my 2011 and Beyond! build thread.
Old Aug 31, 2011 | 10:21 AM
  #441
dikspiel's Avatar
dikspiel
Chestons Toilet
Scheduled to visit the tuner on Friday.
Old Aug 31, 2011 | 02:52 PM
  #442
dikspiel's Avatar
dikspiel
Chestons Toilet
ARP Main Studs
Nismo Thermostat
Extra set of 1 step colder spark plugs just in case
Old Sep 2, 2011 | 05:22 PM
  #443
dikspiel's Avatar
dikspiel
Chestons Toilet
So today's tuning session was a failure but at least my demons are near finished (i hope). Seems I have a very tiny fuel leak somewhere (maybe the fuel rails?) as well as a maybe a bad injector. I know I mentioned I may have an injector issue before but I wanted to wait until I had both of my widebands functioning again to see if one of my banks was going lean as shown by the stock sensor.
I drop my car off at GearHeinz on Tuesday and he is going to pull the injectors and send them to DW as well as fix any fuel leak.
Old Sep 2, 2011 | 07:06 PM
  #444
str8dum1's Avatar
str8dum1
fuel leak? bad injector?
you need to find a new shop ASAP, no disrespect. fuel leaks are super easy to find.
what are your issues? dont waste the money sending the injectors back. they never come back bad. Not once. Quick search will verify that
Old Sep 3, 2011 | 04:58 AM
  #445
GreenGoblin's Avatar
GreenGoblin
check the o-rings on the injectors one could have been torn.
Old Sep 3, 2011 | 06:54 AM
  #446
str8dum1's Avatar
str8dum1
if the injectors are leaking at the o-rings, you can hear it hissing when you prime the car, not to mention visually see the gas wetness.
you should always prime the fuel system before you put the plenum back on
Old Sep 6, 2011 | 07:46 AM
  #447
dikspiel's Avatar
dikspiel
Chestons Toilet
I understand what you mean, this shop im going to is only to tune my car due my original shops dyno breaking. I had paid this shop in advanced to tune my car, I chose not to let them resolve the issue since GearHeinz is the shop i will be working with in the future. There is nothing wrong with RRR Dynotuning its just I'd rather 1 shop do everything in the future (including tuning).
anyways I've been thinking about the issue and was hoping to go to gearheinz today but he just had a kid yesterday so he asked me to come next week.
When they were trying to tune my car N/A we were getting a slight misfire from injector #6 so we pulled all the injectors and #1 #2 #3 looked like it was running rich (which I expected) where as #4 #5 had much less buildup then bank 1 and #6 looked almost white. We put new plugs in and still were having the same issue. We also smelled a slight fuel leak randomly when tuning but there was nothing leaking on the ground and I have had no issues with gas mileage.
Seems to me that either the fuel rail is leaking or the pressure into that rail is not sufficient.
Old Sep 6, 2011 | 08:41 AM
  #448
dikspiel's Avatar
dikspiel
Chestons Toilet
Old Sep 6, 2011 | 03:10 PM
  #449
binder's Avatar
binder
i looked on the front page and didn't see what type of fuel system you have. If it's one of the main return kits then your fuel feed is at the back of the rails and the first cylinders to get the fuel would be 5 and 6. If there were a leak then 6 would have the most fuel and as it goes forward wouldnt the cylinders lack fuel therefore making cylinder 2 leaner than 6? That's backwards as to what you have for results.
Old Sep 6, 2011 | 03:30 PM
  #450
dikspiel's Avatar
dikspiel
Chestons Toilet
I just have Cosworth Fuel Rail Kit installed at the moment though I have CJM's Stage 0 waiting to be delivered...I'll probably have that installed at the same time as when gearheinz troubleshoots my fuel setup.
Old Sep 6, 2011 | 04:28 PM
  #451
Ruthless18x's Avatar
Ruthless18x
What offset is that pump? Center?
Old Sep 6, 2011 | 04:34 PM
  #452
str8dum1's Avatar
str8dum1
as the pic shows its pn 11142.
offset inlet/inline
Old Sep 14, 2011 | 07:44 AM
  #453
dikspiel's Avatar
dikspiel
Chestons Toilet
no updates really except I received my CJM return fuel system, should be installed soon.
Old Sep 14, 2011 | 08:17 AM
  #454
Flo-ridaZ33's Avatar
Flo-ridaZ33
Forget Dikspiel's build thread and concentrate on mine...
Respond
Old Sep 18, 2011 | 10:34 PM
  #455
dikspiel's Avatar
dikspiel
Chestons Toilet
Just destroyed my first engine today...off to gearheinz tomorrow to pull the motor. Car made a nice pop then pretty much died. Pulled over opened up the hood and didnt see any fluids, look under the car didnt see **** either. Tried to start the car and it immediately dies. Tried again and kept my foot on the gas and eventually i got it to crawl at 1-2mph enough that i could park it. Oil pressure was reading 0.
Old Sep 18, 2011 | 10:54 PM
  #456
midz350's Avatar
midz350
Sorry to hear man, hopefully its the first and last engine you destroy.
Were you in boost when that happened?
I hate that feeling. (every couple of weeks or so, I dream that I rev my engine and it blow up)
Old Sep 18, 2011 | 10:57 PM
  #457
dikspiel's Avatar
dikspiel
Chestons Toilet
yea i didnt mean to go into it
Old Sep 18, 2011 | 11:03 PM
  #458
Flo-ridaZ33
Dude... sucks.
Old Sep 18, 2011 | 11:04 PM
  #459
dikspiel's Avatar
dikspiel
Chestons Toilet
I'm crossing my fingers that the block is reusable.
Old Sep 18, 2011 | 11:10 PM
  #460
350z006's Avatar
350z006
Welcome to the SoCal Blown Motor club...I've blown 2, may you not blow anymore...
Exclusive membership, More exclusive than SBC!
