XKR Super G... Going for Mach 1
Old Sep 9, 2009 | 05:55 PM
  #1021
Sylvan Lake V35's Avatar
Sylvan Lake V35
Originally Posted by XKR
Dont get me wrong fellows.....I am not saying you have to have head work to make big power......Someone was saying that headwork is a waste of money......and my attempt is to show that its not
I agree, to me if the heads are off for the money why not throw a little work at them it can't hurt? It might not be a requirement but why not while your at it. I also understand opening up things only goes so far if you have a bottle neck else where.
Old Sep 9, 2009 | 06:05 PM
  #1022
ttg35fort's Avatar
ttg35fort
Professional
The MadScientist and Luie raced at ZdayZ 2008 when Luie still had his car. Both MadScientist and Luie had about the same setup.....Luie 850bb......MS 20G.....
MS has Cosworth heads.....Luie Stock heads.
This was a high speed roll....From what I was told.....MS pulled on Luie....WHY???
From what I was told...The only difference between both cars was the Cosworth Heads.
In that situation the extra 6-7% will make a difference. Again, this figure was ignoring the impact of the cams, the use of different dynos and different weather conditions. So take it with a grain of salt.
I started debating with myself because honestly, for big hp builds, I expected to see a bigger difference. I should know better. I usually do more research and/or analysis before posting. The initial posts by the guy in the other thread got me going.
Old Sep 9, 2009 | 06:16 PM
  #1023
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by str8dum1
The biggest difference between Tom;s SP build and every other log manifold build is the turbine housings used. Tom has a true T3 or T4 while everyone else uses a T25 for fitment reasons.
One very respected tuner keeps telling me that the reason you dont see mid 20+ psi tunes on log manifold/T25 housing setups, is that the backpressure gets soo much that you are entering headlift without detonation territory. You CAN NOT just keep raising the boost to reach your power goals. If you could, why all the weak dynos with gt30 series turbos? A pair of those could easily run in the 800s on pump gas and well into the 900's on race. Yet no one has come close to that. There are tons of dyno sheets of single gt3071 and gt3076s making 400+ easily on other platforms that can use the larger housings
Trying to push 1000 whp thru a T25 housings is going to be inefficient to say the least.
Thats why the highest most strung out dyno using a log manifold/T25 is barely over 800 whp (and even GTMs extreme APS kit was on a 4.24L car)
Hal made more power with less boost because he is running a much larger t4 turbine housing. I'd bet an extremely different amount of backpressure.
Sure nice heads are good, but fitting T3 or T4 housing (ie frame notching) is a much better place to spend money on and way more gains can probably be had there
Very good point.
I don't even know what housings my new turbos have. It probably would have been good to check, but now I already have my exhaust manifolds ceramic coated. I did that with my Greddy kit before I decided to sell it. That was a waste. I took it in the shorts over that blunder. The buyer got a h@ll of a deal, though.
Old Sep 9, 2009 | 06:19 PM
  #1024
ttg35fort's Avatar
ttg35fort
Professional
Tom,
Do you have a link to your dyno graph? It would be interesting to compare your dyno to Hals...
Old Sep 9, 2009 | 06:26 PM
  #1025
str8dum1's Avatar
str8dum1
Everything with log manifolds with Garret turbos uses a T25 housing. Only the single and tubular manifold kits offer bigger manifolds (and a TON more install work)
ATP turbo sells t25 housing that they say flows as much as a true T3 but they are expensive. Not something you'd do on a brand new GTM kit. But if GTM offered that as an upgrade, it would be very interesting to see dyno comparisons.
Not tryin to start a bandwagon, but big numbers with the current kits might take a lil more than we all expect. I just want XKR, TTfort, Sylvan Lake, smalltuner, and Blackbird to hurry the hell up with their builds and get some high boost #'s so I can choose my kit
Originally Posted by ttg35fort
Very good point.
Old Sep 9, 2009 | 06:36 PM
  #1026
thom000001's Avatar
thom000001
yup, this pull only goes to 6k rpm (hit boost cut that was set at 30psi).....but stock cams we all know what happens above 6250rpm..ugh...so maybe would have made a couple more hp going to the peak hp at 6250rpm.....but didn't need to push anymore to get 5hp lol
I rev to 7k now at the track (and the odd race where I really need it on pump)
*edit* - added my car "bone stock" vs "14psi" vs "30psi" layed over on one graph lol
Tom
Tom,
Old Sep 9, 2009 | 07:07 PM
  #1027
ttg35fort's Avatar
ttg35fort
Professional
Here is Hals (Hal, if you have an issue with me posting this, please let me know and I will remove it. ):
Old Sep 9, 2009 | 07:11 PM
  #1028
thom000001's Avatar
thom000001
Mine just does everything about 1K rpm sooner, but not nearly as high into the rpm range.....as expected.
tom
Old Sep 9, 2009 | 07:13 PM
  #1029
ttg35fort's Avatar
ttg35fort
Professional
It looks to me like Tom is getting his HP much earlier in the power band, but he is cutting off sooner. Hal's holding it until nearly 8000 rpm. I think the right cams will help Tom hold the power longer, with some sacrifice of spoolup.
