URGENT question re Vortech aux pump
Old Dec 31, 2010 | 12:02 PM
HotRodG35's Avatar
HotRodG35
The Aux pump and regulator is way to use OEM fuel system with stock Vortech setup. The Aux pump is not used until above 2000RPM with SS box. If the pulley set up is changed for greater boost than Aux pump/regulator become inadequate for tuning.
Your better off with walbro and upgraded injectors.
Old Dec 31, 2010 | 02:36 PM
mazymus's Avatar
mazymus
cool, will keep that in mind if I upgrade to 3.12 pulley.
I have the car now, with the cog belt off. Things are running w/ the SS box plugged, but no boost so no change from the stock ECU (I think.)
Interesting to see the AFR on the stock injectors/pump. I went overboard and got 2 UEGO's, one for each cat (pre-cat location). When cruising down the freeway w/ 2-3k rpm, I'm getting swings between 14.5 to 16. When WOT, lowest I saw was 11.
Also interesting to know that the passenger side (I think it was that side, still getting used to the gauges) was running leaner. I've seen that being discussed before, but cool to see it neve the less.
Oil temps gets to around 170, but that's after 30 min driving. I have to find out what the normal ranges for the oil temps are.
Boost always below zero of course (sadly), but that'll change soon I hope
Wonder if Vortech will give me a hardtime re their missing aux fuel pump? They seem pretty cool, but not sure how they would handle this (and the fact that they sent the wrong spacers and pipes...) I guess it happens though once in a while.
So my plan is to have them send the pump. I'll take it from there if things don't work out w/ them...
edit:
sounds like the avg oil temps are between 160-175F, anything over 250 (depending on your oil) is bad and can start oil to denature/break down.
http://www.*********.com/forums/173-...hey-worth.html
Last edited by mazymus; Dec 31, 2010 at 03:11 PM. Reason: found link that talks about oil temps
Old Jan 1, 2011 | 09:28 PM
mazymus's Avatar
mazymus
any online store recs for buying the bov filter, as well as a dual-gauge apillar pod for 5.2 mm gauges (for AEM gauges)? thanks.
Old Jan 1, 2011 | 10:52 PM
RetchedOne's Avatar
RetchedOne
I got the glowshift.com 3 gauge A Pillar pod and it fits my AEM gauges perfectly.
Old Jan 2, 2011 | 05:54 PM
mazymus's Avatar
mazymus
thanks man, I'll give them a shot. btw, are you using BOV filter? I heard it helps w/ mildly decreasing some of the sound at low RPM's.
ps, I came across the following FYI
https://my350z.com/forum/forced-indu...-silencer.html
http://www.superchargersonline.com/p...ber=V8H040-175
Old Jan 2, 2011 | 08:34 PM
RetchedOne's Avatar
RetchedOne
I bought one, and didnt put it on yet with my new kit. It isnt that loud... I like the noise.
I got my filter throught Nate at superchargersonline.com
Old Jan 4, 2011 | 08:06 AM
HotRodG35's Avatar
HotRodG35
I run a BOV filter purchased from Summit Racing.
It helps to quiet down the BOV and needed in your situation not running the cog belt connnected, unfiltered air is drawn thru BOV.
Old Jan 4, 2011 | 05:32 PM
djamps's Avatar
djamps
Isn't it called a BPV with superchargers?? You guys wish you could say you had a BOV LOL.
Old Jan 4, 2011 | 05:52 PM
str8dum1's Avatar
str8dum1
technically its a blow off valve if it vents to the atmosphere. but generally people call them on superchargers bypass valves bc most often the air is recirculated.
issyz
Jul 2, 2017 03:04 PM
