my 2011 and Beyond! build thread.
Old Aug 24, 2011 | 08:27 AM
  #401
dikspiel's Avatar
dikspiel
Chestons Toilet
They told me 1.10 will be out in a week
We also have the new CAN based I/O12 expander, which will expand the capabilities of the 350Z ECU platform, adding 4 digital outputs, a 4 digital inputs, and 4 analouge inputs. These will work with the 350Z ECU with the release of ECU Manager 1.10, which should be within the next week.
Old Aug 24, 2011 | 10:55 AM
  #402
dikspiel's Avatar
dikspiel
Chestons Toilet
updated build list
Motor:
Cosworth 8:8.1 Pistons +10mm over **
Nissan OEM Piston Rings +10mm over
Carrillo H-Beam Rods (NI-Q35>-65676H-0) **
ARP Main Studs
ARP L19 Head Studs **
Cosworth Head Gasket (not sure which thickness i need)
ACL Main Bearing Set
ACL Rod Bearing Set (not sure if needed, please advise)
ACL Thrust bearing
Cosworth Oil Baffle
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
Fuel:
Cosworth Fuel Rail Kit **
CJMotorsports RFS Stage 0 (modified to work with the Cosworth Kit)
Walbro LPH255 (may upgrade to a lph300 dw) **
DW 850cc injectors **
** means already purchased.
Should I mess with the pulleys? ATI crank pulleys are pretty pricey so I don't know if its worth it. Maybe just a standard size lightweight pulley set?
What about the IP Billet Block Girdle? Should I buy one?
Also will be getting the Cosworth or Nismo thermostat, Pathfinder Coolant mod, and maybe a new revup oil pump.
Old Aug 24, 2011 | 11:16 AM
  #403
DaveJackson's Avatar
DaveJackson
Master
Originally Posted by dikspiel
Why would you put that in the cubby? That is a full gauge cluster replacement and should be right in front of you when driving...
Oh, I guess you're right. I was thinking of it as a comprehensive set of supplementary gauges rather than primaries, too. I hope you get some of that sweet hockey tape with yours, too!
Old Aug 24, 2011 | 12:08 PM
  #404
rcdash's Avatar
rcdash
Thank you for that update!
If you plan on revving past 7500 rpms, I would get the girdle.
Old Aug 24, 2011 | 01:04 PM
  #405
GreenGoblin's Avatar
GreenGoblin
Wow that is exciting that 1.10 is coming out. Looking fwd to some new possibility with the i/o box
Old Aug 24, 2011 | 04:14 PM
  #406
midz350's Avatar
midz350
You need to get a new revup oil pump. you wouldn't want to use the old one.
The ACL Rod Bearing Set is not a must, but they are only for $80 at IP so why not.
Old Aug 24, 2011 | 04:33 PM
  #407
dikspiel's Avatar
dikspiel
Chestons Toilet
my old one is a revup oil pump fyi i have a revup
Old Aug 24, 2011 | 05:41 PM
  #408
midz350's Avatar
midz350
Every time you disassemble the engine you should get a new oil pump and a new set of engine gaskets.
Old Aug 24, 2011 | 06:02 PM
  #409
dikspiel's Avatar
dikspiel
Chestons Toilet
ur not my dad stop telling me what to do
Old Aug 24, 2011 | 06:13 PM
  #410
midz350's Avatar
midz350
Can I be your sugar daddy
Old Aug 25, 2011 | 07:47 AM
  #411
dikspiel's Avatar
dikspiel
Chestons Toilet
Got this update today!!!!!!!!!
Good news today. Haltech AU has completed the inspection and repair of your ECU and harness, and have shipped the unit back to Haltech USA. It is en route via FedEx and scheduled to arrive 29 Aug to this office. Pending there are no FedEx import clearance delays, I’ll make sure you have the unit back in your hands by mid next week
Old Aug 25, 2011 | 09:16 AM
  #412
str8dum1's Avatar
str8dum1
any news on what the issue was?
what was the original issue again?
Old Aug 25, 2011 | 09:21 AM
  #413
dikspiel's Avatar
dikspiel
Chestons Toilet
The original issue was that when on the dyno it would not pull timing correctly. Oh and I don't know what was the cause.
Old Aug 25, 2011 | 10:23 AM
  #414
dikspiel's Avatar
dikspiel
Chestons Toilet
str8dum1:
A problem in the Harness, I don’t know exactly the specifics
We’re including a new harness. I think you had one of the original harnesses, which didn’t have wideband connector breakouts built into the harness. You’ll need to rewire your widebands to the new style wideband input breakout connectors when you install the new harness.
Old Aug 26, 2011 | 02:13 PM
  #415
dikspiel's Avatar
dikspiel
Chestons Toilet
Update:
Today I ordered a CJ Motorsports Stage 0 Fuel Setup, Nismo Theromstat, and ARP Main Studs.
My haltech will be next week assuming there is no delays with customs.
Old Aug 26, 2011 | 04:39 PM
  #416
dikspiel's Avatar
dikspiel
Chestons Toilet
Also ordered a Aeromotive 340lph Steathl fuel pump. Figured i'd replace the walbro 255lph.
Old Aug 26, 2011 | 04:50 PM
  #417
Ruthless18x's Avatar
Ruthless18x
We are pump twins!
Old Aug 26, 2011 | 06:48 PM
  #418
Ruthless18x
You're too old and bald for me.
Old Aug 27, 2011 | 10:51 AM
  #419
dikspiel's Avatar
dikspiel
Chestons Toilet
bald is beautiful...how old do you think i am?
Old Aug 27, 2011 | 10:59 AM
  #420
Flo-ridaZ33's Avatar
Flo-ridaZ33
Shane I'm going bald too... Hopefully I get my Haltech within the next couple of weeks. It looks like I'll be home earlier than expected soooo my build could be finished by the 2-3 week of Oct. I didn't know about the Aeromotive pump either... damn it.
