GTM HR TT KIT + IPP STG 1 HR bulid
Old Sep 15, 2010 | 07:31 PM
  #81
binder's Avatar
binder
that fuel seems really high. don't worry about how much fuel you have to take out. you have 1000cc injectors which is a lot larger than that base map is made for so you're going to have to lose a lot of that fuel.
My fuel cells down in the idle with my hks1000's are down in the low 20's.
Old Sep 15, 2010 | 07:33 PM
  #82
binder's Avatar
binder
and furhter looking at it, you have just as much fuel being poured in at -14mmhg (which is where my car is cruising) as you do at 7psi of boost in the 3000 rpm range. do you honestly think your car needs the same fuel in -14 vacuum as 7psi of boost at hte same rpm? HELL NO!
Old Sep 16, 2010 | 05:26 AM
  #83
midz350's Avatar
midz350
That is the base map BEFORE I did anything to it.
Here is it after:
Old Sep 16, 2010 | 06:54 AM
  #84
binder's Avatar
binder
so you dropped about 12% fuel in the decel area. That's still not much. remember, You need less than half the fuel in vac that you'll need in 0psi. You're still way too rich.
my decel cells are in the teens. each motor is going to be slightly different and i understand that but with the same injectors there isn't going to be 1 car in the teens and another in the 90's. That's a HUGE difference.
Old Sep 16, 2010 | 07:37 AM
  #85
midz350's Avatar
midz350
Can you please post a pic of your fuel table? thanks.
Old Sep 16, 2010 | 08:02 AM
  #86
midz350's Avatar
midz350
So. you mean something like this:
I also will change the fuel injector dead-time to the higher value. see it down:
10v 1.31
11v 1.14
12v 1.04
13v 0.97
14v 0.89
15V 0.79
Old Sep 16, 2010 | 08:18 AM
  #87
binder's Avatar
binder
my negatives are in mmHG so half my vac numbers to get what psi (-10mmhg= -5psi)
it goes further left but i couldn't get it all on the pic. That's a quick show for you.
Old Sep 16, 2010 | 08:24 AM
  #88
midz350's Avatar
midz350
I see.. Thanks alot for the help.
Old Sep 16, 2010 | 09:27 AM
  #89
Erdem's Avatar
Erdem
wow I have no clue on what all those numbers and colors mean..
is it possible to tune your own car if I learnt(learned)?
Last edited by Erdem; Sep 16, 2010 at 10:25 AM. Reason: edited on behalf of Nexx :)
Old Sep 16, 2010 | 09:31 AM
  #90
Nexx's Avatar
Nexx
is it possible to tune your own car if I learnt?
you need to get learnt at a school, best way or if you have a beater you can f with, learnt it that way.
Old Sep 16, 2010 | 09:32 AM
  #91
binder's Avatar
binder
I tune my own car. I just take it to Hal to do the final touches and make it perfect as well as safe timing on wot pulls. Basically all the things I can't do without a dyno and the extra fine tuning from his experience.
  #92
Erdem's Avatar
Erdem
lol haters gonna hate haha
Old Sep 16, 2010 | 11:36 AM
  #93
midz350's Avatar
midz350
This one I just tried, it idle/drive nice 14-15afr. I only tried it to around 3000rpm for now.
I will try to tune the rest of the vacuum cells when I have someone else driving for me.
Thanks binder for the help.
Old Sep 16, 2010 | 02:31 PM
  #94
binder's Avatar
binder
no problem. those numbers look a lot better.
i'm still dialing mine in. putting my external sensor in this afternoon and i'm going to go do some more vac tuning.
Old Sep 20, 2010 | 10:57 PM
  #95
midz350's Avatar
midz350
Will it be better to use the copythrough in the vacuum cells in the fuel table?
BTW, I have the GTM reflash.
Old Sep 20, 2010 | 11:03 PM
  #96
midz350's Avatar
midz350
^^ I just remembered that I have the 1000cc's injectors and that's a no no with the stock ECU.
Old Sep 20, 2010 | 11:19 PM
  #97
Nexx's Avatar
Nexx
low or high impedance?
Old Sep 20, 2010 | 11:25 PM
  #98
midz350's Avatar
midz350
Low.
Old Sep 21, 2010 | 12:08 AM
  #99
ashtrojan2008's Avatar
ashtrojan2008
those numbers have nothing to do with injector size, that is volumetric efficiency. you could have 390cc injectors or 2000cc injectors; when tuning on the same engine with VE the % will be the same regardless of injector size given that injector flow is set up correctly.
Ross
Old Sep 21, 2010 | 10:12 AM
  #100
Nexx's Avatar
Nexx
Low.
i was under the impression the stock ecu couldnt run low impedance injectors... someone correct me if im wrong.
