My HKS S/C Installation
Old Apr 15, 2010 | 01:18 PM
  #101
cdoxp800's Avatar
cdoxp800
Originally Posted by IanP
And my work in progress
That looks great Ian.
Here is a little tip. Trim some of the plastic in from of where the Idler pulley install on the Bracket. It will make life much easier when you install the pulley.
Attached Thumbnails My HKS S/C Installation-photos-004.jpg
Old Apr 15, 2010 | 03:41 PM
  #102
IanP's Avatar
IanP
Is that with a stock radiator? I've got the 54mm Koyo radiator fitted & have already cut away a lot of the top of the fan casing, Just need to figure out now where I can mount my ARC catch can
Old Apr 15, 2010 | 03:53 PM
  #103
cdoxp800's Avatar
cdoxp800
Yep (stock). You still want to trim some of that plastic.
Old Apr 15, 2010 | 04:23 PM
  #104
jonnylaw's Avatar
jonnylaw
+1 to trimming. The extra room helped, especially after my idler pulley snapped off.had to upgrade to stronger bolts. Don't know if it was an issue specific to me. But if anyone else it pushing 13psi on the HKS kit, consider upgrading to stronger idler puller bolts, or keep a close eye in them.
Old Apr 15, 2010 | 06:55 PM
  #105
ITOzann's Avatar
ITOzann
I thought 10psi was the max.. how can we push an hks at 13psi? I thought the stage 5 gtm specs was rated at 9.5-10-psi
Old Apr 15, 2010 | 08:54 PM
  #106
jonnylaw's Avatar
jonnylaw
I dunno (maybe I got a special blower or its my particular setup, but that's what I peak at on the dyno and on the street)...My kit is maxed out stage 5 revup 6 m/t with many upgrades. Tuan@GRD did a great tune and this is all while battling a Cosworth plenum leak (still awaiting a retune with new plenum that is on the car).
Actually, I remember when the car was first on the dyno, it would only boost to ~10psi. I was experiencing some belt slip/loose and a few of the belts were changed to slightly smaller ones. Also, Tuan tweaked the tune and then it would boost to 12-13 psi and made more power. I'm wondering if any further improvements will show when I go back for a retune with the new Cosworth plenum that so far is leak-free.
Old Apr 15, 2010 | 09:58 PM
  #107
ITOzann's Avatar
ITOzann
^^ thanks for all the info! really helpful... I can go talk with my tuner since I was aiming for something like your set up. I have the same set up as you but the difference is the pulley which I'm getting and the EMS, I'm using Osiris(saving for an Fcon)..
A silly question man, I wonder if you ever dyno your car on a different Dynometer such as mustang or DJ?
Old Apr 15, 2010 | 10:45 PM
  #108
_ink's Avatar
_ink
This is an awesome thread!
Looking good IanP and Jonnylaw!!
Would you guys know the size of the the piping required for the oil catch can? i.e. the nozzle size for the crankcase and piping size??
I'm trying to figure this out!
Old Apr 15, 2010 | 10:46 PM
  #109
_ink's Avatar
_ink
Also, what strut bar fits with the HKS SC kit?
Old Apr 16, 2010 | 02:42 AM
  #110
pez1111's Avatar
pez1111
Subscribun, HKS GT S/C on the way............................
And Cosi intake...................................................... .....
Would like to here/see your results with cosi intake posted up........
Old Apr 16, 2010 | 09:49 AM
  #111
jonnylaw's Avatar
jonnylaw
On the G coupe, no strut bar fits b/c of the piping layout Had to sell my ARC bar..On the Z, I'm not sure
Old Apr 16, 2010 | 09:51 AM
  #112
jonnylaw's Avatar
jonnylaw
When my kit was first installed (before the tweaking of the tune/belt change--~10 psi), and with a leaking Cos plenum, I did get my car dynod on a dynojet. I can try to find the dyno files--I believe the numbers were like 399whp/405 trq (sae).
Old Apr 16, 2010 | 10:46 AM
  #113
350z006's Avatar
350z006
I'm curious...what are the biggest numbers anyone has seen on a HKS Supercharger with the VQ?
Also, I imagine the reason the HKS SC has a better hp/torque ratio than the Vortech is probably because the HKS's pulley/belt layout brings the boost up more quickly in the rpm range than the Vortech so you can get moore boost at lower rpms, therefore better torque response...yes?
Old Apr 16, 2010 | 11:36 AM
  #114
IanP's Avatar
IanP
My ARC bar fits fine & I would guess that the OEM bar fits aswell, not sure what others will fit though
Old Apr 16, 2010 | 12:04 PM
  #115
jonnylaw's Avatar
jonnylaw
I haven't seen bigger numbers on the HKS GT SC than the dyno I posted, but if anyone is putting down more power than me, please post up
Old Apr 16, 2010 | 07:27 PM
  #116
_ink's Avatar
_ink
Thanks for the info re the strut bar.
How about the oil catch can piping? Is it 9mm or 15mm?
Old Apr 16, 2010 | 10:02 PM
  #117
ITOzann's Avatar
ITOzann
Originally Posted by DaytonaBlue55
closer look before i shipped the kit:
Just shootin out some ideas.......Belt could be slipping.... I know you had to buy one maybe its to big so even with tensioner tightened all the way its still loose
The blower's serial number on the kit you send me is GTS7040-070094
The Serial number on marble's blower is GTS7040-070086 which is the one you stated that you bought and then ended up selling it to me..
https://my350z.com/forum/shop-builds...automatic.html
I hope Karma doesn't hit on you twice in the future. I could've easily dealt with a pulley but you stating that you are old enough and professional to the point that your word is worth it on top of any supercharger stuff... blah blah blah.. is just lame... you truly lie sir and it's disappointing. I worked over 1 year and saved little by little and struggle between school/housing expenses to afford what I purchased from you ...
No more drama and I'll have to suck it up.... Lesson learned,I believed that before this forum was full of people we could trust but lately this place is getting crazy... scams from random people and vendors.. watch out for them people.. specially when it comes to items that are pricey..
Ariel
Old Apr 16, 2010 | 10:11 PM
  #118
ITOzann's Avatar
ITOzann
the following is the Mustang Dyno number I got after my first tune my base was around 210whp on a mustang dyno..
Old Apr 16, 2010 | 11:55 PM
  #119
Erdem's Avatar
Erdem
sorry to hear about the scam dude!!!
that's why I ended up buying a brand new vortech kit...
I just did'nt trust the marketplace...
anyways.. can you feel a HUGE difference between those 60WHP in gain...
I'm just curious, because I just can't imagine how the Vortch is going to be like...
Old Apr 17, 2010 | 12:57 AM
  #120
IanP's Avatar
IanP
Both. 2 of them are 15mm & the other one is 9mm
