 6, 2009 | 11:17 AM
  #2214
r0mey's Avatar
r0mey
thanks dood i appreciate that but my point was quiet simple most people with high HP cars usually have a dyno vid of their car.
Old Apr 6, 2009 | 01:25 PM
  #2215
XKR's Avatar
XKR
Yup...here is the dyno where I made 1150whp using 850bb turbo's.
<embed src="http://video.cardomain.com/mediaplayer.swf?file=http%3a%2f%2fvideo.cardomain.com%2fadpl aylist.aspx%3fembeded%3dtrue%26key%3d38871A4283F8F257&callba ck=http://video.cardomain.com/adplaylistcallback.aspx&backcolor=0xffffff&frontcolor=0x1c54 9d&lightcolor=0x1c549d&screencolor=0x000000&logolink=http://video.cardomain.com/" width="430" height="354"></embed>
Originally Posted by Hydrazine
The XKR extended warranty plan. =Win/Win
Mike,
Does your extended warranty plan also cover welded up pistons, crank case mud, cracked blocks, wrong cams, reused bearings from blown engines and fire hazards?
Tony....John worked hard to get this guy to take the deal.....he refused to respond to the offer. His warranty has now expired. Now he comes on here and post some fake dyno that scott gave him PA-LESE
Carefull now...VooDoo is TM
Old Apr 6, 2009 | 02:16 PM
  #2216
ToastZ's Avatar
ToastZ
XKR, It's not 100% VooDoo (TM)
The equation may be more complicated, as-in:
10% - Complete BS
30% - Lucky to find naive customers
30% - Luckier that they have money to spend
10% - VooDoo Parts (i.e. high voltage/current wired to walbro)
10% - VooDoo Marketing (website with no address, no business license)
10% - VooDoo Dyno Sheets (HP & TQ too high for a single wire to produce)
100% - Fail
Old Apr 6, 2009 | 02:22 PM
  #2217
XKR's Avatar
XKR
10% - Complete BS
100% - Fail
Old Apr 7, 2009 | 02:10 AM
  #2218
Nate76s's Avatar
Nate76s
10% - Complete BS
100% - Fail
Nice
Old Apr 7, 2009 | 09:05 AM
  #2219
Sylvan Lake V35
Sorry for going OT but For sure my last set up was only 415whp and I had a dyno vid. Most guys that go from 250whp to 500+whp get that **** on video.
Old Apr 7, 2009 | 09:36 AM
  #2220
GenPac's Avatar
GenPac
It's like walking into a secure facility... No pictures or recording equipment allowed. The man has to safeguard his methods or EVERYONE will be pushing his numbers!
