no reason to buy a Walbro 255L anymore
Old Feb 11, 2011 | 10:35 AM
  #141
IslandZavage's Avatar
IslandZavage
pricing?
Old Feb 11, 2011 | 10:54 AM
  #142
InjectedPerformance's Avatar
InjectedPerformance
Vendor - Former Vendor
$169 shipped. You may send paypal to: sales@injectedperformance.com (we must ship to confirmed addresses) or feel free to give me a call to place the order.
Thanks
Dustin
Injected Performance
888-465-7373
Old Feb 11, 2011 | 01:15 PM
  #143
ttg35fort's Avatar
ttg35fort
Professional
I searched the thread and found the flow data for the DW, but not for the Aeromotive. Maybe I missed it. Anyway, how do the two compare to one another?
Old Feb 11, 2011 | 02:34 PM
  #144
jruocco's Avatar
jruocco
Here you go
Attached Thumbnails no reason to buy a Walbro 255L anymore-aeromotivepumpcomparisongraph.jpg
Old Feb 11, 2011 | 04:36 PM
  #145
thawk408's Avatar
thawk408
So at WOT with a base of ~50psi, you really are not gaining "that" much of flow. I guess it could depend on how it is set up.
Old Feb 11, 2011 | 05:58 PM
  #146
Glex25's Avatar
Glex25
You can try lowering your initial fuel pressure to get more flow
I really don't know how well the injectors would react to a lower fuel pressure
or if it will have issues.
Old Feb 11, 2011 | 11:53 PM
  #147
nyqueenz's Avatar
nyqueenz
my car is going back in the hands of Hills Garage, for a fuel sys upgrade.. basically, the 255 WB will feed a custom made fuel sump tank fitted with either a Bosch or Deatchwerks fuel pump directly feeding fuel to my DW 1000cc Injectors..
Old Feb 12, 2011 | 01:07 AM
  #148
BabyZiLLa's Avatar
BabyZiLLa
So is this direct drop in / application specific? The one on the Injected site suggests it is Universal.
Old Feb 12, 2011 | 10:32 AM
  #149
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by jruocco
Here you go
Thank you!
Old Feb 14, 2011 | 05:33 AM
  #150
str8dum1's Avatar
str8dum1
more Aeromotive Stealth 340lph reading
http://www.ls1tech.com/forums/fuelin...l#post14246789
Old Feb 14, 2011 | 06:28 AM
  #151
ttg35fort's Avatar
ttg35fort
Professional
Is there any problem running the Aeromotive and DW pumps at very low pressure, maybe 1-3 psi? I will only be using one to keep an external surge tank filled, and there will be a fuel return line from the surge tank back to the fuel tank.
Here is a drawing of the setup:
Old Feb 14, 2011 | 10:45 AM
  #152
jerryd87's Avatar
jerryd87
shouldnt a walbro be able to provide more then enough fuel for a swirl pot? or mayby even the stock pump since the pressure pump is returning unused fuel to the swirl pot? considering this exact type of setup using a magnafuel 625, ends up being slighty cheaper then a dual intank and support more power. now if i could just find someone to ship me e85 to oahu for a semi decent price lol sorry for the slight thread jack
Old Feb 14, 2011 | 10:55 AM
  #153
str8dum1's Avatar
str8dum1
there'd be no problem. probably adviseable, depending on how big of an external pump you are going to use. If I was gonna use that kinda fuel setup, thats how I'd do it, along with a weldon 2345 or Aeromotive Eliminator
Old Feb 14, 2011 | 11:29 AM
  #154
ttg35fort's Avatar
ttg35fort
Professional
I have an SX fuel pump I bought a couple of years ago, so I'll be using that for the external fuel pump. It is more than adequate (though a bit noisy from I have been told). I'll mount it using rubber grommits to provide some noise isolation.
I am going this route because on my last setup, the Walbro sucked the stock internal swirl tank dry on a number of occasions when running Sebring and I leaned out. This setup should cure that issue. The external tank should provide a nice reserve after the stock swirl tank runs dry.
Old Feb 15, 2011 | 12:28 AM
  #155
midz350's Avatar
midz350
Old Feb 15, 2011 | 05:36 AM
  #156
ttg35fort's Avatar
ttg35fort
Professional
Nice. Thank you!
Old Feb 15, 2011 | 06:23 AM
  #157
RA11325's Avatar
RA11325
Do these install in a similar fashion to the Walbro?
Old Feb 15, 2011 | 06:29 AM
  #158
rcdash's Avatar
rcdash
Alternatively, just bump the voltage under boost? I'd like to see the DW and Aeromotive pump data at different voltages. Enough to reach xxx whp on E85 with one pump?
http://www.stealth316.com/
Old Feb 15, 2011 | 06:46 AM
  #159
BabyZiLLa's Avatar
BabyZiLLa
Someone want to chime in on this?
Old Feb 15, 2011 | 09:29 AM
  #160
Glex25's Avatar
Glex25
From what i have been reading they are drop in just like the walbro
Don't know if the swirl jet would need further modification than what gets done with the Walbro
