20g potential
Old Apr 2, 2010 | 06:46 AM
  #281
SoundPerformance's Avatar
SoundPerformance
Sound Performance
Originally Posted by IslandZavage
was the original harness long enough or did it have to be modified to place it there? pix?
Yes, we make all 128 harnesses long enough to place the computer under the passenger seat.
Old Apr 3, 2010 | 12:57 AM
  #282
rrmedicx's Avatar
rrmedicx
Originally Posted by eltness350
just amazing guys!! i still think u should do a seperate "shop build" thread for this!! u deserve it!!!
+2.
Old Apr 3, 2010 | 03:21 AM
  #283
*Boose*'s Avatar
*Boose*
Damn what a thread. I just went through every post.
Old Apr 3, 2010 | 03:40 PM
  #284
Reid@SP's Avatar
Reid@SP
LOL I can't believe Larry left the amp disconnected. At least you had the sound of the dump tubes and turbos spooling to keep you occupied
Reid
Old Apr 4, 2010 | 12:04 PM
  #285
rrmedicx's Avatar
rrmedicx
Yes that 6 cylinder turbo symphony was really rocking the house down! =)
Old Apr 5, 2010 | 06:24 AM
  #286
str8dum1's Avatar
str8dum1
can you repost what exhaust and clutch you are using.
Old Apr 5, 2010 | 06:47 AM
  #287
rrmedicx's Avatar
rrmedicx
SGP 3" Downpipes into Greddy TT exhaust with Bottleneck removed.
edit***Open Dump Wastegates...
Clutch is a OS Giken twin disk clutch
Old Apr 22, 2010 | 08:04 AM
  #288
thom000001's Avatar
thom000001
Took this from Supraforums.com (but its a GTR build).
This would be basically the extreme limit of what the 20G's can do I'd say (since the GTR heads flow better anyway than ours)
Originally Posted by from Supraforums.com;
This is a build that we are working on.. I know this is Supra Forums but.. I know a few ppl on here might find this interesting
2010 R35 10K miles
The plan: 20G Turbo's / Tubular Manifolds / External W/G / Upgraded Intercoolers / Haltech R35 Probox / Cobb (Control Transmission limiter) / Custom Fabricated Exhaust
Pump:
Race gas 25psi:
Tom
Old Apr 22, 2010 | 08:27 AM
  #289
rrmedicx's Avatar
rrmedicx
So that's what a set of real 20G's (non-hybrid) can do. Nice. And with Tubular manifolds.
I wonder who made those? Custom? any idea?
Old Apr 22, 2010 | 08:32 AM
  #290
thom000001's Avatar
thom000001
Looks like that shop built them.
But I'd say this would be the ideal situation for 20G's when comparing them to our motors (this would be a fully ported head, bigger valves, big cams, tubular manifolds, etc).
Tom
Old Apr 22, 2010 | 09:27 AM
  #291
TwoFiveBar's Avatar
TwoFiveBar
SPE's GT-R put down 866awhp/849awtq with the TD06SH20Gs.
2 Bar, C16.
9.6@150mph w/ Drag Radials
However, I am not sure if they are using the standard hot side (IIRC 8cm^2) or one of the larger options GReddy offers.
Old Apr 22, 2010 | 02:53 PM
  #292
meatbag's Avatar
meatbag
How much boost is the GTR running for the pump gas map?
Here are my 20g's at 18psi
Old Apr 22, 2010 | 06:50 PM
  #293
eltness350's Avatar
eltness350
The Untouchable
wow tq looks a lil low compared to my 18g's at about 18-19psi no??
http://s70.photobucket.com/albums/i1...o.jpg&newest=1
Old Apr 22, 2010 | 07:54 PM
  #294
meatbag's Avatar
meatbag
Different power band. You make peak torque sooner then I do which should be the case since the 18g's will spool quicker. Also depends on your cams, manifold, etc......
Old Apr 23, 2010 | 05:00 AM
  #295
rcdash's Avatar
rcdash
Holy crap nice - how much boost was that? Tell me that was done in the winter in ATL! If it was during hot weather, you can easily add 15% to compare to Dynojet STD. In cold weather with no correction on Sharif's DD dyno, the readings are more comparable depending on how cold...
Old Apr 23, 2010 | 05:08 AM
  #296
rrmedicx's Avatar
rrmedicx
BTW, are those the real 20G's or Hybrid like mine (upgraded by Forced Performance). Also do you use the upgraded inter-cooler and associated cold side piping? Thanks.
Old Apr 23, 2010 | 07:10 AM
  #297
meatbag's Avatar
meatbag
they are upgraded 20g's. I know the hotside is choking my motor and I am looking at getting something bigger from greddy or see what else FP can offer that will work.
All my piping is the same except the one that goes from the IC to the TB. I did redue that one with less bends and it is now a full 3" all the way. Other then that all my piping is ceramic coated on the outside with a teflon layer on the inside as well as the intake manifold and lower intake runners.
Old Apr 23, 2010 | 07:43 AM
  #298
midz350's Avatar
midz350
GReddy R35 TD06SH-20 Twin Turbo Upgrade Kit. Well we are happy to report an update. Over the weekend, they began to boost up a little more from their 706whp @ 1.45kg/cm2 to a crazy 816whp @ 1.7kg/cm2!
Not only does it make great peak power, but if you notice on the graph, the mid range is still quite good with 360whp at 3500 RPM & 520whp @ 4000 RPM...
And the guys at SP Eng, tell us they are not done yet. We can't wait to see how much they end up with!
Old Apr 23, 2010 | 07:51 AM
  #299
thom000001's Avatar
thom000001
Interesting to see where the 20G's run out of breath...
Tom
Old Apr 23, 2010 | 08:50 AM
  #300
rcdash's Avatar
rcdash
meatbag, where is your battery and what is in its place in that compartment?
Nice piping and catch can setup!
(I don't see check valve preventing boost from going backwards through the catch can - just use stock PCV I presume? So you're catch can sees 18 psi etc?)
