Powerlab Kit
Old May 22, 2009 | 09:30 PM
  #81
gotagetmyZ's Avatar
gotagetmyZ
Hey guys what do you all think of the relocation of the coolant reservoir. Does anyone see a problem with where I positioned it. The bumper barely clears it but it works. Too bad I won't be able to check it easily.
This is where I placed the MBC
This is where it Y's off to wastegate and MBC
Anyone know if this is an O2 for a wideband other than the TXS one. It came with the kit but I have no idea what its for. I have everything connected but have this left over.
The one on the right is the one I'm using for the TXS. The one on the left is
Female end
Looks almost the same
Old May 23, 2009 | 05:54 AM
  #82
frankie945's Avatar
frankie945
^^ That is the old style bosh O2 sensor. I have one of those too. Just can't use it with anything.
Old May 23, 2009 | 09:19 AM
  #83
gotagetmyZ's Avatar
gotagetmyZ
Cool Frankie! I guess I can discard it.
Old May 23, 2009 | 10:51 AM
  #84
marra23's Avatar
marra23
nice idea, looking good
Old May 23, 2009 | 11:24 AM
  #85
frankie945's Avatar
frankie945
If you have a turboxs tuner. I have the cable that connects to that wideband If you still want to use it. You can have it just let me know.
Old May 24, 2009 | 06:11 PM
  #86
txshldm's Avatar
txshldm
B8BB8B88
hey OP, relocate that line that goes to the intake. You might be able to see how I did it. Under the headlight I believe.
Old May 24, 2009 | 06:56 PM
  #87
gotagetmyZ's Avatar
gotagetmyZ
Thanks TXSHLDM, I noticed that it was being pinched a tidbit the way I had it so it makes sense. I'll buy longer hose and reroute it.
DRock
Old May 25, 2009 | 06:40 PM
  #88
jaminkid's Avatar
jaminkid
I had to do the same thing on mine. Didn't seem like it would pinch but not sure when things get heated. So I rerouted mine under the headlight. Nice process so far. GL with you have left!!
Old May 25, 2009 | 08:17 PM
  #89
gotagetmyZ's Avatar
gotagetmyZ
Well guys, Finally cranked the car today. I'd post the vid but for some reason when I play it, no sound comes out. I'll keep trying to figure it out. It turn on fine and everything. All my lights were on inside. How normal is that.
I haven't had a chance to load the base map for the UTEC. I Truthfully just don't know how. I'm gonna read the UTEC manual and see if I can figure it out. I do not even know how to or where to hook up my laptop to. Need some help please! Anyone willing to walk me through it? Maybe there is a link I can view. I just want to load the 550 map so I can drive it to the tuner. I don't want to tune it or anything else. There should be a few maps from the previous owner but not sure if I even want to use those. His was an 06 and mines an 03.
I guess for now, I'll keep trying to figure out the process. I hear its easy but when you just don't know....well, you don't know.
Old May 26, 2009 | 04:53 AM
  #90
GT-ER's Avatar
GT-ER
if you bought a gt37r kit then i am sure you got that kit.
The gt37r is actually not an off the shelf garrett part, its custom made by Full-Race. http://www.full-race.com/catalog/pro...5a6b6d1012a213
now its basicall ya modified gt35r, so you might get that box, it could be deceiving, but check the link
you could try to get the ST version... that is a titanium JIC mufler and the rest of piping is ~3" SS....they also have an all SS version too ...greddy has a i think some options for you...aam has some too i think
Actually the GT37R IS an off the shelf Garrett turbo. It's a T67 with a P-trim turbine wheel. The GT3582R is a completely different turbo. A lot of companies use this same identical turbo but change it's name to be "different" but it's the same turbo. The different names are T67 ( comes both journal and BB ), PT6776 ( comes both journal and BB ), T04Z ( BB ), T04R ( Journal ) and GT37R ( BB ). God knows what other names they have given it. The turbo in question is indeed a GT3582R.
I kinda chimed in late huh? lol...
Old May 26, 2009 | 12:56 PM
  #91
gotagetmyZ's Avatar
gotagetmyZ
LOL
Its never too late. Thanks for the insight.
TXS Technical support just became my new best friend.
Old May 26, 2009 | 08:10 PM
  #92
gotagetmyZ's Avatar
gotagetmyZ
Here's a quick vid of the startup. Check it out!!
http://www.youtube.com/watch?v=a-YFLYtMHHA
Old May 27, 2009 | 12:17 PM
  #93
Kuwait350z's Avatar
Kuwait350z
sounds good
Old May 27, 2009 | 12:31 PM
  #94
jaminkid's Avatar
jaminkid
Sounds good bro! What exhaust?
Old May 27, 2009 | 07:28 PM
  #95
gotagetmyZ's Avatar
gotagetmyZ
No exhaust on that vid. Thats why its so loud. I'm gonna do a 3" JIC single w a 3" Vibrant Resonator and 3" piping all the way. I'll borrow my buddys' exhaust for the meantime just to get it tuned.
DRock
Old May 27, 2009 | 07:40 PM
  #96
Chef-J's Avatar
Chef-J
Booooosstt!!
Sounds good, that's how mine sound when i didn't have an exhaust. Good luck man!
Old May 28, 2009 | 05:01 AM
  #97
marra23's Avatar
marra23
if your running 600cc injectors edit map 0% column 500,750,1000rpm -16-15's....you'll have much better trip to your tuner. worked for me.
Old May 28, 2009 | 07:35 AM
  #98
ATX350's Avatar
ATX350
Hey gotaget, I bought the kit on Tuesday so pm me your number so I can meet you at the tuner you decide on if you don't mind. I'd like to check the kit out visually and take mad pictures if possible. Glad to know your build is coming along.
Old May 28, 2009 | 12:16 PM
  #99
gotagetmyZ's Avatar
gotagetmyZ
Definitely man, your install should be smoother than mine since its new. I ran into so many problems with mine along the way because stuff was missing, stripped treads, ect......
I'm glad it almost over. I'm having trouble picking up signal for the connection to my laptop/tuner. Time to call TXS Tech support
Thanks, I'll look into that.
Old May 28, 2009 | 12:18 PM
  #100
ATX350's Avatar
ATX350
^sweet thanks, you have PM.
