Blown OEM Oil Pressure Sensors?
Old Oct 8, 2010 | 11:30 AM
TayTaythatsme04's Avatar
TayTaythatsme04
Default Blown OEM Oil Pressure Sensors?
Anybody else blown multiple OEM oil pressure sensors.
Im about to be on number 3.
Is there any aftermarket OEM replacements? Or another remedy to fix this?
Its a 04 Performance, only about 45000 miles, with a modified TN kit.
And Im getting sick of having to replace these things.
Thanks
T
Old Oct 8, 2010 | 12:32 PM
coachk's Avatar
coachk
Make sure you're not over tightening them. I got mine from the local Nissan dealer a couple years back with no problems yet. Where are you getting them from?
Old Oct 8, 2010 | 12:56 PM
TayTaythatsme04
From either a dealership or a online Nissan parts website
T
Old Oct 8, 2010 | 01:01 PM
coachk's Avatar
coachk
If I remember correctly you only tighten them by hand so you don't F up the sensors
Old Oct 8, 2010 | 01:02 PM
TayTaythatsme04
I'll keep a eye on that for this one, but I cant see that being the overall problem why these things keep dying on me.
T
Old Oct 8, 2010 | 01:20 PM
Vas_Z33's Avatar
Vas_Z33
yeah watch out when u tighten it.. I over tightened mine and it snapped. I had to seal that and run my sensor through the oil filter with an adapter.
Old Oct 8, 2010 | 06:17 PM
rcdash's Avatar
rcdash
High pressure spikes can cause a problem with the diaphragm I suppose. What oil pressure do you normally run? For my water pressure sensor which runs near 200 psi I had to run a pressure snubber, which provides more gentle changes to the diaphragm.
http://www.omega.com/pptst/PS_SNUBBERS.html
You need to get one that matches the fluid viscosity (oil vs water basically).
Old Oct 11, 2010 | 01:56 PM
TayTaythatsme04
thanks for the info, I was thinking about doing something like this already.
I figured one hard boost spike and the sensor cant handle it.
T
Old Oct 11, 2010 | 04:34 PM
coachk's Avatar
coachk
T
I believe Raj was refering to an oil pressure spike. I've never heard anyone blowing an OPS from an oil pressure spike, but it is possible. But because you have had multiple replacements, I doubt its from spikes.
Old Oct 12, 2010 | 06:36 AM
TayTaythatsme04
Well that would be the only thing I could think of with the current setup Im running.
Some sort of pressure issue. When the sensor is reading correctly the numbers are normal.
T
Old Oct 12, 2010 | 12:51 PM
coachk's Avatar
coachk
Try sending a PM to Quadcam or GoFast. Very smart guys.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
