Powerlab Dumptube Weld Crack
Old Jun 7, 2010 | 05:09 PM
ATX350's Avatar
ATX350
Default Powerlab Dumptube Weld Crack
Hey All,
It's been 10 months since my car was dyno'd and tuned but managed to catch the uprev Dyno event this past weekend. The techs did a pre-dyno checkup and found that I had a crack pre-wastegate. We did the dyno and the loss was obvious as I had dropped from 6.5lbs of boost to around 4.
Original Dyno (mustang):
http://www.youtube.com/watch?v=zRCaRcuap0E
Recent Dyno (dynojet):
Based on the recent dyno I'm running extremely lean under boost which I contribute to the crack. I'm hooking up with Jtran to fix the weld crack and will put the car back on the dyno to resolve the tune issues. Johnny mentioned that the dumptube welds cracked on his customers car also so beware.
-Eric
Old Jun 7, 2010 | 05:20 PM
SlideFox's Avatar
SlideFox
Unfortunately, I think this happened to two other people as well. The last time I heard of this happening was well over a year ago, and I thought Powerlab has since reinforced that particular weld (Assuming it's the same weld that I am thinking of). Those that had a crack, I think had their local shops re-weld and reinforce it a little. I don't think I have ever heard of those people having it "re-break".
Sorry OP, hopefully you get it fixed quickly and are back up and running at full power!
Old Jun 7, 2010 | 05:37 PM
ATX350's Avatar
ATX350
Forgot to post the pic of the cracK
Old Jun 7, 2010 | 05:49 PM
SlideFox's Avatar
SlideFox
Yup, it's the same spot as the other two guys. I think it's the weight of the WG right on that weld. Have them grind it, and re-weld it stronger, and you should be good to go!!
Old Jun 7, 2010 | 05:51 PM
ATX350's Avatar
ATX350
KK, will do. Thanks Slide
Old Jun 7, 2010 | 06:16 PM
tig488's Avatar
tig488
have them weld a square piece across the joint.
Old Jun 7, 2010 | 06:21 PM
UMW350Z's Avatar
UMW350Z
Just reweld it, the metal around the weld is weak, that's all. I had Meineke do it, no problems since
Old Jun 10, 2010 | 06:50 PM
IntenseSales's Avatar
IntenseSales
Vendor - Former Vendor
LMK if you need any help Eric. Sorry that happened to you.
The kits have since been reinforced and havent had any additional mention of it until now.
Old Jun 10, 2010 | 07:07 PM
ATX350's Avatar
ATX350
Thanks for the response Pete/Darren.
Could always pick up the tab to fix the crack
Old Jun 10, 2010 | 08:20 PM
Elperuano's Avatar
Elperuano
My man! Subscribed now! ahahahaha
Old Jun 11, 2010 | 08:04 AM
IntenseSales
Thumbs up
PM'ing ya. I'll help you out
-Pete
Old Jun 11, 2010 | 08:21 AM
UMW350Z's Avatar
UMW350Z
damn! I should have asked for help...maybe some credit on a Cosworth plenum for me
Old Jun 11, 2010 | 08:36 AM
mx594's Avatar
mx594
You found a Meineke that can weld stainless? Did they TIG weld it? Did they purge the back side of the weld with Argon to prevent contamination ("sugaring")?
Old Jun 11, 2010 | 11:17 AM
QuadCam's Avatar
QuadCam
Meineke.....where skilled Tig Welders work. I have yet to see a "muffler shop" with a tig welder. Even when they weld stainless, they are Mig welding it with regular Er70S-6 wire and 75/25 gas. It'll work, but it's not right. You can MIG weld stainless, but you should use stainless wire (for the correct alloy) and a "tri-mix" gas that is specific to stainless steel welding.
Old Jun 11, 2010 | 11:37 AM
str8dum1's Avatar
str8dum1
realistically though, does it matter?
if not then who cares, except for semantics? I dont know so I am curious.
Old Jun 11, 2010 | 01:04 PM
mx594's Avatar
mx594
If you are re-welding a weld that cracked, why would you do so with methods that are inferior to the original weld which wasn't sufficient to begin with? Isn't that just asking for it to fail again?
Old Jun 12, 2010 | 07:09 AM
UMW350Z's Avatar
UMW350Z
the original weld broke in under 2,000 miles, the reweld has lasted 8...which was the inferior weld again?
Old Jun 12, 2010 | 02:44 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
lmfao
Old Jun 15, 2010 | 07:36 PM
Speqz's Avatar
Speqz
I had this problem on my car...they sent me a new reinforced pipe very quickly..Thanks Pete!
Old Jun 15, 2010 | 07:42 PM
Speqz's Avatar
Speqz
the cause of the cracking is the stress on that particular portion of pipe. I think the amount of welding is insufficient no matter the material. Hence the reinforcing of the pipe. Ive had the reinforced pipe for 8k miles and no problems since installing it.
norrix420
350Z Roadster
May 23, 2022 05:11 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Twenty4
Jan 17, 2016 01:20 PM
hardkicks
Sep 20, 2015 12:28 PM
