Another Powerlab Build on stage 2 motor
Old Nov 29, 2009 | 07:43 AM
  #61
GBoger's Avatar
GBoger
sub'd
Old Nov 29, 2009 | 06:13 PM
  #62
Alberto's Avatar
Alberto
Cranky FI Owner
Why would you want SHORTER gears especially the first 2?
I dont know enough about transmissions to properly discuss what I thought sounded like BS, Neal and Brian can do that....
I understand wanting stronger internals, but shorter ratios ouch.
Old Nov 30, 2009 | 07:49 AM
  #63
qqqqball's Avatar
qqqqball
was IOT get into the 3rd gear faster
Old Nov 30, 2009 | 10:31 AM
  #64
Alberto's Avatar
Alberto
Cranky FI Owner
You would get into 3rd gear faster if you had traction in the first 2 gears.
Old Nov 30, 2009 | 12:28 PM
  #65
Vas_Z33's Avatar
Vas_Z33
Sorry I couldnt make it.. in for the numbers!
Old Dec 1, 2009 | 08:00 AM
  #66
frankie945's Avatar
frankie945
Originally Posted by qqqqball
will definitely post result eta Tuesday the 1st of December
In for results...
Old Dec 2, 2009 | 10:56 AM
  #67
Vas_Z33's Avatar
Vas_Z33
Bump for results ..
Old Dec 2, 2009 | 12:11 PM
  #68
qqqqball's Avatar
qqqqball
Originally Posted by Vas_Z33
Bump for results ..
dyno lead to some bad results.... F*ck the cobb accessport... they says it is for a turbo setup as well as N/a ... this was not the case. Hpx maf doesn't work with cobb even though cobb will attest to this. made 230rwhp at 31.6psi@ 4000rpm ... hate when the dyno shop turns up my boost controller. have to retune on stock MAF till it peggs ( only since its a free re dyno and my A/F is 16.4 at idle.. peaks at 21.8... needless to say the car is still at dyno awaiting new time for dyno) so i can take it to another facility to get Osiris tuned. (13hour drive for closest one) Injected performance
Old Dec 2, 2009 | 12:35 PM
  #69
str8dum1's Avatar
str8dum1
31 psi? jeez
thats pretty solid. did it hold 31 psi? best ive ever seen is no wastegate reference aand that went to 29 psi but dropped to 21'ish psi by redline.
thats pretty sweet at 31psi you made less HP than stock. good luck getting it dialed in. I;d buy a UTEC for 500$ used and not mess with a reflash that is dependant on a tuner 13 hrs away.
Old Dec 2, 2009 | 12:44 PM
  #70
psychoballistic's Avatar
psychoballistic
+1, grab a utec and take it to Ray @PFS he's like 7-8 hrs from you.
Old Dec 2, 2009 | 12:46 PM
  #71
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
WAT
How in the hell is that even possible?
Old Dec 2, 2009 | 01:10 PM
  #72
rcdash's Avatar
rcdash
31 psi on pump gas or race gas? What happened to all that air if power is only 230 whp? Something is not right - hope the motor is still ok. I would recommend making the trip to Injected. Good luck.
Old Dec 2, 2009 | 01:13 PM
  #73
Jay'Z's Avatar
Jay'Z
Isnt Forged Performance closer? or try AAM?
Old Dec 2, 2009 | 01:17 PM
  #74
frankie945's Avatar
frankie945
^+1 230whp, WTF. Go to Injected Performance they will take good care of you. Worth the trip. And they will tune it the right way. You might as well pick up a good ems like a Haltech if you plan on running that much boost. I think Hal still might have a used one for sale.
Old Dec 2, 2009 | 01:34 PM
  #75
GBoger's Avatar
GBoger
dude i just can't believe that you made 230 to the wheels with that much boost. Either there is a massive leak somewhere or the motor is facked up
Old Dec 2, 2009 | 01:47 PM
  #76
frankie945's Avatar
frankie945
maybe it was only running on 3 cylinders.
Old Dec 2, 2009 | 01:51 PM
  #77
Resmarted's Avatar
Resmarted
Z06 gears in vq tranny.... ok thats a SERIOUS stretch.
600cc inj for 600whp+?.... ok wtffff
COBB ACCESS PORT?...... WHAT IN GOD'S NAME.......
OP, I want to give you benefit of the doubt, but it seriously sounds like you don't know what the f*** is going on.
And how are you running 31psi on a gt37, while only 230whp? I get the feeling somethings are seriously wrong somewhere........ ill stop here before i start saying truly bad things.
Old Dec 2, 2009 | 02:09 PM
  #78
350Z400rwhp's Avatar
350Z400rwhp
I want to give you the benefit of the doubt too but seriously wtf?
Old Dec 2, 2009 | 03:32 PM
  #79
Vas_Z33's Avatar
Vas_Z33
Id grab a Utec and go to Ray
Old Dec 2, 2009 | 03:43 PM
  #80
GBoger's Avatar
GBoger
haha it should still be putting out like ~300whp
