Big boost?.. Was it worth it?
Old Mar 9, 2010 | 09:19 AM
  #41
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Originally Posted by phunk
just make sure you have another car.
whoever started this whole "building the engine for more reliability" was not thinking straight.
you build a motor so that the internals can handle more HP, thats it. With that more HP, you are losing reliability in every other part of the drivetrain, the only thing you can "rely" on more is to not throw a rod thru the block or crack a piston. You are also *decreasing* reliability because now every little thing in your engine bay has been ****ed with by someone.
While my car has never once broke down on me... I would still have to have a pretty twisted sense of "reliable" to think that I could depend on that car like I can my stock 370z.
Extremely well put
Old Mar 9, 2010 | 10:41 AM
  #42
CAB350z's Avatar
CAB350z
I had a built 99 vr4 heavy boost never regreted it, even after the engine blew... this is why im boosting mine right now
Old Mar 9, 2010 | 10:54 AM
  #43
suprasam's Avatar
suprasam
I love cars and I love driving...driving a boosted z/g is fun and I get on my car when I can. I've been thinking/dreaming about boostin my car since 05 and I had the money to do so. My only regret is not readily having a second car. Some things you like to do may not be financially responsible and not offer great, if any, returns but they can be fun.
Old Mar 9, 2010 | 10:58 AM
  #44
thom000001's Avatar
thom000001
I will say this.......for the few (ok like 3 of us that have been that high lol)
Seeing that boost gauge spin to 30psi is a little un-nerving......especially on a motor that was never intended to see boost initially lol.
Tom
Old Mar 9, 2010 | 11:03 AM
  #45
suprasam's Avatar
suprasam
^^^ Tom, 30 psi sounds crazy...I'm still getting used to my "high boost" 14.5 psi.
Old Mar 9, 2010 | 11:47 AM
  #46
Chris@FsP's Avatar
Chris@FsP
I remember back when high boost was....
10psi on a bone stock greddy kit
Old Mar 9, 2010 | 02:50 PM
  #47
StuLax18's Avatar
StuLax18
General & Tech Moderator
Originally Posted by Nexx
FML is right, make sure you disconnect the negative when you dont plan on driving your car frequently. Damn haltech sucks up so much juice, my optima red top dies in less than two weeks if not driven.
Sounds like you need me to babysit it?
Old Mar 9, 2010 | 03:07 PM
  #48
UMW350Z's Avatar
UMW350Z
My battery drain went away when I ditched the UTEC...it's nice that it starts on cue now.
It seems like the answer to this question depends on who you ask OP, but Tom is right, your best chance of success is to take it somewhere reputable. Shop proximity just might be the biggest deal-killer (for me at least) for a built motor this fall.
The biggest question is...5,000 for a reliable street bike or another 10k+ to finish the motor...hmmmmmm
Old Mar 9, 2010 | 03:19 PM
  #49
superchargedg's Avatar
superchargedg
Damn Noobs
Originally Posted by Alberto
Everyday that passes I feel like I regret the decision to go so crazy on this car more and more.
I feel like Id rather be driving my old NA setup and enjoying it daily at no cost above stock for maintenance, than spending money on fixing my car, trailering it around, caring for it more and never driving it because its become such a pain in my d!ck. Id drive it now but the battery is dead again. I dont even trust my car for a 2.5hr trip to the Ocean.
FML
Bert get a fuking battery tender and dont worry about that little Braile you got in there.
Old Mar 9, 2010 | 05:24 PM
  #50
mistanismo's Avatar
mistanismo
It blows my mind that people even consider boost if they cannot afford a second DD etc.
Boosting is great, if you can afford the maintenance. From what I have read thus far (couple months of trolling etc), newer users / potential candidate always consider the initial cost (complete kit/install/tune etc) as the 'expense' of boost... that's just not the reality.
It's just like buying a car. The initial purchase is just the start, it's only more $ from there.
If you *think* you can't afford it... you probably can't, that's just the reality unfortunately, and why as of now I'm NA... might as well do it right and be reasonable.
