My BP Single Turbo Kit Review
Old Nov 17, 2010 | 08:50 AM
str8dum1's Avatar
str8dum1
i dont think adding more timing would shift his powerband to the left almost 1000 rpms though... thats a function of turbo spool
Originally Posted by binder
403hp 359tq with 12% added to bring it up to what a DJ reads would be 451hp and 403tq. Somewhat off of yours but again, super low timing.
OP, i have some questions, what w/g spring are you running and what were your intake temps on these runs? also, the DD should have a knock sensor so why didn't he run the timing closer to knock threshold?
Old Nov 17, 2010 | 08:55 AM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
This was also a 4th gear pull, so the loading would be different.
str8dum1's Avatar
str8dum1
i dont think adding more timing would shift his powerband to the left almost 1000 rpms though... thats a function of turbo spool. 8* isnt that low, but if its too advanced during spool, that could be hurting response.
But again, not 1000 rpms different.
Old Nov 17, 2010 | 09:12 AM
athenG's Avatar
athenG
I dont understand why we always assume that a DD dyno is always low? There are tons of DD shop here in NY that add the correction to their number to mimic the DJ numbers.
Old Nov 17, 2010 | 09:44 AM
rcdash's Avatar
rcdash
It's also not that low in winter relative to summer where the #s do take a big hit (in shootout mode). Most dyno operators are familiar with the conversion of their dyno results to dynojet - not really an assumption.
Old Nov 17, 2010 | 10:50 AM
athenG's Avatar
athenG
/\ my point is what if the dyno operator already added the correction? For example, my local shop automatically add the DJ correction on his Dyno Dynamic. If I post my dyno, people will assume that I should be pushing more HP if I go to a DJ, but in reality my dyno already have the correction and should be already on par with a DJ dyno. MRC did the same thing with mine on his initial tune. He posted the dyno with the correction. So how do we know if that dyno dont have the correction?
Old Nov 17, 2010 | 11:06 AM
str8dum1's Avatar
str8dum1
the actual numbers dont even matter between the 2 BP setups. If anything the DD will spool the turbos faster, more like on the street. But the OP still is showing alot of lag compared to other BP setups and general gt35r powerlab setups
Old Nov 17, 2010 | 11:21 AM
CRIDDA's Avatar
CRIDDA
Damn you Sasha. Tax time is almost here, will see what funds look like after I put new floors in the house.
Congrats op, enjoy the new power
Old Nov 17, 2010 | 11:41 AM
binder's Avatar
binder
Originally Posted by BCs350z
I have the stock spring in it but i am running an aem EBC. The highest iat i saw was 102 degrees at full boost at like 6500 rpms.
you can choose spring rate when you order so one peron's "stock" isn't the same as anothers. which one does yours have?
I need more info on the intake temps. What is the ambient during that 102* intake temp? how long was the car run? how many pulls before you saw that?
Old Nov 17, 2010 | 11:45 AM
binder's Avatar
binder
true, i was viewing on my phone and couldn't see that the shift was 1000rpms.
Because the numbers he posted are very close (if not near identical) to the other dynoed BP kits on a DJ at the same boost level. So you can assume 2 things: dyno is reading lower than the others done on DJ's or his car at 10psi is 12% less powerful than all the others.
Old Nov 17, 2010 | 01:31 PM
tylerxfire's Avatar
tylerxfire
every dyno dynamics ive seen here in ny and been on were true dyno dynamics numbers and never corrected to read like a dynojet..
Old Nov 17, 2010 | 01:36 PM
Boosted Performance
I am working on 6 kits right now for stock, so there will be plenty to go around. The holidays should be very busy for me..
Old Nov 17, 2010 | 06:35 PM
350XTCz's Avatar
350XTCz
Looks good! What are your future plans for the car?
Old Nov 17, 2010 | 06:54 PM
Vas_Z33's Avatar
Vas_Z33
I think the turbo is sleeping and needs to wake the F up... =x.. just sayin lol
Old Nov 17, 2010 | 06:55 PM
Vas_Z33's Avatar
Vas_Z33
Vas, do you know how much timing you have?
Iam unsure of timing.. Ill ask vince
Old Nov 17, 2010 | 07:39 PM
binder's Avatar
binder
It's the same turbo and engine that you have....there shouldn't be any difference in it's ability to "wake up" unless something is wrong. I think rich is correct in that there might be a leak or something not working to full potential.
Old Nov 17, 2010 | 07:47 PM
Vas_Z33's Avatar
Vas_Z33
I was referring to the " whats the next future plan.. " as in built the motor and up the boost lol... 10psi is zzzzZZZ
Old Nov 17, 2010 | 07:50 PM
  #38
Dragonbreath's Avatar
Dragonbreath
Old Nov 17, 2010 | 07:54 PM
  #39
350zion's Avatar
350zion
Professional
^^^^One of them should be mine!!!!!
Old Nov 17, 2010 | 07:57 PM
  #40
350XTCz's Avatar
350XTCz
Gotcha haha. I need to up the boost myself. Need to find some time to install my boost controller and get a retune with higher psi.
I am still going off of wastegate pressure
