Oil Return line ?
Old Feb 16, 2009 | 08:29 PM
NiZMo1o1's Avatar
NiZMo1o1
Default Oil Return line ?
Question for the guys that are on boost,
where does your return line sit ?
If anyone has any picture or details could you please post em up?
Thank you in advance
Old Feb 17, 2009 | 01:01 AM
chopperman's Avatar
chopperman
Which kit?
Old Feb 17, 2009 | 04:56 AM
westpak's Avatar
westpak
SFZCC
^+1 it could be lineS if twin
Old Feb 23, 2009 | 05:22 PM
NiZMo1o1's Avatar
NiZMo1o1
im doing a custom kit , I was just curious where your return lines run to ?
Old Feb 23, 2009 | 09:10 PM
fstrnldr's Avatar
fstrnldr
A lot of the kits, APS TT, GReddy, JWT, probably others i am forgetting, return the oil either into a spacer, or lower oil pan replacement. This is in my opinion not ideal since it is below the oil level, making gravity draining of the oil from the turbo more difficult. The GTM, Turbonetics and Vortech SC systems all return into the upper pan. This will allow an unrestricted drain from the turbo into the pan. There are yet a few other kits, APS single, and i believe speed force racing, that use a scavenge pump because the turbo are to low to allow any sprt of gravity drain back. If i were doing a custom set up i would follow the GTM/Turbonetics/Vortech method. You should be able to find online instructions on most if not all of those to get an idea of where they drill and tap the pan.
Old Feb 23, 2009 | 09:36 PM
jeffie7's Avatar
jeffie7
https://my350z.com/forum/forced-indu...install-5.html
I went into the spacer, I didn't like the idea of drilling my block.
Old Feb 24, 2009 | 06:17 AM
GreenGoblin's Avatar
GreenGoblin
We welded some an fittings to my upper pan, above the oil level
Old Feb 24, 2009 | 06:26 AM
BoostedProbe's Avatar
BoostedProbe
My is in the upper oil pan, above the oil line level when at max:
<a href="http://s137.photobucket.com/albums/q204/1997KLDE/?action=view&current=Turbobuild002.jpg" target="_blank"><img src="http://i137.photobucket.com/albums/q204/1997KLDE/Turbobuild002.jpg" border="0" alt="Oil drain"></a>
This is a remote mount turbo setup with a scavenge pump.
Old Feb 24, 2009 | 09:19 AM
rx7/350z's Avatar
rx7/350z
Mine goes into the fitting on the pe oil pan with my vortech kit. It's still going to gravity drain back to the oil pan but you will always have a level of oil in your return oil line. It's never going to see pressure as long as your oil return nipple on your supercharger/turbo is higher than the oil level in the pan.
Old Feb 24, 2009 | 03:01 PM
Car vs. Driver's Avatar
Car vs. Driver
Here's mine.
The hole ..
The line hooked up ...
Old Mar 28, 2009 | 06:05 PM
NiZMo1o1's Avatar
NiZMo1o1
Question for those who has run the spacer, do you run an extra QT of oil ?
Old Mar 28, 2009 | 10:36 PM
streetzlegend's Avatar
streetzlegend
What you doing hiding here at the Z forums huh? lol working on something classified for the maxima peeps lol. If this is going to be a RMT, you can return the oil through an oil cap, just get yourself a metal cap (they sell em at discount), drill/tap and put a barb on it. Thats how iv had it for 2+ years, no issues at all. Obviously this is, if your using a scavenge pump. If not, and then i strongly recommend tapping the upper pan, less restriction as oil will just fall right in. lower pan, there's oil sitting down there, might work but why have to deal with the possibility of it backing up on you.
