Another Vortech V3 Setup...
Old Sep 25, 2012 | 06:13 PM
  #121
meanz's Avatar
meanz
Nice! Do you already have a block in the works? Im at 430/390 right now with my new set up!
Old Sep 25, 2012 | 07:14 PM
  #122
Threads's Avatar
I don't have anything in the works yet. I have a few ideas on the route I want to go. I'll probably end up getting a shortblock from IPP.
Old Sep 25, 2012 | 10:44 PM
  #123
unvmyg35's Avatar
unvmyg35
That is going to make some serious power! Can't wait to see the results!
Old Sep 26, 2012 | 09:17 AM
  #124
350zhp306's Avatar
350zhp306
I apologize. I shouldn't have put you on the spot on the other thread and I didn't want to go off topic with the OP.
I already know about the history of yor car and your thread mentions that dynojet numbers would be 485whp/430tq......if I'm correct. I also know that the dyno you used definitely reads lower than a dynojet.
I would like your recommendation as to how far to push the limits of the stock block
Old Sep 26, 2012 | 09:48 AM
  #125
Threads's Avatar
I've always agreed with the 400wtq, dynojet, number. Obviously, there are other factors that come into play when a motor fails. However, a lot of people on here feel that if they had to set a threshold, that would be the number.
Old Sep 26, 2012 | 10:16 AM
  #126
350z006's Avatar
350z006
Oh...hello Ysi, have we met?
Good luck with your build OP ...
Originally Posted by Threads
After everything I've been through with my V3 blower, I've decided to go with:
Because I need a new shortblock, I figured i'd upgrade to the YSi. Currently, my goals are to make as much power as I can safely on pump gas.
Props to 350z006 for providing such a great deal on this blower. He even had the blower re-inspected before shipping it to me!
I guess I need to re-title this thread or start a new one since I'll no longer be running a V3 blower.
Old Sep 26, 2012 | 11:04 AM
  #127
str8dum1's Avatar
str8dum1
with the huge amount of belt slip that 4shizzl has on his T-trim above mid 500whp, i think we will all be interested in your solution.
well you need a motor 1st.
Old Oct 8, 2012 | 09:49 AM
  #128
Threads's Avatar
Haha. I was under the assumption that I would have issues with belt slip. At the moment, I don't have a plan of attack on how to reduce belt slip further than the extra pulley mod. I'm crossing my fingers that the slip won't be as bad as I've been reading about.
Old Oct 10, 2012 | 02:28 PM
  #129
alexml's Avatar
alexml
do you conected your bypass valve? to where?
Old Oct 10, 2012 | 04:05 PM
  #130
Threads's Avatar
Negative. My valve is venting to the atmosphere. Sounds better that way.
Old Oct 10, 2012 | 05:25 PM
  #131
- bigc -'s Avatar
- bigc -
install a vacuum line from the nipple on the bypass valve to a port on your intake manifold. the bypass valve needs to see vacuum in order to work correctly.
i'm pretty sure this is what you're asking about based on some of your recent posts.
Old Oct 11, 2012 | 02:57 AM
  #132
alexml's Avatar
alexml
yes it is because i´m instaling a boost gauge and i´m trying to find the correct conection to the gauge and the BPV...
thanks
i´m going to install it today... i will leave feed back
Drock
Apr 18, 2012 05:16 PM
JCstart
Nov 27, 2007 05:57 PM
JCstart
Jan 10, 2007 05:49 PM
DRFTR
Apr 22, 2004 08:49 PM
