My HKS S/C Installation
Old Apr 23, 2010 | 04:27 AM
  #161
_ink's Avatar
_ink
Why did the belt take you the longest? Different size pulley??
You must also have very cut and battered FAT hands! haha
Was just thinking with the extra heat under the hood with the Supercharger, has anyone thought of doing this to keep things cool?
http://www.s2carbonworks.com/09ni37alhosp.html
Old Apr 23, 2010 | 05:26 AM
  #162
IanP's Avatar
IanP
I've got a vented bonnet so not too bothered
Belt took the longest because with the bigger rad & fans in place there is hardly any room to move, especially with chubby hands
Old Apr 23, 2010 | 09:22 AM
  #163
_ink's Avatar
_ink
Anyone using the DW 600 injectors?
I just received mine and they don't have any spacers, do these need any spacers? Or just plug and play?
Old Apr 23, 2010 | 10:31 AM
  #164
jonnylaw's Avatar
jonnylaw
I run those. They are plug and play as far as I know.
Old Apr 23, 2010 | 12:45 PM
  #165
IanP's Avatar
IanP
Yup they are plaug and play
Old Apr 23, 2010 | 01:55 PM
  #166
ITOzann's Avatar
ITOzann
^^ +1 pm what they said.. plug and play
Old Apr 23, 2010 | 02:42 PM
  #167
cdoxp800's Avatar
cdoxp800
See the kink of the intercooler on top?
This will stop you from running a pipe through.
Originally Posted by cdoxp800
Will see. I have done a dry run with no filter and it fit fine.
Like I have already said before, I have done a dry run with no filter and it fit fine.
Old Apr 24, 2010 | 06:57 AM
  #168
_ink's Avatar
_ink
^^Would love to see how you go!
Old Apr 24, 2010 | 06:59 AM
  #169
_ink's Avatar
_ink
I need some help with the oil catch can and the piping.
I read searched and read sooo many threads and am still confused! Some people are recommending drilling out the PCV which i definitely do not want to do.
Where are you guys routing your pipes from?
Old Apr 25, 2010 | 09:23 AM
  #170
IanP's Avatar
IanP
What catch can is it? I never had to drill anything
Old Apr 25, 2010 | 04:46 PM
  #171
_ink's Avatar
_ink
It's a 2 nipple generic oil catch can.
Have a read here Ian, its about crankcase and oil catch can installation :
https://my350z.com/forum/forced-indu...od-w-pics.html
https://my350z.com/forum/forced-indu...lve-cover.html
wonder whats best practice for us hks sc boys.
Old Apr 25, 2010 | 08:14 PM
  #172
carbon z's Avatar
carbon z
Johnnylaw, I'm just reading the thread trying to get educated. One thing you said was you got 13psi boost. I understand the pulley set up which spins at higher RPM's for the upper boost. Question, you say you have an ATI crank pully. Is it a smaller diameter then stock? If so that might just explain your higher boost. Point, If so you might be turning higher rpm's than your blower will handle long term.
Old Apr 26, 2010 | 03:35 AM
  #173
IanP's Avatar
IanP
I've had 2 catch cans neither of them needed to drill anything out.
Theres a guid on here somewhere for the cusco catch can, which is the one I used & the ARC one has its own instructions.
Old Apr 26, 2010 | 05:26 AM
  #174
_ink's Avatar
_ink
Thanks Ian! Appreciate your replies. I'll be running a breather filter on the US driver side, and a catch can on the US passenger side.
Old Apr 26, 2010 | 08:47 AM
  #175
jonnylaw's Avatar
jonnylaw
ATI is slightly larger than stock--might up boost a tad bit--but imo wouldn't add 3 psi. I'm not sure if it is my supporting mods or what. GTM stage 5 so, the blower is maxed out with their modifications/upgrades. I don't think I'm over the limit of the rpms for the blower. I'm going for retune in late May, now with a new (hopefully still leak-free Cosworth plenum). We'll see what the results are.
Old Apr 26, 2010 | 10:21 AM
  #176
str8dum1's Avatar
str8dum1
its not just a tad bigger, its alot. 1 full inch. On a vortech, that will spin the impeller 1000 rpms faster for the same engine rpm!
I'd say you could easily pick up 3psi from that.
Old Apr 26, 2010 | 11:32 AM
  #177
jonnylaw's Avatar
jonnylaw
Wow, I had no idea it was that much OD. No wonder, it took awhile to get the most effective belt sizes worked out. So adding a ATI dampened crank pulley can add up a couple psi to most Vortech/Rotrex/ATI/HKS SC setups?
Hmm. I wonder what it would take to overspin the HKS GTS7040 SC?
The specs I can find are 110,000 rpms max impellar speed, 2.5 max pressure ratio, max flow rate of 22 m3/min, 9.444 drive unit ratio, 4.2kg weight.
http://www.hksusa.com/info/?id=3767
Old Apr 26, 2010 | 02:04 PM
  #178
cdoxp800's Avatar
cdoxp800
Quick question.
jonnylaw what's your Rev limiter set at on your RevUp?
Thanks,
Old Apr 26, 2010 | 02:28 PM
  #179
jonnylaw's Avatar
jonnylaw
Quick question.
Thanks,
I think it was originally at 7200 rpms, but now it should be 7000 rpms (have to check); well I'd like for it to be at the stock redline at least
Old Apr 26, 2010 | 02:34 PM
  #180
IanP's Avatar
IanP
Thats good info to know, especially when I inevitably get bored of my new found power
All the figures I've seen for the kit so far are really inconsistent, I have no idea what power mine will make
Basing it on stage 1 power with minor mods I thought 370whp would be achievable but after seeing the power the stage5 makes I'm not so sure
