APS Single turbo setup with GTM upgrade...need help
Old Jun 21, 2009 | 07:32 PM
travismaser's Avatar
travismaser
Default APS Single turbo setup with GTM upgrade...need help
so bought the APS Single turbo setup a lil while back and i think the turbo was bad right from the get go because it would smoke alot...well the smoke got worse and worse over the past 4 months and i finally just went and replaced it with the GTM GT35R turbo upgrade with a Tial 44mm wastgate...well that stopped the smoke...but now im having a problem with boost, after 5,000 RPM's i am going from 10-11PSI to 2PSI??? we tryed adjusting the boost controller (Blitz SBC ID) on the dyno and still nothing?
i checked for boost leaks but found nothing...and the only other thing i can think of would be the wastgate??? i have a 9PSI spring in it...would it be opening on its own at high RPMs?
i would think that that GT35 would be SKREAMING in the higher end right?
P.S. i put 394 torque and 328 wheel on a dynojet...im thinking my HP should be WAY higher if the boost would stay flat throughout the gear
im at work right now but when im off ill post up my dyno sheet...
do you guys have any ideas at what my problem could be?
Old Jun 21, 2009 | 09:09 PM
Asad_A203's Avatar
Asad_A203
Forge Boost actuator maybe ?
http://www.forgedperformance.com/sto...1&cat=0&page=1
Old Jun 21, 2009 | 10:00 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Most likely the inlet hose (# 7 on the aps list ) is collapsing under boost , basically the turbo is sucking the hose and shutting the air flow .
Call me if you need any further assistance
Sam
blueper4mancez's Avatar
blueper4mancez
asad he has tial wastegate .
Old Jun 21, 2009 | 11:29 PM
nightcrawler_8's Avatar
nightcrawler_8
i dont think he is using any actuature. he got the external wastegate.
+1 for what SAM@GTM said, it must be the intake tube that get collapses when high boost.
one more thing, why are u on 9 PSI spring? go for the 9 to 15 psi spring and control it with the boost controller to be all the time on the range fo 9 to 10 psi.
good luck
Old Jun 22, 2009 | 05:14 AM
travismaser
Sam
wow...well i guess that makes alot of sence...looks like ill be fabing up a new intake haha
Old Jun 22, 2009 | 05:52 AM
QuadCam's Avatar
QuadCam
Originally Posted by Asad_A203
He is running an external wastegate (tial 44mm)......there is no place (or need) for a forge actuator in this setup.
EDIT: I just noticed that 2 others already said the same thing as me. lol.
Old Jun 22, 2009 | 01:10 PM
Asad_A203's Avatar
Asad_A203
^ Whoops sorry didn't notice that. I wasn't being sarcastic though, I honestly was not sure, haha.
Old Jun 22, 2009 | 02:55 PM
UMW350Z's Avatar
UMW350Z
what is that collapsing pipe made of...plastic????
Old Jun 22, 2009 | 10:26 PM
nightcrawler_8
rubber.
there is two rubbers,, one for the turbo inlet and the other for the intake..
one is longer than the other. u have to make sure that the longer one is for the intake and shorter for the trubo inlet.
( correct me if am wrong SAM )
Old Jun 22, 2009 | 11:04 PM
travismaser
thats what it looks like...im just going to weld up a hard pipe...that way ill never have a problem again
ill let you guys know if it solves the problem
Old Jun 22, 2009 | 11:22 PM
nightcrawler_8
i believe its this one...
Old Jun 23, 2009 | 06:45 AM
travismaser
well i went ahead and did some testing today and it was infact the intake tube (the black hose that looks like an acordian) that was causing the problem...i just removed it and took the car for a ride running open turbo..
IT RUNS AMAZING NOW!~! it holds 11psi flat the whole way to redline! i cant wait to get it back on the dyno and see what numbers im running now
thanks alot Sam for the info!!!
Old Jun 28, 2009 | 01:28 PM
travismaser
this is the dyno sheet after i took the intake tube off! WAY better! thank you sam!!
Old Jun 28, 2009 | 02:27 PM
tig488's Avatar
tig488
good job, i noticed that also, that piece just collapses on itself under higher boost.
Old Jun 28, 2009 | 02:57 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Thats what im talking about man.........sweet numbers and i bet it feels like a different car now.
Old Jul 12, 2009 | 10:37 PM
zads's Avatar
zads
Hey guys, I'm getting ready to install a stock APS ST kit, has anyone had or heard of problems with this intake pipe collapsing using the "stock" turbo (non- GTM upgrade)?
If so, I might as well fab up a hard pipe during installation instead of messing around with the rubber/plastic one.
Thanks!
Old Jul 13, 2009 | 10:24 PM
nightcrawler_8
Thanks!
i would suggest you to do that.
Old Jul 14, 2009 | 12:54 PM
terps's Avatar
terps
11.7psi and only 400hp, thats kinda low hp for the booost
Old Oct 21, 2009 | 09:42 AM
Currin's Avatar
Currin
hey op, talked to you awhile back.
but jsut got the car running with aps single (non gtm upgrade) and i made 412hp and 442 tq(the torque was from a different run/pull that only made 396hp) at 10 psi, i got a dyno sheet i can upload tonight cause i know how most people say its a fail without proof,
but have you made any higher hp? sence you got the gtm upgrade?
