Exhaust backpreasure vs. boost
Old Feb 7, 2009 | 04:50 PM
cwylie's Avatar
cwylie
Default Exhaust backpreasure vs. boost
So help me out here. Exhaust backpressure is exactly that. So why would a freer flowing exhaust cause a supercharger produce higher pressures at the same RPM. I would think it would be the other way around. The higher the backpressure in the exhaust would cause higher cylinder pressures because the exhaust could not escape as freely. Just trying to figure this one out.
Old Feb 7, 2009 | 04:58 PM
rcdash's Avatar
rcdash
Cylinder pressures containing spent combustion byproducts devoid of oxygen do not produce power.
Old Feb 7, 2009 | 05:50 PM
cwylie's Avatar
cwylie
Correct but if your just talking about flow like a air pump which any piston engine is. It would make sense for the boost to be higher with a more restrictive exhaust.
Old Feb 7, 2009 | 06:14 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
I am not totally sure that what you are saying about a free flowing exhaust is correct.
But if it is I would guess that with less back pressure, intake temperatures are lower. As a result, the compressor runs more efficiently. Somewhat like putting an intercooler into a system. The compressor has to do less work to produce the same amount of work. However, I really do not see this being the case.
Old Feb 7, 2009 | 06:21 PM
djtimodj's Avatar
djtimodj
Superchargers run the same power at a lower boost pressure with a free flowing exhaust. With stock exhaust 350whp at 10 psi. With a good true dual you can make 350whp @ 9psi for example. Hope that helps.
Old Feb 7, 2009 | 06:52 PM
cwylie's Avatar
cwylie
I am running a 3.12 pully on my G. I am only seeing about 7.5 psi at 6500 rpm. I was told it was because I am still running the stock cats. I had heard that before but was just trying to get the resoning behind it.
Old Feb 8, 2009 | 06:55 AM
QuadCam's Avatar
QuadCam
when comparing a supercharged car with a stock (catted equipped exhaust) to a big, free flowing dual exhaust with headers..........
the stock setup with show higher manifold pressure! essentialy, the air flow is the same in both motors due to the constant relationship of compressor speed to enginne speed.
this is a great example of why quoting boost pressure is not a very relative marker for engine airflow or power. intake pressure is not related to total airflow! this is how you can make more power with less boost on a supercharged car by improving the pumping efficiency of the total system. by making the exhaust system more effective and efficient, the engine can move more air through its cylinders - resulting in a lower reading of manifold pressure ("boost".)
on turbo cars, it's very hard to know what is really going on since the compressor wheel speed isn't in a proportionate relationship to engine speed. I think a couple companies have come out with rpm pickups for turbo speed now....this is very valuable in understanding what is happening with the turbo.
there's plenty of info on this out there if you are really interested........but to answer the original question...............a more restrictive exhaust setup (ie...stock cats, mufflers, piping) with result in HIGHER "boost" readings.
Old Feb 8, 2009 | 09:36 AM
ttg35fort's Avatar
ttg35fort
Professional
Hi QuadCam:
Makes sense: Same turbine speed + more air flow = lower pressure. I should have thought about that (but I didn't). Thank you for the clarification.
I'll delete my post since it is inaccurate. Glad you're checking!
Old Feb 8, 2009 | 11:22 AM
cwylie's Avatar
cwylie
OK that is what I was thinking. So I think I have a boost leak. What boost have people been seeing with the vortech and the 3.12 pulley.
Old Feb 9, 2009 | 06:36 AM
rcdash's Avatar
rcdash
When I added cats to my setup, boost pressure (no bc, internal WG springs) was 8 psi. It was 9.3 psi before that (no cats). Back to no cats. Expensive experiment.
Old Feb 9, 2009 | 08:14 AM
350Z400rwhp's Avatar
350Z400rwhp
I hit 10 psi with the 3.12, no cats and a stock exhaust. I was missing one of the bolts in the intercooler during tuning that I later found missing but boost didn't seem to change much but now I need a retune I'm sure.
Old Feb 9, 2009 | 06:25 PM
QuadCam's Avatar
QuadCam
determining actual airflow on a turbo car is harder than with a belt driven blower. you have no idea what your impeller speed is for a given setup to produce a certain boost reading in your manifold.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
