Need suggestions on an oil cooler
Old Mar 10, 2010 | 12:15 PM
  #41
- bigc -'s Avatar
- bigc -
i want a second car
Old Mar 10, 2010 | 12:30 PM
  #42
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by 0jiggy0
But does he drive the car then or is he driving his g37?
ya, sorry i didnt refer to that, but ya, my thoughts are based on the fact that he has a daily......
-J
Old Mar 10, 2010 | 03:35 PM
  #43
Nexx's Avatar
Nexx
-J
yeah, the car is not drivable in cold weather anyways. no fun cause the lack of traction.
Old Mar 10, 2010 | 05:31 PM
  #44
0jiggy0's Avatar
0jiggy0
-J
I was basically agreeing with you. My post was aimed at bigc.
Old Mar 11, 2010 | 10:28 AM
  #45
Nexx's Avatar
Nexx
im leaning towards the GTM competition oil cooling kit. it just seems like the most efficiently designed setup. its clean and very functional. price is a bit steep but ill pay for good money for a well designed product.
Old Mar 11, 2010 | 10:40 AM
  #46
plumpzz's Avatar
plumpzz
They're all the same. I got the GTM HD kit for track use because it came with a nice bracket and lines precut. Its not much cheaper to build an equivelent kit. It works nicely. My only issue with it is the pressures run high since the piping is too small.
Old Mar 14, 2010 | 11:20 AM
  #47
xzotklr's Avatar
xzotklr
People..you are aware many of these pre-fabbed kits use Setrab or Mocal coolers, Aeroquip braided hose & other name brands!!! Might as well get individual pieces; at least you can customize to your needs.
Most cooler kits include:
Oil Cooler unit ( Mocal, Setrab etc)
Oil sandwitch adapter
Stainless Steel Braided hose
An fittings
Mounting brackets & bolts
Old Mar 14, 2010 | 11:38 AM
  #48
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
An fittings
I agree, but some people don't want the hassle of assembling lines and whatnot. They pay extra for someone else to do it for them
Old Mar 15, 2010 | 06:53 PM
  #49
xzotklr's Avatar
xzotklr
What is the part number of the mocal t-stat adapter that would be needed?
Mocal Thermostatically controlled sandwhich plate-#SP1FT
Old Apr 23, 2010 | 03:11 PM
  #50
Barnabas's Avatar
Barnabas
National Z Club President
I am piecing together my oil cooler kit, thanks for the advice guys... I am gonna find the pieces then post them here soo everyone that has doen it before can tell me if I am missing anything or need something else.
Mocal sandwich plate 3/4" -16thread
http://www.racerpartswholesale.com/p...Sandwich_Plate
mocal AN to bsp fittings
http://www.racerpartswholesale.com/product/3282/s
Mocal 19row oil cooler (is 19rows enough/best use/what most use??) -10 fittings
http://www.racerpartswholesale.com/p...ix_Oil_Coolers
-10 aeroquip SS lines
http://www.racerpartswholesale.com/p...l_Braided_Hose
what AN fittings will be needed?? I will prob just get these at a local speed shop as it will prob be easier.
Anything else I am missing??
Thanks for all the advice guy's!!!
Old Apr 23, 2010 | 06:19 PM
  #51
Chris@FsP's Avatar
Chris@FsP
-10 may be a little overkill. The GTM comp cooler kit uses -8 lines, and works great.
Old Apr 23, 2010 | 06:24 PM
  #52
Barnabas's Avatar
Barnabas
ok il double check with my installer and double check with him if I dont then great
some of the guys said previously the -8 couldnt handle enough flow though?? maybe its a restriction??
Old Apr 23, 2010 | 06:31 PM
  #53
- bigc -'s Avatar
- bigc -
i used -10 AN lines and fittings. you'll need two 90 degree AN fittings at the sandwich plate and two -10AN fittings at the cooler (angles will depend on how you mount the cooler). looks like you already have the 2 bsp to AN adapters so you should be set.
i found this thread to be very helpful when I put together my oil cooler:
https://my350z.com/forum/forced-indu...56k-pwn3d.html
Old Apr 23, 2010 | 06:37 PM
  #54
Barnabas's Avatar
Barnabas
cool thanks!!! I will be having frank at hills garage doing the install but Ihave no problem saving 100 dollars or a little more to just do the work to get all the pieces
Old Apr 23, 2010 | 06:43 PM
  #55
Barnabas's Avatar
Barnabas
soo I just tallied up the parts and they are 20 bucks less then buying the GTM kit since it is currently only 380 soo I may just buy the kit after all...
Old Apr 23, 2010 | 08:16 PM
  #56
Zazz93's Avatar
Zazz93
+1 on the -10 AN, it should be fine. I'm using it and the pressures at the proper weight oil is spot on for my setup.
Old Apr 23, 2010 | 08:36 PM
  #57
zman1982's Avatar
zman1982
Originally Posted by str8dum1
i think people are crazy to shell out that kinda money for a oil cooler.
All GTM has done is package OTS products, mark them up again, and resell. Thats an excellent business plan and it has seemed to work superbly! You can get all those components from Jegs/Summit for cheap and make your own -AN lines from ebay.
Heck even this would work perfectly http://cgi.ebay.com/ebaymotors/ws/eB...m=370288418608
you may just want to swap to a thermostatic sandwich plate.
Better yet, send me 550$ and I'll make you a oil cooler kit
+1000000
You can get a B&M 500hp kit at Jegs for 149.99. All you need is the sandwich plate and fittings.
Old Apr 30, 2010 | 02:17 PM
  #58
Barnabas's Avatar
Barnabas
Question how do I know what sandwich plate is right/best??
http://www.racerpartswholesale.com/c...Sandwich_Plate
Old Apr 30, 2010 | 05:59 PM
  #59
Zazz93's Avatar
Zazz93
Sorry man can't remember if it was the 20mm or the 22mm.
Old Apr 30, 2010 | 06:00 PM
  #60
Barnabas's Avatar
Barnabas
what determines proper size??
