My FI story
Old Sep 27, 2011 | 05:17 AM
  #81
bjmax's Avatar
bjmax
Originally Posted by Spork
Put the oil cooler around the intake side of the intercooler. I've also seen some people with oil coolers mounted behind the intercooler.
Also, just my 2 cents, mount the BOV pre-intercooler.
any pictures? of the Oilcooler?
The BOV is going just after te IC and before the MAF..
Old Sep 27, 2011 | 05:34 AM
  #82
Spork's Avatar
Spork
Sorry, don't have any pictures, and I'm also on a different platform than you.
Placement shouldn't be a problem as long as you're willing to spend some time with cardboard to mock up the mounting and aluminum sheets for the mounting tabs.
The reason I suggested pre-intercooler was to prevent dumping cooled air. It may not make that big of a difference, if at all, but it's just something I prefer. Hell, my stock recirc valves are pre-cooler.
Looking forward to seeing more pics.
Old Sep 28, 2011 | 11:33 AM
  #83
bjmax's Avatar
bjmax
thx
i try this setup.
Old Oct 20, 2011 | 08:30 AM
  #84
bjmax's Avatar
bjmax
small update..
oil is in and i just need to install the halltech
Old Oct 20, 2011 | 01:12 PM
  #85
ace32x's Avatar
ace32x
looken good man
Old Oct 20, 2011 | 06:23 PM
  #86
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
love it
Old Oct 20, 2011 | 07:12 PM
  #87
dikspiel's Avatar
dikspiel
Chestons Toilet
curious as to why you had the dual intake ducts
Old Oct 23, 2011 | 10:43 PM
  #88
bjmax's Avatar
bjmax
To get as much air in there as possible. the car is getting ready for tuning next week
Old Nov 2, 2011 | 02:37 PM
  #89
bjmax's Avatar
bjmax
Its alive !!!!!
http://www.youtube.com/watch?v=xYFykIO8-ic
http://www.youtube.com/watch?v=0OhaBbRj9k4
Next week it is going to the tuner :mrgreen:
Old Nov 2, 2011 | 03:09 PM
  #90
TRYNALIVEPRO
nice dude, I know you're HAPPY AS HELL...... engine bay looks beautiful
Old Nov 5, 2011 | 09:56 AM
  #91
bjmax's Avatar
bjmax
He is of to the tuner, and out of my hands.
I love the pickup 505PK V10.
Old Nov 28, 2011 | 08:11 PM
  #92
jebz240's Avatar
jebz240
Updates? Dyno Pulls?
Old Nov 28, 2011 | 09:34 PM
  #93
bjmax's Avatar
bjmax
We had to solve some oil leakes. After that we saw that 1 bank is running 20% richer than bank 2. This week I am trying to solve this.
Done so far
change fuel regulators.
Change fuel pomps.
No positive result.
What can it be. Any suggestions?
Old Nov 29, 2011 | 05:41 AM
  #94
rcdash's Avatar
rcdash
Is the AFR imbalance under load or under vacuum or both? Under vacuum is normal because of plenum design (well, with the stock plenum). With the kinetix, I'm not sure. With an exhaust leak upstream of the O2 sensor, you might also get imbalance under vacuum. Under load it should equalize...
If it doesn't, test injectors per the FSM.
Old Nov 29, 2011 | 06:34 AM
  #95
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Done so far
Change fuel pomps.
No positive result.
I can only assume that the free air calibration of both O2 sensors was done.
If so, then (like rcdash suggested) it could very well be an exhaust leak, but more info is needed.
Old Nov 29, 2011 | 07:26 AM
  #96
binder's Avatar
binder
ya, i would say o2 problem causing incorrect readings.
possible manifold air leak on the lean bank side (unlikely though)
The chances of a whole bank of injectors being bad is rare and easy to test by swapping injectors between banks.
I know my cams are slightly off which causes a little bit of variance between my banks but only at certain vac cells. I was confused why i was having variances and then logged cam values and i assume that was the small issue. I'm not sure cams could create a 20% difference though. I would check to make sure both cams are at least working. If one has a wiring issue or a solenoid issue and is at 0* while the other is at 25* advance it could cause some problems.
Old Nov 29, 2011 | 10:13 PM
  #97
bjmax's Avatar
bjmax
Widebands are calibraded.
all under vacum.
only drivers site all sparks are wet so i know it is on all 3 cilinders.
1000 rpm 20% richer
3000 rpm it is getting leaner then the passeger site.
Pfff.. i hope to solve this.. but no luck so far.
Old Nov 29, 2011 | 10:19 PM
  #98
bjmax's Avatar
bjmax
the strage thing is also tha at 1 point it was running fine for 1 minute and then it was off again... like the first video above....
Old Nov 30, 2011 | 10:44 AM
  #99
rcdash's Avatar
rcdash
If it's only under vacuum, why does it matter? 10.4 vs 10.8? Ignore! You can try checking your exhaust manifold and downpipe connection... A small leak under hard vacuum will suck in enough outside air to cause a slight imbalance, but it's completely irrelevant.
Old Nov 30, 2011 | 11:38 AM
  #100
binder's Avatar
binder
or could be maybe a sticking injector if it's doing it heavily at idle.
mine is unbalanced in vac then they flip flop when i go WOT then they equalize.
