FI Roadster Counterweight
Old Apr 25, 2009 | 04:52 AM
Netacoma2003's Avatar
Netacoma2003
Default FI Roadster Counterweight
If anyone has installed a Vortech in a roadster they know you need to remove the OE "counterweight" for clearance reasons.
Other than slowing the Z down and wasting fuel, does anyone know what function Nissan designed this 40 pound monstrosity to serve?
Debating on what to do with it.
Old Apr 25, 2009 | 05:44 AM
Fairlady_z33's Avatar
Fairlady_z33
I think its used for weight distribution since the convertible top adds more weight. Thats the only thing that comes to mind if im wrong someone correct me.
Old Apr 25, 2009 | 06:46 AM
QuadCam's Avatar
QuadCam
where was that bolted on?
Old Apr 25, 2009 | 08:58 AM
INTIMAZY's Avatar
INTIMAZY
Talk about a band-aid approach to weight distribution!
Old Apr 25, 2009 | 07:24 PM
QuadCam's Avatar
QuadCam
it may not be for weight distribution. I recall ford using some odd weight in their convertible mustangs too. I think it had something to do with the chassis harmonics.
Old Apr 26, 2009 | 10:41 AM
specialized5223's Avatar
specialized5223
my guess was to aid in factory corner balancing or harmonics as well. there are two in the roadster and i removed both of mine with no noticed ill effects.
Old Apr 26, 2009 | 12:21 PM
Netacoma2003
Sounds like I need to crawl underneath and find the other one. Any hints?
Old Apr 26, 2009 | 02:26 PM
specialized5223
its in the trunk hiddin in towards the right corner behind all of the plastic trim. its difficult to get out. EXTREMELY. I was stripping my trunk of my Z and found it. I attempted to remove it but it was hald welded half riveted in place. I literally had to cut it out. The front is a simple unbolting but not this one. You'll likely break tabs on that trunk trim too. Be careful and I would let it go if this is not your track car...
Old Apr 26, 2009 | 06:47 PM
r0mey's Avatar
r0mey
i removed mine 2 years ago.
Old Apr 27, 2009 | 10:14 AM
Netacoma2003
To bad Nissan adds all this dead weight but it sounds like I better leave it alone. I assumed the Roadster was heavier than the coupe because of the drop top assy, motor, etc....only to find out they added these boat anchors.
Thanks for the tips.
Old Apr 28, 2009 | 12:13 AM
bbs350z's Avatar
bbs350z
wtf is that? throw it away!
Old Apr 28, 2009 | 06:55 AM
GreenGoblin's Avatar
GreenGoblin
lol the boat ancor
Old Apr 28, 2009 | 08:57 AM
Laps's Avatar
Laps
I removed both of them saved 20kg in weight
Old Apr 28, 2009 | 12:12 PM
specialized5223
It is heavier because of that stuff. My top, frame, motors, tonneau motors, and more have all been removed to drop weight. And the car still has a fat ***...
MAsSIVrOOM
Oct 20, 2023 10:50 AM
jlb
Oct 15, 2017 05:10 AM
416blueZ
Sep 25, 2015 10:00 AM
Zergfest
Sep 23, 2015 06:03 AM
