***ProEFi 128 Unit w/FlexFuel Review***
Well, as many of you already know, I went ahead and opted for the ProEFI upgrade 128 pin box for my most recent rebuild. I chose the services of Sound Performance simply because that's who I wanted to work on my car. Nuf Said.
Anywho, in regards to the 128 box, for those who are on the fence about it, I just thought I would share my review thus far.
FLEX FUEL aka 110 octane
I am so impressed with this feature alone. This is a cheap way to make great power and for little $$$. When you think about it $2.25/gallon (price in NY) for 110 octane is ridiculously cheap. The ProEFI allows me to at will choose between 93 octane pump gas and E-85 aka Flex Fuel. For the purpose of my trip back to NYC from Chicago (800+ miles), I opted to switch over from E-85 to 93 octane because that would minimize my need to stop for fuel.
Then upon arriving to NYC I have access to E-85 which I can then use to romp all over any one who crosses my path with almost 700 ponies provided me thanks to SP.
The only disadvantage that I can see with E-85 is that you will require more of it to make the power you desire. The motor will need to burn almost 30% more fuel when running E-85 when compared to regular 93 octane. So your fuel system better be up to snuff to meet this demand. I am running the CJM Twin pumps and 1200cc to meet the demand. Just something to keep in mind, better to overbuild your fuel system, just to be safe.
Popular problem areas with other EMS units:
Hot vs. Cold Starting:
Hot starts and Cold starts seems to be a problem that plagues many aftermarket EMS devices and sometimes tuners. Well, with regard to the 128 box, the car now starts like it came directly from the dealer. 2 turns and Vroom for BOTH hot and cold.
On/Off Throttle Exchange aka Drive-ability:
In the past I have experienced issues when getting off the gas. One EMS that comes to mind is the UTEC. Every time I got off the gas, the car would drop flat on its face. Most likely a tuning issue, but even when adjusted by a second tuner, it never really got better. Not a problem for the 128 pin box. Again, the transition of on/off throttle is silky smooth.
Boost Control:
The boost for my application is handled by a ProEFI boost solenoid which again is controlled by the ProEFI 128 box. I can run anywhere from 15 psi to 25 psi at will. I am using 1 bar springs.
***Only stipulations are understanding that for higher boost (19-25psi) I must maintain a minimum of 60% Ethanol to keep things safe. Anywhere between 15 and 18 I can run 93 pump gas and be safe.
Can Gauge Benefit:
I only wish I knew about the CAN Gauge before I went and spent $$$ on a plethora of gauges which can basically all be trashed. I could have saved a ton of cash. The CAN gauge is the 1 for all and all in one gauge showing everything from Radiator pressure, to boost pressure in kpa or psi, est hp, est 1/4 mile time, to common things like oil pressure, air temp, trans temp/pressure, AFR, etc...etc... It is incredible.
Idle Control:
I have some experience with the ProEFI 48 pin box prior to upgrading and the idle control was terrible. (moreso from the poor tuning than the device itself (Not SP)) Larry took care of the roving idle and got it rock solid at 950 rpm, even with the 272 cams. No need to set it at 1200 rpm like some folks, wasting even more precious fuel. Idle control is there and can be manipulated as my good man Larry can attest to. He also was able to resolve the momentary issue I had with the car stalling as I downshifted to a full stop. A few clicks of the keyboard and that issue was resolved.
Advanced Knock Control:
I don't even know its there, but I am glad to know it is actively protecting my engine.
Two Step Feature: (Drag Racing Enthusiasts)
This is something new to me that I will have to learn to deal with. Based on my demands expressed prior to tuning, I informed Larry that this car will definitely be seeing some drag racing as well as road course time. In pursuit of helping me decrease my 1/4 mile times he preset the 128 box with active 2-step.
For those that don't know how this works: basically so long as the clutch is depressed I can put the throttle to the floor and the rev limiter will only go as high as 4k rpm (or however high I choose to set it). Once the clutch is fully released the car can progress to full rev limit or however I desire.
Just in case you forgot, or didn't catch the other thread, here is the demonstration of E-85 in use.
http://www.youtube.com/watch?v=7e1IeAdw9QM
More to come as I get more seat time.
Comments or questions welcome.
Bottom line...128 box is AWESOME and the FlexFuel Mod is the best!!!!
Boost Control:
Can Gauge Benefit:
Idle Control:
Great review.
God I wish I had stopped by SP when I was in Chicago couple of days ago.
Nice review - thanks for taking the time - good to know the idle and hot/cold starts are solid - the 128 unit with a fully functioning CAN gauge is killer.
Few ?: Do you have widebands installed? How do the AFRs behave around town? Decel fuel cut working (noticed the backfires, popping, so...)? You have a **** for boost control? Looking forward to traction control review when its available (and speed dependent boost, etc)! Would love to see pics of CAN gauge, boost control ****, install, etc...
Yes, The ProEFI comes with it's own wideband and in addition I have an AEM already installed. The ProEFI wideband is in the driver side downpipe, and the AEM in the pass side. The ProEFI side is a tad richer than the pass side, but this is normal.
Absolutely perfect. To properly answer that question, it actually depends on which fuel I am running, it may appear richer than normal (I think I got that right) when running E-85, but otherwise spot on. Cruising was right on point as well. I should know I was cruising across teh country for 800 miles. There is no bogging down from being too rich.
That is a function of tuning. Larry asked me if I would like to get rid of the backfires, and that it would be just a few clicks of the keyboard. I said, leave the backfires. Hehe
SP installed a simple ****, similar to that of a Bass or Subwoofer controller. It allows me to adjust Boost on the fly. I can flip the CAN gauge to the Boost screen and then use the **** to adjust anywhere from 15 psi - 25 psi.
It doesn't get any better than that.
My luck, Jason called on the day I arrived to Chicago and advised that traction control was about 1 week away. (give or take a day) Unfortunately, the wheels were already in motion for me to pick up the car. I guess I can always try to either access the software upgrade remotely (if I purchase the tuning cable, or just go back later on in the year. Not really sure. I would love to have that feature, but I am just so glad to have the car back I think I want to enjoy it for a while.
I will try to shoot a quicky vid to demonstrate how it works. Maybe tonight. Just not sure how the CAN gauge will look on camera.
Few ?: Do you have widebands installed? Yes, The ProEFI comes with it's own wideband and in addition I have an AEM already installed. The ProEFI wideband is in the driver side downpipe, and the AEM in the pass side. The ProEFI side is a tad richer than the pass side, but this is normal.
traction control a week away... niiiiiiiice... i dont know man, if i were u id jump on that update ASAP..lol.. I must have watched the supra traction control video 100 times. Glad to see they were on their word about actively working on it..
What are some of the key differences between the PE128, VIPEC and Haltech.
Also what do u mean about buying the "tuning cable" I thought that the ProEFI has publically available software and does not require an additional purchase from what I have read.
Thx.. I have read that thread previously. For instance the Vipec supports dual fuel maps where the Haltech does not. It is stuff like this that is nice to know about and hence the comparison with the ProEFI
There used be demo software available on the proefi site apparently but is no longer there. I have asked SP to see if this is still available so i can have a play with it.
agreed, i am going to use 2000cc injectors
Also agreed on leaving the backfires.. haha
excellent review, videos, thread man... great news all around!