Old Sep 9, 2009 | 07:17 PM
  #1030
ttg35fort's Avatar
ttg35fort
Professional
I just compared the cross-sectional areas of the T25, T3 and T4 turbine inlets. Here are the results:
T25: 1735 mm^2
T3: 2412 mm^2
T4: 3623 mm^2
The T3 turbine inlet is 39% larger than the T25 inlet.
The T4 turbine inlet is 109% bigger than the T25 inlet.
Those ratios are pretty significant, and support str8dum1's statement regarding the turbine inlet size.
Old Sep 9, 2009 | 07:19 PM
  #1031
thom000001's Avatar
thom000001
Trust me, Larry bugs me all the time to do cams lol
If we would have known it would make power like this, I would have done cams up front.
Tom
Old Sep 9, 2009 | 07:22 PM
  #1032
thom000001's Avatar
thom000001
So just based on cross section....a single T4 flange can outflow 2 T25 flanges no matter what. No wonder Supra's will opt for a bigger single T4 over two teeny T25's (and its half the cost to boot for them)
tom
T25: 1735 mm^2
T3: 2412 mm^2
T4: 3623 mm^2
Old Sep 9, 2009 | 07:25 PM
  #1033
ttg35fort's Avatar
ttg35fort
Professional
I just looked at GTM's website. It is not clear whether the turbine inlets are T25, T3 or T4. Based on stridum1's comments, I am assuming that they are T25. I'll check on it tomorrow.
Old Sep 9, 2009 | 07:29 PM
  #1034
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
tom
Exactly.
Old Sep 9, 2009 | 07:46 PM
  #1035
ttg35fort's Avatar
ttg35fort
Professional
I spoke with Sam today. My short block should be shipping soon.
I was much at fault for the delay. I switched gears on him and asked him to look into adding support around the tops of the cylinders (I got the idea from another thread posted here about a month ago).
I'm hoping for around 675 whp on 93 octane and 750 whp with the meth system on. I should be able to get there. My 3.5L motor got to over 600 whp on 93 octane, and with the 4.0L motor I am increasing displacent by about 14.2%. Add 14.2% to 600 and you arrive at 685. I'm also putting in bigger cams and bigger turbos.
Also, the last time around my spark plugs were 1 step colder. We pulled the timing way, way back. This time we are going to use 2 step colder plugs with the hopes of being able to run a little more timing. Perhaps this will let us get closer to 700 whp on 93 octane. I'm not holding my breath, but it would be nice.
Old Sep 9, 2009 | 08:11 PM
  #1036
ttg35fort's Avatar
ttg35fort
Professional
This is ot, but this is as good as anyplace to bring it up since my hardcore friends are in here:
It seams to me that there would be a significant benefit in long term longevity of our high hp motors to use cranks with larger journal diameters. Heck, some of us are already doing a lot of mods to our shorblocks, e.g., aftermarket rods, crankshafts and main caps. It doesn't seem like it would be that big of a deal to enlarge the main caps and the bearing seats in the block, nor increase the diameter of the rod's housing bore. Other than perhaps weight, why wouldn't/hasn't this been looked into???
Any thoughts???
Old Sep 9, 2009 | 08:42 PM
  #1037
ttg35fort's Avatar
ttg35fort
Professional
tom
Yes.
But A LOT depends on the intended use... Sometimes you really need cast iron manifolds (i.e. if you are intending on road racing alot) and you are stuck with the available sizes.
Old Sep 10, 2009 | 04:35 AM
  #1038
Cass007's Avatar
Cass007
Terry - the headwork I had done roughly lets my DE heads flow like HR heads. I was hoping Dave would post results in his thread, but he has been real busy.
Old Sep 10, 2009 | 06:28 AM
  #1039
rcdash's Avatar
rcdash
T25: 1735 mm^2
T3: 2412 mm^2
T4: 3623 mm^2
I think str8dum1's post (and whatever tuner he was referring to!) is right on the money, but remember what you said about velocity and pressure differential driving the turbine in the other thread? That still holds true. The smaller T25 outlet is going to push the powerband to the left and enhance spool, but of course you will have the high rpm bottleneck.
Don't worry, I won't start postulating about how lowering EGTs might help...
We did banter a bit about the twin scroll GT35R turbos mated to a quick spool valve on the g35driver thread back in June for Mike's build.
Old Sep 10, 2009 | 07:00 AM
  #1040
thom000001's Avatar
thom000001
we thought about the quick spool valves on mine as well....just don't know if there is quite enough room or an actual need on my setup.....maybe after doing the cams though, we'll see
tom
