And so it begins...Finaly!
Old Apr 1, 2010 | 05:22 AM
  #141
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Originally Posted by Sylvan Lake V35
Talk to Sasha he is the electrical engineer
Scott, I will send you the section of my electrical install for my turbo kit. It will clear things up. PM me your email.
EDIT:
Found it on my build thread:
https://my350z.com/forum/forced-indu...-build-11.html
I used a Princess Auto relay and wired it to the washer fluid pump. It gets power when the ignition is on and and/or when the ACC is on. I prefer this over messing with anything related to the OEM ignition system.
It is very simple and you don't need to cut a sinlgle wire on the car.
Old Apr 1, 2010 | 09:01 AM
  #142
str8dum1's Avatar
str8dum1
mine is relayed off the fuel pump. Primes in the ON position and never running unless the car is running.
Simple doesnt mean the best.
Old Apr 1, 2010 | 09:56 AM
  #143
Boosted Performance
That works too.
Old Apr 1, 2010 | 11:33 AM
  #144
CAB350z's Avatar
CAB350z
So Car should be up and running by Tuesday or Wednesday... Got a few hick ups cause SFR is special...
Old Apr 1, 2010 | 01:00 PM
  #145
Jay'Z's Avatar
Jay'Z
SFR special in a good or bad way?
Old Apr 1, 2010 | 04:34 PM
  #146
Sylvan Lake V35's Avatar
Sylvan Lake V35
Judging by all of the things wrong or missing on his kit I would say special in a bad way.
Old Apr 10, 2010 | 03:20 PM
  #147
CAB350z's Avatar
CAB350z
Thanks to boosted Probe my scavenger pump has power!
^^^^ Im gonna need to do a serious wire tuck
Tomorrow i hope to top off fluids... I plan on starting it up tomorrow however there is one thing i just want to make sure is okay before i do... The turbos will be oil starved for a few seconds before the oil circulates... is this okay?
A buddy of mine who rebuilds rb25s told me that i need to disconnect the coil packs from the battery lead then crank the engine 6 times for 5 second intervals for a total of 30 seconds. He insisted that this wouldnt kill my starter... however I believing otherwise... Opinons?
Old Apr 10, 2010 | 03:22 PM
  #148
Boosted Performance
No problem.
You should have put the relay in the batery compartment. That way you only have the grey cable going to the pump. Much cleaner.
I should have mentioned that when I sent it down to you.
Your starter is fine if you crank it over a few times.
Old Apr 11, 2010 | 08:17 PM
  #149
CAB350z's Avatar
CAB350z
Tried to start it about half an hour ago, no go. Starter wasn't turning over. When i was doing the intake piping i had to make a ground to go about 4 inches. Looks like ill be the auto parts store to buy a better ground
Old Apr 12, 2010 | 04:31 PM
  #150
CAB350z's Avatar
CAB350z
Exclamation And so it ends more or less
It started, it started, oh my god it started , it sounds ****ing sexy. There is only one leak, so i will fix that up but here enjoy a video. What you cant see is me dancing around like a retard.
<object width="400" height="300" ><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://www.facebook.com/v/380489904301" /><embed src="http://www.facebook.com/v/380489904301" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="400" height="300"></embed></object>
Old Apr 12, 2010 | 05:18 PM
  #151
Boosted Performance
Congrats Scott, I am sure you will be even hapier when you start driving. When/where are you tuning it?
2 deg C in there...nice and cold.
Old Apr 12, 2010 | 05:59 PM
  #152
Sylvan Lake V35
Good news when are you going for a tune?
Old Apr 12, 2010 | 06:13 PM
  #153
CAB350z's Avatar
CAB350z
I havent even thought that far ahead, I don't know any where in Calgary that tunes
Old Apr 12, 2010 | 06:27 PM
  #154
Sylvan Lake V35
What do you have for engine managment? Lightspeed Innovations in RedDeer has tuned several TT and supercharged G/Zs he can also tune most ECUs. However as with all good tuners he might be hard to get into right now but worth a try. cam@lightspeedinnovations.com
