ARK Design MFD-2
Old Aug 31, 2010 | 04:55 PM
cdoxp800's Avatar
cdoxp800
Default ARK Design MFD-2
So anyone have the new ARK Design MFD-2? I just sent an email over asking a few questions to them.
http://www.arkdesign-us.com/mfd2-multi-function-dash-2
Thanks for your interest in ARK Design Product. Here is some information regarding the MFD II and your 350Z.
1. Yes the unit will be able to read your factory ECU O2 Signal. The MFD II unit can also read most aftermarket wide band unit that a 0-5V Output Signal. These aftermarket units are what we use to get the most accurate reading while tuning.
2. For reading boost you will have to get the optional boost sensor that will plug right in into the black box of the MFD II.
We apologize we have some programming error on our website, this product should be in the accessories section.
Anyhow, here is the info on the Boost Sensor for the MFD II
PN # 01-0103X-00 Cost $ 89.00
I have been looking at this for while since I saw the original MDF. Any postive or negative comments about it?
Thanks
Old Aug 31, 2010 | 05:12 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
If it really reads the header 02 signals then it may be worth having...
on 2003 and the early 2004 z's we dont have WB in the cats so reading that would be useless for us.
I am always hesitant about having one single gauge to read everything.
My boost controller will read my boost and I already have a oil temp/wideband so upgrading to this wouldnt get me much.
Old Aug 31, 2010 | 05:50 PM
rcdash's Avatar
rcdash
The DashDaq has this beat I think. It can read the Innovate MTS chain, OBD-II, among others... Too bad no multifunction 52 mm gauge. PLX is a rip off with all the expensive sensor modules you have to buy just to use their multifunction gauge.
Old Aug 31, 2010 | 07:20 PM
cdoxp800's Avatar
cdoxp800
Thanks. Will look it up
Old Sep 2, 2010 | 01:48 AM
_ink's Avatar
_ink
I have the MFD-I
I went with the MFD-I because i didn't want to use the OBDII port. It's pretty cool and clean.
Old Sep 2, 2010 | 05:52 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
+1, the DashDAQ is a pretty sweet little unit. I just wish one had the option to use a larger touch screen.
Here's one we installed a little while back...
Old Sep 2, 2010 | 09:02 AM
cdoxp800's Avatar
cdoxp800
So how good dose the Boots feature work?
Old Sep 2, 2010 | 09:44 AM
Chris@FsP's Avatar
Chris@FsP
que? Do you mean boost? With the optional MAP sensor installed, it reads boost perfectly, and even lets you set overboost warning tones.
Old Sep 2, 2010 | 05:10 PM
cdoxp800's Avatar
cdoxp800
LOL.. At least you understood part of it.
What I was trying to say was the calculating boost option. I guess it only works with a MAP sensor after reading the instructions. So do you get a MAP with it?
Per the instructions.
EXAMPLE: CALCULATING BOOST
Many vehicles do not provide an enhanced signal for Turbo Boost but it’s pretty easy to calculate. We’ll assume that boost is the
additional manifold pressure above normal barometric pressure (~14.7psi). For example, MAP=19.7psi minus BARO=14.7psi implies that
the turbocharger is providing BOOST=5psi. This calculation looks like:
BOOST = MAP - BARO
To perform this calculation on the DashDAQ, try setting:
• Input Signal: Manifold Absolute Pressure from GenericOBD2
• Multiplier Signal: Constant Multiplier from Rescale Signal Calculator
• Multiplier Sign: 1 (Positive)
• Constant Multiplier: 1.0
• Offset Signal: Barometric Pressure from GenericOBD2
• Offset Sign: -1 (Subtract)
The calculated value will be available when you assign signals to a gauge (section 0).
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Dymsi
Sep 29, 2015 11:32 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