Old Mar 9, 2010 | 05:51 PM
  #51
BonesZ33's Avatar
BonesZ33
Originally Posted by jeffie7
Alberto start disconnection your battery, I remove my neg side everytime I pull into the garage, for some reason the Z draws enough power to knock out a battery over a few weeks if the car just sits around. I learned this the hard way, 2 dead batteries later. and many jump starts.
If you continue to do this, you will eventually get a CEL code, for not having sufficient ECU "back-up" or something. I forget the code number but I've gotten it before. Never had a problem with draining my batteries, Sounds like you have a short somewhere.
Old Mar 9, 2010 | 05:56 PM
  #52
Sylvan Lake V35's Avatar
Sylvan Lake V35
I doubt i would go big again. My car worked great at around the 400whp mark if i could go back i would keep it there.
Old Mar 9, 2010 | 05:59 PM
  #53
jeffie7's Avatar
jeffie7
Whatever it might be, it use to happen when I had nothing more then an exhaust and pop charger.
If I get a cel I'll just wipe it.
Old Mar 9, 2010 | 06:19 PM
  #54
themadhatterxxx's Avatar
themadhatterxxx
Originally Posted by JAM3Z
Yeah this is an absolute must. I've been very busy for the past few months so I haven't been driving the Z regularly. Anytime I know I won't be taking it out for a while o disconnect th battery. I have a feeling my UTEC is causing the trouble.
Having a second car is also a must.
What makes you think its the UTEC?
Old Mar 9, 2010 | 07:37 PM
  #55
rcdash's Avatar
rcdash
Haltech should not suck up any juice when the car is off. Nor should the UTEC. I've left my car for a week or more at a time when out of town and it always starts up just fine. I do have a complicated setup with built in car PC, aftermarket audio, etc that runs off a 2nd battery in the trunk but I use a battery controller which disconnects all the crap in the trunk including the 2nd battery when the ignition goes off. Are you guys powering crap in the trunk? A large capacitor perhaps for your audio system?
Old Mar 9, 2010 | 08:02 PM
  #56
Flo-ridaZ33's Avatar
Flo-ridaZ33
Originally Posted by Boostedtrack350
OP, have you ever driven a boosted Z?
Not a Boosted Z but I have driven a Z06 with about 550whp and a TT 04 Cobra with 638whp... I'm basing my set up around those experiences.
Originally Posted by thom000001
All depends on your definition of worth.
If you think its an investment...you are wrong lol.....
Make sure its what YOU want. And learn from other's mistakes, go to the right places/people for EVERYTHING
Tom
Yea its def not viewed as an investment... I'm actually looking at Forged for the block.
Originally Posted by mistanismo
It blows my mind that people even consider boost if they cannot afford a second DD etc. Boosting is great, if you can afford the maintenance. From what I have read thus far (couple months of trolling etc), newer users / potential candidate always consider the initial cost (complete kit/install/tune etc) as the 'expense' of boost... that's just not the reality.
Money isn't my problem... my daily is an almighty 2010 Toyo Yaris. My 100hp beast gets 29mpg city and 35mpg hwy, it only costs $27 to fill it up. I'm actually getting the vibe that the guys have have made it past the 600whp plateau for the most part regret it and the guys that are in the 500whp area really like it... I've already put about $25k in the car(not including the original price) and was just getting the opinions of you guys before I drop another 10k.
Old Mar 9, 2010 | 08:23 PM
  #57
SatchScream's Avatar
SatchScream
OP, please correct your signature. It is really, really bothering me.
Old Mar 9, 2010 | 08:55 PM
  #58
Flo-ridaZ33
Lol seriously? Wow
Old Mar 10, 2010 | 09:38 AM
  #59
makopolo's Avatar
makopolo
Originally Posted by winchman
I can race around like crazy without breaking 3000 RPM, and that's hardly making the engine work at all. What do you need more power for?
What kind of fun are you having bellow 3000 RPM? The fun starts at least 1k above that.
Old Mar 10, 2010 | 10:06 AM
  #60
Alberto's Avatar
Alberto
Cranky FI Owner
I ditched the Braille years ago old man get caught up!
I did have it on a tender but the car sleeps outside now due to other circumstances, so no tender I let it die away.
See you Saturday still right? You better not be a queer and b!tch out...
