GTM turbo kit feedback thread
Old Sep 4, 2009 | 07:05 PM
  #101
derekinthez's Avatar
derekinthez
The GTM kit looks top notch. Interesting thread . . . let's see where this goes
Old Sep 5, 2009 | 09:19 PM
  #102
nathanwl2004's Avatar
nathanwl2004
Just out of curiousity does the stage 1 turnkey kit with the Osiris tune throw a cel code?
Old Sep 5, 2009 | 09:41 PM
  #103
350z 6spd's Avatar
350z 6spd
^ no
Old Sep 6, 2009 | 04:13 AM
  #104
ryan350zpower's Avatar
ryan350zpower
does anyone have driving videos yet of this kit on their HR??
Old Sep 6, 2009 | 08:49 PM
  #105
midz350's Avatar
midz350
^^ Do you want acceleration (Speedometer) videos or from outside the car?
I will do it for you this week.
Old Sep 6, 2009 | 10:09 PM
  #106
JWS82's Avatar
JWS82
you should do both...
Old Sep 7, 2009 | 05:34 AM
  #107
ryan350zpower
I would love to see outside the car videos like crazy.... butt, if you can do both, i wouldnt say no :-D :-D
Old Sep 8, 2009 | 01:32 PM
  #108
midz350's Avatar
midz350
OK.. will do both.
Old Sep 9, 2009 | 10:28 AM
  #109
homeboynyc's Avatar
homeboynyc
i saw you had said something about an oil restricter on a gtm tt turbo kit. i have an aps tt kit and it wasn't smoking before with the factory engine, swapped out for a built bottom block engine and still was fine, then i bought a AAM 3" true dual for my 2.5" hks true dual and now for somereason it starts smoking a little, i checked everything and it was fine, but i did correct my return lines cause they had a few kinks on them, it stopped smoking like before, now it just does it from time to time, just a little. any suggestions??
oh and by the way i have not drove the car hard as i am still in break in period and have not tunned the car yet. so there is no way the turbo can get messed up'ed by just changing the exhaust!
Old Sep 13, 2009 | 08:58 AM
  #110
fla350tt's Avatar
fla350tt
Originally Posted by George@GTM
Jason,
I am truly sorry about your situation and can relate to your problems based on experiences with my own car. Unfortunately things don't always go as planned and the project keeps getting delayed - sometimes there are things that we cannot control.
I am sorry one of the turbos were incorrect, we were very busy and somehow missed that Garret had sent us a mis-matched set. It was our fault, and we will be more careful to make sure it never happens again. We will PayPal you the $13 for shipping that it cost you to ship back the part.
As far as these other fitment issues this is the first we are hearing of them, we haven't had any other complaints and would appreciate as much feedback as possible so if there is a problem we can correct it ASAP.
We have revised our intake piping since the original kit and would be glad to send you the revised piping to make you happy, although I don't think it will at this point. When we received your turbos we had them inspected ASAP, they were tested, with out oil restrictiors, and they are perfectly fine - no oil is passing through the seals. It was odd that both turbos would be bad.
So as you can see, the issue that has gotten you so frustrated is out of our control as well - the product is fine and has no defects, this could only lead to and installation issue or some other odd coincidence at play.
Your drain lines could be too low, if you were trying to get a better angle than what we have in the instructions by placing the return lower in the pan it could be causing the oil to back up in the turbo. Another cause could be that your crank case is being pressurized and blowing oil through your PCV into the intake track. What ever the cause it was not a faulty turbo as we all thought.
As you can see this is a bad situation for us as well, because now you are unhappy with us because of something that was beyond our control.
We are still here to help if you need anything, just let us know - our number one priority is your satisfaction.
P.S. Please don't take this as us putting the blame on you or anyone, we just want you to understand our perspective.
-George
GT Motorsports
I must add my 2 cents here. I have the stg 2 w/ open dump and was questioned by Sam if I had problems with the install of the right side waste gate tube. And yes I did have to beat the wastegate tube flat to get it installed.Then the wastegate was rubbing against lower control arm on passenger side. And other items were 2 ic piping clamps. intercooler bracket mounting bolts were to short for new aluminum brkt. and down pipe flange and gasket had to be dremelled also. So some one did know of the problems. My heart beat is very rapid right now to hear about the problems still exsist and you have no idea of the installation problems. I really do not want to bash here but I did have problems getting a call back at times to get the issues solved in a timely manner. Ground shipping the clamps sucked when that was all I needed to finish my install. But I will say that the performance of the kit made me forget about the little problems in the end. Let me repeat myself 500hp @ 12psi and I only run 8psi trying to keep tires from spinning but there is no stopping that. And for informational purposes if George does read this, the only way I could fix the problem with the wastegate tube was to cut it and reweld. And in the long run of the installation put a good clutch in before the turbo kit. you can not get transmission out once the kit is in,so when the stock clutch went in 200 miles, I pulled off the drivers side exhaust piping and the passengers side wastegate tube,installed twin disk, and cut both wastegate tubes cut tubes in half added flanges so the next time the trans. could be removed without taken the whole drivers side exhaust out. Which happens to be the worst area to get to.
Old Sep 13, 2009 | 11:13 AM
  #111
MaRbLe's Avatar
MaRbLe
Just got the car back....reviews soon.
Old Sep 15, 2009 | 05:53 AM
  #112
ryan350zpower
any video updates yet???
Old Sep 15, 2009 | 10:34 AM
  #113
midz350's Avatar
midz350
I didn't forget you,actually I was about to take the videos and pics to start my thread last night with my friend evo but he got into a small accident coming out of the last roundabout going to our favorite and isolated street so will try to do it tonight
Old Sep 15, 2009 | 11:25 AM
  #114
SmallTuner's Avatar
SmallTuner
good im waiting allso
Old Sep 20, 2009 | 06:01 PM
  #115
ryan350zpower
i cant wait! this may determine my purchase...
Old Sep 23, 2009 | 01:06 AM
  #116
midz350's Avatar
midz350
I did the videos today and just waiting for my friend to downloading them from his cam and send them to me later today.stay tuned.
Old Sep 25, 2009 | 01:02 AM
  #117
midz350's Avatar
midz350
They are here:
driveby:
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/HNWlrJ7Prgo&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/HNWlrJ7Prgo&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
80-210 km/h acceleration:
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/fo1w-wrjZIs&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/fo1w-wrjZIs&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
100-240 km/h acceleration:
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/xPPxZNh6v2s&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/xPPxZNh6v2s&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
Old Sep 25, 2009 | 03:27 AM
  #118
SH Luciano's Avatar
SH Luciano
i hope your check engine light was on for something minor when you were blasting on your car...
Old Sep 25, 2009 | 04:54 AM
  #119
Germanguy's Avatar
Germanguy
what is that scratching after you shifted from 3rd to 4th at max rpm ? : /
Old Sep 25, 2009 | 06:20 AM
  #120
Blck350z's Avatar
Blck350z
sounds great!!! .... aside from the clanking/scratching^^^, hope that was just the camera.... also i'm glad to see you did that with no one on the road... shows some common sense!! CONGRATS!!!!
