Dynosty does Boosted Performance Build (PICS)
Old Feb 28, 2011 | 11:48 AM
  #121
zmedic16's Avatar
zmedic16
ebay headers are the same design as the dc headers. same diameters as all the other headers. the only thing is that they are not equal lengh.
Old Mar 24, 2011 | 06:02 AM
  #122
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Post #2 updated. 512whp with aftermarket headers and bigger fmic.
Old Mar 24, 2011 | 06:35 AM
  #123
ashtrojan2008's Avatar
ashtrojan2008
Great news
Old Mar 24, 2011 | 06:38 AM
  #124
Sylvan Lake V35's Avatar
Sylvan Lake V35
So headers made about a 100hp difference , do you guys think the IC was an issue or was it just upgraded for the sake of upgrading? Nice numbers anyway
Old Mar 24, 2011 | 08:00 AM
  #125
DéDé's Avatar
DéDé
You can win more then 100hp with a good header on a charged engine.
Old Mar 24, 2011 | 08:28 AM
  #126
thatv35guy's Avatar
thatv35guy
Nice! So, the 94 whp gain came from the addition of a larger intercooler, headers, and increase in boost by 2-3 psi, correct?
Old Mar 24, 2011 | 08:36 AM
  #127
Boosted Performance's Avatar
Boosted Performance
Headers were the main reason/difference here. With the OEM header you could have run 30psi, and it would not make a difference as far as power gains go, because they did not flow past 400whp on that dyno.
I am sure with cams and a mild port would go a long way as well, but I think this is a good start. I bet that a .96 a/r turbine would also help on the top end.
Old Mar 24, 2011 | 08:45 AM
  #128
BCs350z's Avatar
BCs350z
wow. those are nice numbers!
Old Mar 24, 2011 | 08:57 AM
  #129
DéDé's Avatar
DéDé
Can you link how looks the new headers?
Old Mar 24, 2011 | 10:09 AM
  #130
str8dum1's Avatar
str8dum1
any high boost pulls?
512 on a 6765 on pump gas is pretty nice for daily driver. Nice bump in power.
Old Mar 24, 2011 | 10:13 AM
  #131
rcdash's Avatar
rcdash
Congrats to all involved. On that dyno, that is really nice power...
Old Mar 26, 2011 | 04:36 AM
  #132
zmedic16's Avatar
zmedic16
this is really good news. i bet there would of been some more gain with a plenum spacer or a different plenum all together. i wonder if i should go with cams since my motor is still out.
Old Mar 26, 2011 | 05:29 AM
  #133
NNOCENT's Avatar
NNOCENT
looks like i need a bigger front mount!
Old Mar 26, 2011 | 06:02 AM
  #134
binder's Avatar
binder
Find some stock cam dynos. I'm pretty sure there are some 600hp cars on stock cams.
Personally if my cams are damaged from this last incident then i'm not buying new ones. I'll put my stock ones back in.
I will say if you are ever thinking about cams and you have the money do it while the motor is out. It is a stupid amount of work to tear the motor down to do only cams. Once i get my engine back in this time i'll never take it apart JUST for cams in the future.
Old Mar 26, 2011 | 02:35 PM
  #135
S12 driver's Avatar
S12 driver
500whp on pump gas, nice!
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
