jwt tt bank 1 wastegate gone
Old Apr 27, 2010 | 03:51 PM
gen05's Avatar
gen05
Default jwt tt bank 1 wastegate gone
hi guys. i had my car in the air the other day because i hear this rattling noise coming from the engine area on low rpms when i take off or decel. so i had my car in the air. while i was looking, i saw bank 1 wastegate is not there so the side where the rod suppose to lock in, there is nothing there. its moving freely.rattling causing the noise. i can not see far enough to tell if the complete wastegate is not there or jus the rod broke, anyone experience this kind of problems and while i drive i kept my eye on my boost gauge, im not over boosting
Old Apr 30, 2010 | 02:52 PM
rcdash's Avatar
rcdash
You may not be overboosting, but you could be running one turbo too fast with the other venting to compensate. I think you could damage the turbo running without a wastegate not operating. Good thing you noticed it - would see if you can source that part from JWT...
Old Apr 30, 2010 | 04:44 PM
Zivman's Avatar
Zivman
you aren't missing the wastegate, you are missing the actuator and/or actuator rod. the car will not overboost. It will likely underboost if anything. Like rc stated, you might be over running the other turbo to compensate. Just get a replacement actuator and get it installed.
Old May 1, 2010 | 12:49 AM
wannabuy350z's Avatar
wannabuy350z
this happend to me, the clip holding the actuator to the flap of the wastegate cam off. i just welded it on
Old May 1, 2010 | 07:19 PM
gen05's Avatar
gen05
i will have to look at it again. but if im just missing the rod. how can it be installed? i believe its a complete assembly isnt it?
Old May 1, 2010 | 10:43 PM
Zivman's Avatar
Zivman
don't know if you can find it by itself, but if you can it just threads on to the actuator. It then uses a clip to attached it to the wastegate swing arm
Old May 2, 2010 | 12:12 AM
wannabuy350z
you can purchase actuators from www.Forge.com
Old May 2, 2010 | 04:40 AM
gen05's Avatar
gen05
thanks guys. i have a internal wastegate laying around for my 335. i believe its the same thing. im just going to take the rod out of that one and put it on. but now the question is. how do i know where to set the wastegate rod.another word. what shouldi do to adjust them, im running 9psi,
Mattg350z
Oct 2, 2015 06:51 AM
Bigsyke
Sep 11, 2015 06:19 PM
